    Setting Several Data Points at once
    36 Posts 3 Posters 40.1k Views 4 Watching
      for (var pnt in CONTEXT_POINTS) {
           this[pnt].set(1);
      • R Offline
        Rodrigo
        Hi Matt,
        You are alway ready to help! Thanks for that.
        I am not bening able to understand how to do this, I have created the Scripting Data Source and added to it, External Context Points (from other Data Sources), this points are the ones that turn devices ON or OFF. Like this
        Then, I created the Binary data point with this properties
        Would you be so kind of expanding your previous reply a little more with this data?
        Thanks in advance.
        Best,
        Rodrigo
          Add all your modbus context points, PLUS one virtual datapoint that is settable. Make the virtual point the context point for firing. All other context points must not be ticked for firing the script.
          Put inside the for loop:
          if(this[pnt].xid==virtualpointxid){continue;}
          this[pnt].set..
          Dont want the script point to set the virtual point and make it fire itself again.
          Thus when the virtual point in the context is set, the script will run.
          If using an advanced scheduler, make it set that virtual point when it shifts from low to high.
          Hope that enlightens you
          • R Offline
            Rodrigo
            thanks Matt, but I am not able to understand how to make it work :(
              ok I shall write a complete solution for you tonight. Dont know what time it is where you are but I shall assemble it all for you later today.
              R 1 Reply Last reply Reply Quote 0
              • R Offline
                Rodrigo @MattFox
                @mattfox
                Really! Awesome, do not worry about the time, here is 19:21 (March 5) now.
                Paraguayan time.
                I could read it later tonight or even tomorrow and try to apply it.
                Thanks a lot!
                  11:34 AM here NZDT.
                  Ill have something here for you by breakfast :)
                  • R Offline
                    Rodrigo
                    You are the best!
                      OK!
                      First off, apologies Rodrigo. I can see where you got lost. The script was marginally more involved than I first suspected...
                      However. as promised: here is the solution for you to learn from and apply for your own personal use.
                      I have 3 batches of JSON for you to import and view to appreciate what to do. I have modelled this with virtual data sources for a proof of concept which can be applied in other places.
                      Virtual Datasource + points:
                        "dataSources":[
                            "xid":"DS_233ecafd-78eb-4837-98fc-8cbdb35430bc",
                            "name":"Temp Virtual",
                            "enabled":true,
                            "type":"VIRTUAL",
                            "alarmLevels":{
                              "POLL_ABORTED":"URGENT"
                            "purgeType":"YEARS",
                            "updatePeriods":1,
                            "updatePeriodType":"MINUTES",
                            "polling":false,
                            "quantize":false,
                            "useCron":false,
                            "editPermission":"",
                            "purgeOverride":false,
                            "purgePeriod":1
                        "dataPoints":[
                            "xid":"DP_c0_temperature",
                            "name":"Temp 1",
                            "enabled":true,
                            "loggingType":"ALL",
                            "pointLocator":{
                              "dataType":"NUMERIC",
                              "changeType":{
                                "type":"NO_CHANGE",
                                "startValue":"10"
                              "settable":true
                            "eventDetectors":[
                            "plotType":"SPLINE",
                            "rollup":"NONE",
                            "unit":"",
                            "simplifyType":"NONE",
                            "chartColour":"",
                            "chartRenderer":{
                              "type":"IMAGE",
                              "timePeriodType":"DAYS",
                              "numberOfPeriods":1
                            "dataSourceXid":"DS_233ecafd-78eb-4837-98fc-8cbdb35430bc",
                            "defaultCacheSize":1,
                            "deviceName":"Temp Virtual",
                            "discardExtremeValues":false,
                            "intervalLoggingPeriod":1,
                            "purgePeriod":1,
                            "readPermission":"",
                            "setPermission":"",
                            "tags":{
                            "textRenderer":{
                              "type":"ANALOG",
                              "useUnitAsSuffix":false,
                              "suffix":"",
                              "format":"0.00"
                            "tolerance":0.0
                            "xid":"DP_c1_temperature",
                            "name":"Temp 2",
                            "enabled":true,
                            "pointLocator":{
                              "changeType":{
                                "type":"NO_CHANGE",
                                "startValue":"10"
                              "settable":true
                            "eventDetectors":[
                            "rollup":"NONE",
                            "unit":"",
                            "chartColour":"",
                            "chartRenderer":{
                              "type":"IMAGE",
                              "numberOfPeriods":1
                            "purgePeriod":1,
                            "setPermission":"",
                            "tags":{
                            "textRenderer":{
                              "type":"ANALOG",
                              "suffix":"",
                              "format":"0.00"
                            "tolerance":0.0
                            "xid":"DP_c2_temperature",
                            "name":"Temp 3",
                            "enabled":true,
                            "pointLocator":{
                              "changeType":{
                                "type":"NO_CHANGE",
                                "startValue":"10"
                              "settable":true
                            "eventDetectors":[
                            "rollup":"NONE",
                            "unit":"",
                            "chartColour":"",
                            "chartRenderer":{
                              "type":"IMAGE",
                              "numberOfPeriods":1
                            "purgePeriod":1,
                            "setPermission":"",
                            "tags":{
                            "textRenderer":{
                              "type":"ANALOG",
                              "suffix":"",
                              "format":"0.00"
                            "tolerance":0.0
                            "xid":"DP_c3_temperature",
                            "name":"Temp 4",
                            "enabled":true,
                            "pointLocator":{
                              "changeType":{
                                "type":"NO_CHANGE",
                                "startValue":"10"
                              "settable":true
                            "eventDetectors":[
                            "rollup":"NONE",
                            "unit":"",
                            "chartColour":"",
                            "chartRenderer":{
                              "type":"IMAGE",
                              "numberOfPeriods":1
                            "purgePeriod":1,
                            "setPermission":"",
                            "tags":{
                            "textRenderer":{
                              "type":"ANALOG",
                              "suffix":"",
                              "format":"0.00"
                            "tolerance":0.0
                            "xid":"DP_c4_temperature",
                            "name":"Temp 5",
                            "enabled":true,
                            "pointLocator":{
                              "changeType":{
                                "type":"NO_CHANGE",
                                "startValue":"10"
                              "settable":true
                            "eventDetectors":[
                            "rollup":"NONE",
                            "unit":"",
                            "chartColour":"",
                            "chartRenderer":{
                              "type":"IMAGE",
                              "numberOfPeriods":1
                            "intervalLoggingPeriod":15,
                            "purgePeriod":1,
                            "setPermission":"",
                            "tags":{
                            "textRenderer":{
                              "type":"ANALOG",
                              "suffix":"",
                              "format":"0.00"
                            "tolerance":0.0
                            "xid":"DP_dfd30a93-8ac3-40b7-aa7f-9f40b2a583a8",
                            "name":"Trigger Point",
                            "enabled":true,
                            "pointLocator":{
                              "changeType":{
                                "type":"NO_CHANGE",
                                "startValue":"50"
                              "settable":true
                            "eventDetectors":[
                            "rollup":"NONE",
                            "unit":"",
                            "chartColour":"",
                            "chartRenderer":{
                              "type":"IMAGE",
                              "numberOfPeriods":1
                            "purgePeriod":1,
                            "setPermission":"",
                            "tags":{
                            "textRenderer":{
                              "type":"ANALOG",
                              "suffix":"",
                              "format":"0.00"
                            "tolerance":0.0
                      Next the scripted data source that uses these points:
                        "dataSources":[
                            "xid":"DS_dba43dbb-b0bf-497a-85f4-632ce54091d0",
                            "name":"Rodrigo's Scripted trigger",
                            "enabled":true,
                            "type":"SCRIPTING",
                            "alarmLevels":{
                              "SCRIPT_ERROR":"URGENT",
                              "CONTEXT_POINT_DISABLED":"IGNORE",
                              "DATA_TYPE_ERROR":"URGENT",
                              "POLL_ABORTED":"URGENT",
                              "LOG_ERROR":"URGENT"
                            "updatePeriods":1,
                            "updateEvent":"UPDATE",
                            "context":[
                                "varName":"t1",
                                "dataPointXid":"DP_c1_temperature",
                                "updateContext":false
                                "varName":"t2",
                                "dataPointXid":"DP_c2_temperature",
                                "varName":"t3",
                                "dataPointXid":"DP_c3_temperature",
                                "varName":"t4",
                                "dataPointXid":"DP_c4_temperature",
                                "varName":"trigger",
                                "dataPointXid":"DP_dfd30a93-8ac3-40b7-aa7f-9f40b2a583a8",
                                "updateContext":true
                                "varName":"t0",
                                "dataPointXid":"DP_c0_temperature",
                            "logLevel":"NONE",
                            "scriptPermissions":[
                              "superadmin"
                            "polling":false,
                            "executionDelaySeconds":0,
                            "historicalSetting":false,
                            "logCount":5,
                            "logSize":1.0,
                            "script":"var triggerpt = trigger.getDataPointWrapper();\r\nfor (var pnt in CONTEXT_POINTS) {\r\n    var pt = this[pnt].getDataPointWrapper();\r\nprint(pt.xid===triggerpt.xid);\r\n    if(pt.xid===triggerpt.xid){continue;}\r\n    else{\/\/we are not amending this point!!!! Do not want an infinite loop and a breakdown.\r\n     pt.runtime.set(  Math.random()*100 );\r\n    }\r\n }",
                            "quantize":false,
                            "useCron":false,
                            "purgePeriod":1
                      Finally, here is your event handler which is tied to an advanced scheduler which I believe you requested in another thread....
                         "advancedSchedules":[
                               "xid":"ADVSCH_25f85e3d-7c2b-4b80-9a50-93571e510896",
                               "defaultSchedule":{
                                  "dailySchedules":[
                                        "changes":[
                                           "01:55",
                                           "02:00",
                                           "02:50",
                                           "03:00",
                                           "04:00",
                                           "04:05",
                                           "04:50",
                                           "05:00",
                                           "06:00",
                                           "06:05",
                                           "07:00",
                                           "07:05",
                                           "08:05",
                                           "08:10",
                                           "08:55",
                                           "09:00",
                                           "09:55",
                                           "10:00",
                                           "11:00",
                                           "11:05",
                                           "12:00",
                                           "12:05",
                                           "12:55",
                                           "13:00",
                                           "13:55",
                                           "14:00",
                                           "15:05",
                                           "15:10"
                                        "changes":[
                                           "01:55",
                                           "02:00",
                                           "02:50",
                                           "03:00",
                                           "04:00",
                                           "04:05",
                                           "04:50",
                                           "05:00",
                                           "06:00",
                                           "06:05",
                                           "07:00",
                                           "07:05",
                                           "08:05",
                                           "08:10",
                                           "08:55",
                                           "09:00",
                                           "09:55",
                                           "10:00",
                                           "11:00",
                                           "11:05",
                                           "12:00",
                                           "12:05",
                                           "12:55",
                                           "13:00",
                                           "13:55",
                                           "14:00",
                                           "15:05",
                                           "15:10"
                                        "changes":[
                                           "01:55",
                                           "02:00",
                                           "02:50",
                                           "03:00",
                                           "04:00",
                                           "04:05",
                                           "04:50",
                                           "05:00",
                                           "06:00",
                                           "06:05",
                                           "07:00",
                                           "07:05",
                                           "08:05",
                                           "08:10",
                                           "08:55",
                                           "09:00",
                                           "09:55",
                                           "10:00",
                                           "11:00",
                                           "11:05",
                                           "12:00",
                                           "12:05",
                                           "12:55",
                                           "13:00",
                                           "13:55",
                                           "14:00",
                                           "15:05",
                                           "15:10"
                                        "changes":[
                                           "01:55",
                                           "02:00",
                                           "02:50",
                                           "03:00",
                                           "04:00",
                                           "04:05",
                                           "04:50",
                                           "05:00",
                                           "06:00",
                                           "06:05",
                                           "07:00",
                                           "07:05",
                                           "08:05",
                                           "08:10",
                                           "08:55",
                                           "09:00",
                                           "09:55",
                                           "10:00",
                                           "11:00",
                                           "11:05",
                                           "12:00",
                                           "12:05",
                                           "12:55",
                                           "13:00",
                                           "13:55",
                                           "14:00",
                                           "15:05",
                                           "15:10"
                                        "changes":[
                                           "01:55",
                                           "02:00",
                                           "02:50",
                                           "03:00",
                                           "04:00",
                                           "04:05",
                                           "04:50",
                                           "05:00",
                                           "06:00",
                                           "06:05",
                                           "07:00",
                                           "07:05",
                                           "08:05",
                                           "08:10",
                                           "08:55",
                                           "09:00",
                                           "09:55",
                                           "10:00",
                                           "11:00",
                                           "11:05",
                                           "12:00",
                                           "12:05",
                                           "12:55",
                                           "13:00",
                                           "13:55",
                                           "14:00",
                                           "15:05",
                                           "15:10"
                                        "changes":[
                                           "01:55",
                                           "02:00",
                                           "02:50",
                                           "03:00",
                                           "04:00",
                                           "04:05",
                                           "04:50",
                                           "05:00",
                                           "06:00",
                                           "06:05",
                                           "07:00",
                                           "07:05",
                                           "08:05",
                                           "08:10",
                                           "08:55",
                                           "09:00",
                                           "09:55",
                                           "10:00",
                                           "11:00",
                                           "11:05",
                                           "12:00",
                                           "12:05",
                                           "12:55",
                                           "13:00",
                                           "13:55",
                                           "14:00",
                                           "15:05",
                                           "15:10"
                                        "changes":[
                                           "01:55",
                                           "02:00",
                                           "02:50",
                                           "03:00",
                                           "04:00",
                                           "04:05",
                                           "04:50",
                                           "05:00",
                                           "06:00",
                                           "06:05",
                                           "07:00",
                                           "07:05",
                                           "08:05",
                                           "08:10",
                                           "08:55",
                                           "09:00",
                                           "09:55",
                                           "10:00",
                                           "11:00",
                                           "11:05",
                                           "12:00",
                                           "12:05",
                                           "12:55",
                                           "13:00",
                                           "13:55",
                                           "14:00",
                                           "15:05",
                                           "15:10"
                                  "offsetCount":196
                               "name":"Rodrigo's Scheduled trigger",
                               "alarmLevel":"IMPORTANT",
                               "errorAlarmLevel":"DO_NOT_LOG",
                               "user":"admin",
                               "enabled":true,
                               "exceptions":[
                         "eventHandlers":[
                               "xid":"EH_c0202c22-1684-4216-ae68-5a9bc0cb1e82",
                               "activeAction":"STATIC_VALUE",
                               "inactiveAction":"NONE",
                               "handlerType":"SET_POINT",
                               "name":"Rodrigo's Automated Trigger",
                               "targetPointId":"DP_dfd30a93-8ac3-40b7-aa7f-9f40b2a583a8",
                               "disabled":false,
                               "activeValueToSet":"1",
                               "scriptPermissions":"",
                               "eventTypes":[
                                     "XID":"ADVSCH_25f85e3d-7c2b-4b80-9a50-93571e510896",
                                     "sourceType":"ADVANCED_SCHEDULE",
                                     "scheduleEventType":"SCHEDULE_ACTIVE"
                               "additionalContext":[
                      You can amend the schedules however you like.
                      To show how this works manually: here is some dashboard markup:
                      <ma-get-point-value point-xid="DP_c0_temperature" point="pt1"></ma-get-point-value>
                      <ma-get-point-value point-xid="DP_c1_temperature" point="pt2"></ma-get-point-value>
                      <ma-get-point-value point-xid="DP_c2_temperature" point="pt3"></ma-get-point-value>
                      <ma-get-point-value point-xid="DP_c3_temperature" point="pt4"></ma-get-point-value>
                      <ma-get-point-value point-xid="DP_c4_temperature" point="pt5"></ma-get-point-value>
                      <ma-get-point-value point-xid="DP_dfd30a93-8ac3-40b7-aa7f-9f40b2a583a8" point="trigger"></ma-get-point-value>
                      <md-button class="md-accent md-raised md-hue-2"ng-click="oldpt1=pt1.renderedValue;
                      oldpt2=pt2.renderedValue;
                      oldpt3=pt3.renderedValue;
                      oldpt4=pt4.renderedValue;
                      oldpt5=pt5.renderedValue;
                      trigger.setValue(1);
                      ">HIT ME!</md-button>
                      <md-table>
                      <table>
                      <tr>
                      <th>{{pt1.name}}</th><th>{{pt2.name}}</th><th>{{pt3.name}}</th><th>{{pt4.name}}</th><th>{{pt5.name}}</th>
                      </tr>
                      <tr>
                      <!-- Current Values -->
                      <td>{{pt1.renderedValue}}</td><td>{{pt2.renderedValue}}</td><td>{{pt3.renderedValue}}</td><td>{{pt4.renderedValue}}</td><td>{{pt5.renderedValue}}</td>
                      </tr>
                      <!-- Previous Values -->
                      <td>{{oldpt1}}</td><td>{{oldpt2}}</td><td>{{oldpt3}}</td><td>{{oldpt4}}</td><td>{{oldpt5}}</td>
                      </tr>
                      </table>
                      </md-table>
                      Ok, that's all of the config for you. Please have a good look and take note at how I applied the event handler settings.
                      The way I implemented allows the scheduler to set the virtual trigger the same way as if you had clicked the button on the dashboard.
                      HOWEVER, you can use the code in the scripted datasource and all of your context points and run the script inside the handler instead. But that is entirely up to you.
                      Good luck!
                      • R Offline
                        Rodrigo
                        Thank a lot Matt! I will be trying it this week and see how it goes.
                        I really appreciate your help.
                        Best,
                        Rodrigo
                        • R Offline
                          Rodrigo
                          Hi Matt,
                          With your help and also a little local help (my brother) I have managed to do what I wanted.
                          One change I did was to move the trigger from the virtual data source to the scripted data source.
                          Virtual Data Source + Points
                            "dataSources":[
                                "xid":"DS_EdificioA",
                                "name":"Edificio A",
                                "enabled":true,
                                "type":"VIRTUAL",
                                "alarmLevels":{
                                "updatePeriods":10,
                                "updatePeriodType":"SECONDS",
                                "polling":true,
                                "quantize":true,
                                "useCron":false,
                                "purgePeriod":1
                            "dataPoints":[
                                "xid":"DP_Equipo01A",
                                "name":"ON \/ OFF (0 = ON - 1 = OFF )",
                                "enabled":true,
                                "loggingType":"ON_CHANGE",
                                "pointLocator":{
                                  "dataType":"BINARY",
                                  "changeType":{
                                    "type":"NO_CHANGE",
                                    "startValue":"true"
                                  "settable":true
                                "eventDetectors":[
                                "plotType":"STEP",
                                "rollup":"NONE",
                                "unit":"",
                                "chartColour":"",
                                "chartRenderer":{
                                  "type":"TABLE",
                                  "limit":10
                                "dataSourceXid":"DS_EdificioA",
                                "deviceName":"Equipo 01 A",
                                "purgePeriod":1,
                                "setPermission":"",
                                "tags":{
                                "textRenderer":{
                                  "type":"BINARY",
                                  "oneColour":"rgb(255, 51, 51)",
                                  "oneLabel":"OFF",
                                  "zeroColour":"rgb(102, 255, 102)",
                                  "zeroLabel":"ON"
                                "tolerance":0.0
                                "xid":"DP_Equipo02A",
                                "enabled":true,
                                "pointLocator":{
                                  "changeType":{
                                    "type":"NO_CHANGE",
                                    "startValue":"true"
                                  "settable":true
                                "eventDetectors":[
                                "plotType":"STEP",
                                "rollup":"NONE",
                                "unit":"",
                                "chartColour":"",
                                "chartRenderer":{
                                  "type":"TABLE",
                                  "limit":10
                                "deviceName":"Equipo 02 A",
                                "purgePeriod":1,
                                "setPermission":"",
                                "tags":{
                                "textRenderer":{
                                  "type":"BINARY",
                                  "oneLabel":"OFF",
                                  "zeroLabel":"ON"
                                "tolerance":0.0
                                "xid":"DP_Equipo03A",
                                "enabled":true,
                                "pointLocator":{
                                  "changeType":{
                                    "type":"NO_CHANGE",
                                    "startValue":"true"
                                  "settable":true
                                "eventDetectors":[
                                "plotType":"STEP",
                                "rollup":"NONE",
                                "unit":"",
                                "chartColour":"",
                                "chartRenderer":{
                                  "type":"TABLE",
                                  "limit":10
                                "deviceName":"Equipo 03 A",
                                "purgePeriod":1,
                                "setPermission":"",
                                "tags":{
                                "textRenderer":{
                                  "type":"BINARY",
                                  "oneLabel":"OFF",
                                  "zeroLabel":"ON"
                                "tolerance":0.0
                                "xid":"DP_Equipo04A",
                                "enabled":true,
                                "pointLocator":{
                                  "changeType":{
                                    "type":"NO_CHANGE",
                                    "startValue":"true"
                                  "settable":true
                                "eventDetectors":[
                                "plotType":"STEP",
                                "rollup":"NONE",
                                "unit":"",
                                "chartColour":"",
                                "chartRenderer":{
                                  "type":"TABLE",
                                  "limit":10
                                "deviceName":"Equipo 04 A",
                                "purgePeriod":1,
                                "setPermission":"",
                                "tags":{
                                "textRenderer":{
                                  "type":"BINARY",
                                  "oneLabel":"OFF",
                                  "zeroLabel":"ON"
                                "tolerance":0.0
                                "xid":"DP_Equipo05A",
                                "enabled":true,
                                "pointLocator":{
                                  "changeType":{
                                    "type":"NO_CHANGE",
                                    "startValue":"true"
                                  "settable":true
                                "eventDetectors":[
                                "plotType":"STEP",
                                "rollup":"NONE",
                                "unit":"",
                                "chartColour":"",
                                "chartRenderer":{
                                  "type":"TABLE",
                                  "limit":10
                                "deviceName":"Equipo 05 A",
                                "purgePeriod":1,
                                "setPermission":"",
                                "tags":{
                                "textRenderer":{
                                  "type":"BINARY",
                                  "oneLabel":"OFF",
                                  "zeroLabel":"ON"
                                "tolerance":0.0
                          Scritped Data Source with Trigger Point
                            "dataSources":[
                                "xid":"DS_ScriptEdificioA",
                                "name":"Script Edificio A",
                                "enabled":true,
                                "type":"SCRIPTING",
                                "alarmLevels":{
                                  "SCRIPT_ERROR":"DO_NOT_LOG",
                                  "CONTEXT_POINT_DISABLED":"DO_NOT_LOG",
                                  "DATA_TYPE_ERROR":"DO_NOT_LOG",
                                  "POLL_ABORTED":"DO_NOT_LOG",
                                  "LOG_ERROR":"DO_NOT_LOG"
                                "updatePeriods":5,
                                "context":[
                                    "varName":"pt01",
                                    "dataPointXid":"DP_Equipo01A",
                                    "varName":"pt02",
                                    "dataPointXid":"DP_Equipo02A",
                                    "varName":"pt03",
                                    "dataPointXid":"DP_Equipo03A",
                                    "varName":"pt04",
                                    "dataPointXid":"DP_Equipo04A",
                                    "varName":"pt05",
                                    "dataPointXid":"DP_Equipo05A",
                                "logLevel":"NONE",
                                  "superadmin"
                                "polling":false,
                                "logCount":5,
                                "logSize":1.0,
                                "script":"\/\/First: Get triggerA data.\r\nvar triggerPoint = triggerA.getDataPointWrapper();\r\n\r\n\/\/Second: For each point in CONTEXT_POINTS\r\n\/\/For example: Equipo 01 A, Equipo 02 A...\r\nfor (var contextPoint in CONTEXT_POINTS) {\r\n    \r\n    \/\/Third: Get the data\/status of each point.\r\n    \/\/For example: Equipo 01 A data.\r\n    var currentPoint = this[contextPoint].getDataPointWrapper();\r\n   \r\n    var triggerRuntimeValue = triggerPoint.runtime.value;\r\n    \r\n    if(currentPoint.xid === triggerPoint.xid) {\r\n        \/\/Considering that triggerA belongs to CONTEXT_POINTS.\r\n        \/\/We have to skip this one to avoid an infinite loop.\r\n        continue;\r\n        \r\n    } else {\r\n        \r\n        if(triggerRuntimeValue === true) {\r\n            currentPoint.runtime.set( false );\r\n            \r\n        } else if (triggerRuntimeValue === false) {\r\n            currentPoint.runtime.set( true );\r\n        }\r\n    }\r\n }",
                                "quantize":true,
                                "useCron":false,
                                "editPermission":"superadmin",
                                "purgePeriod":1
                            "dataPoints":[
                                "xid":"DP_scriptingEdificioA",
                                "name":"Trigger Edificio A",
                                "enabled":true,
                                "pointLocator":{
                                  "contextUpdate":true,
                                  "settable":true,
                                  "varName":"triggerA"
                                "eventDetectors":[
                                "plotType":"STEP",
                                "rollup":"NONE",
                                "unit":"",
                                "chartColour":"",
                                "chartRenderer":{
                                  "type":"TABLE",
                                  "limit":10
                                "dataSourceXid":"DS_ScriptEdificioA",
                                "deviceName":"Script Edificio A (Trigger)",
                                "purgePeriod":1,
                                "setPermission":"",
                                "tags":{
                                "textRenderer":{
                                  "type":"BINARY",
                                  "oneColour":"rgb(102, 255, 102)",
                                  "oneLabel":"ON",
                                  "zeroColour":"rgb(255, 51, 51)",
                                  "zeroLabel":"OFF"
                                "tolerance":0.0
                          Worked great!
                          I wanted to thank you again!
                          Best,
                          Rodrigo
                            Nicely done Rod! Proud of you man!
                            • R Offline
                              Rodrigo
                              Thanks, my background is actually electromechanical, so this is like advance chinese translated to esperanto hahaha
                              I miss DGLux, the combination with Mango was very powerful, at least for my not programmer capacity.
                                Feel free to message me in the future if you need any programming. Always happy to give some advice.
                                • R Offline
                                  Rodrigo @MattFox
                                  Hi @mattfox are you available for a quick chat?
                                    Message sent
