    Installation / Documentation for Mango 4.0b
    1 Posts 1 Posters 3.1k Views 1 Watching
    • flehF Offline
      fleh
      Hi guys,
      I ran into some troubles with the documentation / installation and wanted to let you know about it. The one I am referring to is hosted at: https://helpv4.mangoautomation.net/linux-installation and I am running a relatively clean and updated Opensuse 15.2
      1. The install script fails when trying to install Mango 4.0 (or any other version than the default 3.6.6 for that matter):
      Archive: /tmp/tmp.5ikghN5F2T
      End-of-central-directory signature not found. Either this file is not
      a zipfile, or it constitutes one disk of a multi-part archive. In the
      latter case the central directory and zipfile comment will be found on
      the last disk(s) of this archive.
      unzip: cannot find zipfile directory in one of /tmp/tmp.5ikghN5F2T or
      /tmp/tmp.5ikghN5F2T.zip, and cannot find /tmp/tmp.5ikghN5F2T.ZIP, period.
      1. There is an error when trying to run "chown -R mango:mango /opt/mango" because there is no mango group yet.
      2. The copy command fails because the unzipped mango archive does not have the overrides folder yet.
      cp /opt/mango/classes/env.properties /opt/mango/overrides/properties/
      1. manually starting Mango complains that the file does not exist...
      linux-wh13:/home/fl/SW # sudo -u mango /opt/mango/bin/start-mango.sh > /dev/null &
      [1] 13594
      linux-wh13:/home/fl/SW # sudo: /opt/mango/bin/start-mango.sh: command not found
      [1]+ Exit 1 sudo -u mango /opt/mango/bin/start-mango.sh > /dev/null
      ... and hence does start.
      ls /opt/mango/bin/
      certbot-deploy.sh genkey.sh getenv.sh install-mango.sh mango.service start-mango.sh start-options.sh stop-mango.sh
      1. While installing the service file works, it does -- unsurprisingly -- not start Mango neither.
      mango.service - Mango Automation
      Loaded: loaded (/etc/systemd/system/mango.service; enabled; vendor preset: disabled)
      Active: activating (auto-restart) (Result: exit-code) since Fri 2020-10-09 10:32:53 CEST; 2s ago
      Process: 13198 ExecStart=/opt/mango/bin/start-mango.sh (code=exited, status=203/EXEC)
      Oct 09 10:32:53 linux-wh13 systemd[1]: Failed to start Mango Automation.
      Oct 09 10:32:53 linux-wh13 systemd[1]: mango.service: Unit entered failed state.
      Oct 09 10:32:53 linux-wh13 systemd[1]: mango.service: Failed with result 'exit-code'.
      FWIW, v3.7.7 runs beautifully on this machine.
      Thanks in advance for any comments and help,
      Frank
