    How to use "/events/data-point-summaries" API?
    10 Posts 2 Posters 4.2k Views 2 Watching
      Malaguena
      Hello!
      I am trying to use /events/data-point-summaries API function which is shown in swagger. I could not get a response.
      The code used is shown below.
      How should I use /events/data-point-summaries API to get a successful response?
      Thanks!
      var eventsum = HttpBuilder.request({
          path: "http://localhost:8080/rest/v2/events/data-point-summaries",
          method: "POST",
          headers: {
              "Host": "10.167.35.76:8080",
            "Accept": "application/json, text/plain",
              "Content-Type": "application/json;charset=UTF-8",
              "Authorization":
                  "Bearer+"token,
          parameters:{
              "xids":[
                "DP_a638a144-5b1d-45c7-bcb1-b89097cbb08a",
                "DP_a7e64a32-8229-4909-95e3-a992208382c4"
          err: function (status, headers, content) {
              throw "Request got bad response: " + status;
          resp: function (status, headers, content) {
              return JSON.parse(content);
        @nurr said in How to use "/events/data-point-summaries" API?:
        "Bearer+"token,
        Should be "Authorization":"Bearer " + token,
          Malaguena
          @MattFox yes I have done this as you said. When I post, still couldn't get a response. Are we posting parameters in true format?
          We use Mango core version 3.7.5.
            Looking a little closer, it would appear the XIDS are in fact the xids of the event handlers themselves, not the datapoints.
            ie:EH_42e3843c-3510-484c-9a50-00c247834c79.
            EDIT: I could be wrong. have you actually tried using the swagger api tester?
            EDIT2: Just tested for you on 3.77: - it's datapoints, test with the swagger API then let's look at your script.
                "xid": "40281405",
                "counts": {}
              Malaguena
              @MattFox , I have tested via swagger-ui page. When I use datapoint xids it responses properly on swagger-ui.
              I have used the code below in the global script, and getting response like below.
              Response:
              {"cause":"MismatchedInputException: Cannot deserialize instance of `java.lang.String[]` out of START_OBJECT token\n at [Source: (PushbackInputStream); line: 1, column: 1]","mangoStatusName":null,"mangoStatusCode":-1,"localizedMessage":"Bad Request — com.fasterxml.jackson.databind.exc.MismatchedInputException: Cannot deserialize instance of `java.lang.String[]` out of START_OBJECT token\n at [Source: (PushbackInputStream); line: 1, column: 1]"}
              function httpReq(url,method,callback,headers,params)
              {//Second format, full request
                  if(headers===undefined){headers={};}
                  if(params===undefined){params={};}
                  if(method=="get")
                  HttpBuilder.get(url,headers,params)
              	.err(function(status, headers, content) { //setErrorCallback for linguistic completion
                          	print(status);	print(content);
              	}).resp(
              	 callback
               ).excp(function(exception) { //setExceptionCallback
              		throw exception.getMessage();
              	}).execute();
                  else
                       HttpBuilder.post(url,headers,params)
              	}).resp(
              	 callback
              	}).execute();
              var url = "http://10.167.35.76:8080/rest/v2/events/data-point-summaries";
              var method = "post";  //Or "post"
              var headers = {ContentType : "application/json", Authorization: "Bearer eyJhbGciOiJFUzUxMiJ9.eyJzdWIiOiJhZG1pbiIsImV4cCI6MTU5MjQ1OTMyNiwiaWQiOjEsInYiOjEsInR5cCI6ImF1dGgifQ.AZBrTRgtnP7W-88iiNbTn8oHFtjAMieGzEtC-Lr2uLRcZsDftzHKqct-gABlixlEErQqrmTRxF-y8aTprxld59tYAVdcggptg-jyJ-tPHqKSiaIY9VwNnefsxDf-qUTRQ9WeGi95jf1pQDhDQnSqsNsJ_HAFrD_Z0DiFoQwY9Z01iWcE" };
              var parameters ={xids:["DP_c244739c-86cd-43e3-95c5-b76acf4730b2"]}; /* If needed exclude if not*/
              var handleResponse = function(status, headers, content)
                 var data = JSON.parse(content);
                print(data);
              httpReq(url, method, handleResponse , headers);
                Aha! I see why now! You need to send it in the body of the message not as a parameter!
                Ok sorry to be a pain, but a different approach is needed - this will be with javascript's xmlhttp ajax handler.
                  This was written by Phil Dunlap, so i can't take any credit here: but this will help you get your request out.
                  First make a global script by the name of XMLHttp Request: the function to call is called newHttpRequest:
                  function newHttpRequest(method, url, headers) {
                  	var http = new XMLHttpRequest();
                  	http.open(method, url, true);
                  	http.setRequestHeader("Accept", "application/json")
                  	http.setRequestHeader("Authorization", "Bearer " + token)
                  	if(headers != null) {
                  		for(var header in headers)
                  			http.setRequestHeader(header, headers[header]);
                  	return http;
                  Next:
                  Your API body:
                  requestBody = {
                    "xids": [ //plonk xids in this array
                  Your Methods:
                  var getEventSummary = newHttpRequest('POST', "http://10.167.35.76:8080/rest/v2/events/data-point-summaries", headers);
                  getEventSummary.onreadystatechange  = function() {
                  	if (getEventSummary.readyState == XMLHttpRequest.DONE) {
                  		//var response = JSON.parse(getEventSummary.responseText); //Then do stuff
                  		console.log(getEventSummary.responseText);
                  getEventSummary.send(JSON.stringify(valuesRequestBody));
                  Edit sorry Nurr, I've mislead you. The embedded javascript engine doesn't support this.
                  You'd have to do this from an external system.
                    @terrypacker , made a bit of a blunder here. Does the HttpRequest system support a POST body? and if so how can it be implemented?
                    It'd be good to add it to the wrapper I wrote...
                      Malaguena
                      Hi! @MattFox @terrypacker
                      Is there any update about it?
                        Not without writing your own API and using that to make your query then calling that from mango instead.
