    Corrupt H2 Database
    4 Posts 2 Posters 1.7k Views 2 Watching
    • B Offline
      Brad_GMI
      Good Afternoon All,
      I am receiving this error on one of our client systems in the field:
      File corrupted while reading record: "[360329] stream data key:16680 pos:11 remaining:0". Possible solution: use the recovery tool [90030-181] 90030/90030 (Help)
      Based on a quick search it looks like there are varying degrees of success in recovering the database file.
      Has anyone had any experience in recovering a Mango H2 database?
      Thanks!
        Hi Brad_GMI,
        Yeah, I've done it a couple of times or more...
        Here's the thread I typically link people to: https://forum.infiniteautomation.com/topic/2748/how-to-restore-a-database-backup
        Which has the easy way (works if the backup was created from the same version of Mango, in the third post) and the command line way (works even with backups that are from a version prior to the current version, but must be done when Mango is off and you may need to adjust the path to the H2 jar file from the second post as the version has changed).
        I would expect restoring a database backup will solve the issue. If you're using the NoSQL module, the only thing that would be lost is any events or modifications that you made to the configuration since the backup was created: the data will have still been recorded into the NoSQL database.
        • B Offline
          Brad_GMI
          I've attempted several recoveries from the available backups. They are all producing these errors once the restore process completes:
          org.springframework.web.util.NestedServletException: Request processing failed; nested exception is org.springframework.jdbc.BadSqlGrammarException: PreparedStatementCallback; bad SQL grammar [SELECT edt.id,edt.xid,edt.sourceTypeName,edt.typeName,edt.data,edt.dataPointId FROM eventDetectors AS edt WHERE edt.dataPointId=? ORDER BY id]; nested exception is org.h2.jdbc.JdbcSQLException: Table "EVENTDETECTORS" not found; SQL statement:
          SELECT edt.id,edt.xid,edt.sourceTypeName,edt.typeName,edt.data,edt.dataPointId FROM eventDetectors AS edt WHERE edt.dataPointId=? ORDER BY id [42102-181]
          	at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:982)
          	at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:861)
          	at javax.servlet.http.HttpServlet.service(HttpServlet.java:687)
          	at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:846)
          	at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
          	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:808)
          	at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1669)
          	at com.serotonin.m2m2.web.filter.WebContextFilter.doFilter(WebContextFilter.java:43)
          	at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1652)
          	at com.serotonin.m2m2.web.filter.LoggedInFilter.doFilter(LoggedInFilter.java:49)
          	at com.serotonin.m2m2.web.filter.UrlSecurityFilter.doFilter(UrlSecurityFilter.java:206)
          	at com.serotonin.web.filter.CharacterSetFilter.doFilter(CharacterSetFilter.java:37)
          	at org.eclipse.jetty.servlets.UserAgentFilter.doFilter(UserAgentFilter.java:83)
          	at org.eclipse.jetty.servlets.GzipFilter.doFilter(GzipFilter.java:364)
          	at org.springframework.web.filter.ShallowEtagHeaderFilter.doFilterInternal(ShallowEtagHeaderFilter.java:87)
          	at com.serotonin.m2m2.web.filter.MangoShallowEtagHeaderFilter.doFilterInternal(MangoShallowEtagHeaderFilter.java:47)
          	at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
          	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:317)
          	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127)
          	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91)
          	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)
          	at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:115)
          	at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:137)
          	at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:111)
          	at org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:169)
          	at org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:63)
          	at org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:121)
          	at com.serotonin.m2m2.web.mvc.spring.security.CsrfHeaderFilter.doFilterInternal(CsrfHeaderFilter.java:41)
          	at org.springframework.security.web.csrf.CsrfFilter.doFilterInternal(CsrfFilter.java:100)
          	at org.springframework.security.web.header.HeaderWriterFilter.doFilterInternal(HeaderWriterFilter.java:66)
          	at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)
          	at org.springframework.security.web.context.request.async.WebAsyncManagerIntegrationFilter.doFilterInternal(WebAsyncManagerIntegrationFilter.java:56)
          	at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:214)
          	at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:177)
          	at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
          	at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
          	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:585)
          	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
          	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)
          	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)
          	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)
          	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)
          	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
          	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)
          	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
          	at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:215)
          	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
          	at org.eclipse.jetty.server.Server.handle(Server.java:499)
          	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:310)
          	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)
          	at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:540)
          	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)
          	at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)
          Caused by: org.springframework.jdbc.BadSqlGrammarException: PreparedStatementCallback; bad SQL grammar [SELECT edt.id,edt.xid,edt.sourceTypeName,edt.typeName,edt.data,edt.dataPointId FROM eventDetectors AS edt WHERE edt.dataPointId=? ORDER BY id]; nested exception is org.h2.jdbc.JdbcSQLException: Table "EVENTDETECTORS" not found; SQL statement:
          	at org.springframework.jdbc.support.SQLErrorCodeSQLExceptionTranslator.doTranslate(SQLErrorCodeSQLExceptionTranslator.java:231)
          	at org.springframework.jdbc.support.AbstractFallbackSQLExceptionTranslator.translate(AbstractFallbackSQLExceptionTranslator.java:73)
          	at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:645)
          	at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:680)
          	at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:712)
          	at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:722)
          	at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:772)
          	at com.serotonin.db.DaoUtils.query(DaoUtils.java:308)
          	at com.serotonin.m2m2.db.dao.EventDetectorDao.getWithSourceId(EventDetectorDao.java:177)
          	at com.serotonin.m2m2.db.dao.DataPointDao.setEventDetectors(DataPointDao.java:460)
          	at com.serotonin.m2m2.db.dao.DataPointDao.setRelationalData(DataPointDao.java:288)
          	at com.serotonin.m2m2.db.dao.DataPointDao.getDataPoint(DataPointDao.java:167)
          	at com.serotonin.m2m2.db.dao.DataPointDao.getDataPoint(DataPointDao.java:159)
          	at com.serotonin.m2m2.web.mvc.controller.DataPointDetailsController.handleRequest(DataPointDetailsController.java:78)
          	at com.serotonin.m2m2.web.mvc.UrlHandlerController.handleRequest(UrlHandlerController.java:36)
          	at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
          	at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
          	at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
          	at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:970)
          	... 74 more
          Caused by: org.h2.jdbc.JdbcSQLException: Table "EVENTDETECTORS" not found; SQL statement:
          	at org.h2.message.DbException.getJdbcSQLException(DbException.java:345)
          	at org.h2.message.DbException.get(DbException.java:179)
          	at org.h2.message.DbException.get(DbException.java:155)
          	at org.h2.command.Parser.readTableOrView(Parser.java:5227)
          	at org.h2.command.Parser.readTableFilter(Parser.java:1221)
          	at org.h2.command.Parser.parseSelectSimpleFromPart(Parser.java:1860)
          	at org.h2.command.Parser.parseSelectSimple(Parser.java:1969)
          	at org.h2.command.Parser.parseSelectSub(Parser.java:1854)
          	at org.h2.command.Parser.parseSelectUnion(Parser.java:1675)
          	at org.h2.command.Parser.parseSelect(Parser.java:1663)
          	at org.h2.command.Parser.parsePrepared(Parser.java:433)
          	at org.h2.command.Parser.parse(Parser.java:305)
          	at org.h2.command.Parser.parse(Parser.java:277)
          	at org.h2.command.Parser.prepareCommand(Parser.java:242)
          	at org.h2.engine.Session.prepareLocal(Session.java:446)
          	at org.h2.engine.Session.prepareCommand(Session.java:388)
          	at org.h2.jdbc.JdbcConnection.prepareCommand(JdbcConnection.java:1189)
          	at org.h2.jdbc.JdbcPreparedStatement.<init>(JdbcPreparedStatement.java:72)
          	at org.h2.jdbc.JdbcConnection.prepareStatement(JdbcConnection.java:277)
          	at org.springframework.jdbc.core.JdbcTemplate$SimplePreparedStatementCreator.createPreparedStatement(JdbcTemplate.java:1516)
          	at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:623)
          	... 90 more
          REQUEST URL
          http://localhost:8080/exception/error.jsp
          REQUEST PARAMETERS
          REQUEST HEADERS
             Cookie=MANGO8080=1oorhho5d8upo1gbk0m2mlbznz; XSRF-TOKEN=f1840133-71be-4aaf-9ff9-e5cc0422867d
             Accept=text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8
             Upgrade-Insecure-Requests=1
             User-Agent=Mozilla/5.0 (Windows NT 6.1; Win64; x64; rv:65.0) Gecko/20100101 Firefox/65.0
             Referer=http://localhost:8080/modules.shtm
             Connection=keep-alive
             Host=localhost:8080
             Accept-Language=en-US,en;q=0.5
             Accept-Encoding=gzip, deflate
          REQUEST ATTRIBUTES
             javax.servlet.forward.context_path=
             org.springframework.web.context.request.async.WebAsyncManager.WEB_ASYNC_MANAGER=org.springframework.web.context.request.async.WebAsyncManager@5252d6dd
             javax.servlet.error.status_code=500
             javax.servlet.forward.servlet_path=/data_point_details.shtm
             org.springframework.web.servlet.DispatcherServlet.CONTEXT=WebApplicationContext for namespace 'springDispatcher-servlet': startup date [Mon Feb 18 15:00:34 EST 2019]; parent: Root WebApplicationContext
             javax.servlet.jsp.jstl.fmt.localizationContext.request=org.springframework.web.servlet.support.JstlUtils$SpringLocalizationContext@1bc9424c
             org.springframework.web.servlet.HandlerMapping.introspectTypeLevelMapping=false
             org.eclipse.jetty.server.error_page=/exception/error.jsp
             __spring_security_session_mgmt_filter_applied=true
             urlSecurity=true
             org.springframework.web.servlet.DispatcherServlet.LOCALE_RESOLVER=org.springframework.web.servlet.i18n.SessionLocaleResolver@6a6a2a03
             org.springframework.web.servlet.HandlerMapping.bestMatchingPattern=/data_point_details.shtm
             org.springframework.web.servlet.DispatcherServlet.OUTPUT_FLASH_MAP=FlashMap [attributes={}, targetRequestPath=null, targetRequestParams={}]
             javax.servlet.error.exception_type=class org.springframework.web.util.NestedServletException
             org.springframework.web.servlet.DispatcherServlet.FLASH_MAP_MANAGER=org.springframework.web.servlet.support.SessionFlashMapManager@3b093a20
             lang=en
             javax.servlet.forward.request_uri=/data_point_details.shtm
             availableLanguages=[]
             javax.servlet.http.HttpServletResponse=org.springframework.security.web.header.HeaderWriterFilter$HeaderWriterResponse@3893bdbb
             __spring_security_filterSecurityInterceptor_filterApplied=true
             _csrf=org.springframework.security.web.csrf.DefaultCsrfToken@d43e349
             javax.servlet.error.servlet_name=springDispatcher
             javax.servlet.error.message=org.springframework.web.util.NestedServletException: Request processing failed; nested exception is org.springframework.jdbc.BadSqlGrammarException: PreparedStatementCallback; bad SQL grammar [SELECT edt.id,edt.xid,edt.sourceTypeName,edt.typeName,edt.data,edt.dataPointId FROM eventDetectors AS edt WHERE edt.dataPointId=? ORDER BY id]; nested exception is org.h2.jdbc.JdbcSQLException: Table "EVENTDETECTORS" not found; SQL statement:
             org.springframework.web.servlet.DispatcherServlet.THEME_SOURCE=WebApplicationContext for namespace 'springDispatcher-servlet': startup date [Mon Feb 18 15:00:34 EST 2019]; parent: Root WebApplicationContext
             instanceDescription=My Mango Automation
             NEW_ID=-1
             org.springframework.web.servlet.HandlerMapping.pathWithinHandlerMapping=/data_point_details.shtm
             org.springframework.security.web.csrf.CsrfToken=org.springframework.security.web.csrf.DefaultCsrfToken@d43e349
             javax.servlet.error.request_uri=/data_point_details.shtm
             org.springframework.web.servlet.DispatcherServlet.THEME_RESOLVER=org.springframework.web.servlet.theme.FixedThemeResolver@3642fad0
             javax.servlet.jsp.jstl.fmt.locale.request=en_US
             javax.servlet.error.exception=org.springframework.web.util.NestedServletException: Request processing failed; nested exception is org.springframework.jdbc.BadSqlGrammarException: PreparedStatementCallback; bad SQL grammar [SELECT edt.id,edt.xid,edt.sourceTypeName,edt.typeName,edt.data,edt.dataPointId FROM eventDetectors AS edt WHERE edt.dataPointId=? ORDER BY id]; nested exception is org.h2.jdbc.JdbcSQLException: Table "EVENTDETECTORS" not found; SQL statement:
          SESSION ATTRIBUTES
             org.springframework.security.web.csrf.HttpSessionCsrfTokenRepository.CSRF_TOKEN=org.springframework.security.web.csrf.DefaultCsrfToken@d43e349
             sessionUser=User [id=1, username=admin, password={BCRYPT}$2a$10$geXLtQkG69172R6A5oHyGO4uv4UrMwPNVg0/XiNvsttNfgDK9m0wC, email=admin@yourMangoDomain.com, phone=, disabled=false, homeUrl=null, lastLogin=0, receiveAlarmEmails=-3, receiveOwnAuditEvents=false, timezone=null, permissions=superadmin]
             LONG_POLL_DATA_TIMEOUT=1550520355793
             SPRING_SECURITY_CONTEXT=org.springframework.security.core.context.SecurityContextImpl@eefb1197: Authentication: org.springframework.security.authentication.UsernamePasswordAuthenticationToken@eefb1197: Principal: User [id=1, username=admin, password={BCRYPT}$2a$10$geXLtQkG69172R6A5oHyGO4uv4UrMwPNVg0/XiNvsttNfgDK9m0wC, email=admin@yourMangoDomain.com, phone=, disabled=false, homeUrl=null, lastLogin=0, receiveAlarmEmails=-3, receiveOwnAuditEvents=false, timezone=null, permissions=superadmin]; Credentials: [PROTECTED]; Authenticated: true; Details: null; Granted Authorities: ROLE_superadmin, ROLE_ADMIN
             LONG_POLL_DATA=[com.serotonin.m2m2.web.dwr.longPoll.LongPollData@360ca62, com.serotonin.m2m2.web.dwr.longPoll.LongPollData@8d8250d, com.serotonin.m2m2.web.dwr.longPoll.LongPollData@4c78eef5, com.serotonin.m2m2.web.dwr.longPoll.LongPollData@1df20e14]
          CONTEXT ATTRIBUTES
             org.eclipse.jetty.server.webapp.ContainerIncludeJarPattern=.*\.jar$
             DwrContainer=org.directwebremoting.impl.DefaultContainer@11ab28ec
             LocalDeviceDwr=com.serotonin.ma.bacnet.device.LocalDeviceDwr@309ec473
             constants.EventType.EventTypeNames.AUDIT=AUDIT
             constants.SystemEventType.TYPE_USER_LOGIN=USER_LOGIN
             constants.Permissions.DataPointAccessTypes.READ=1
             org.directwebremoting.ContainerList=[org.directwebremoting.impl.DefaultContainer@11ab28ec]
             constants.DataTypes.BINARY=1
             constants.UserComment.TYPE_EVENT=1
             constants.SystemEventType.TYPE_SYSTEM_STARTUP=SYSTEM_STARTUP
             constants.SystemEventType.TYPE_REJECTED_WORK_ITEM=REJECTED_WORK_ITEM
             constants.AuditEventType.TYPE_EVENT_DETECTOR=EVENT_DETECTOR
             javax.servlet.ServletConfig=org.eclipse.jetty.servlet.ServletHolder$Config@3482d47c
             javax.servlet.http.HttpServlet=org.directwebremoting.servlet.DwrServlet@31342b54
             org.eclipse.jetty.tmpdirConfigured=true
             constants.EventType.EventTypeNames.DATA_POINT=DATA_POINT
             clientSideMessages={common.alarmLevel.lifeSafety=com.serotonin.m2m2.i18n.TranslatableMessage@1c71626, common.disabled=com.serotonin.m2m2.i18n.TranslatableMessage@be9bfeff, header.mute=com.serotonin.m2m2.i18n.TranslatableMessage@43df3cba, header.unmute=com.serotonin.m2m2.i18n.TranslatableMessage@d635aa93, common.alarmLevel.critical=com.serotonin.m2m2.i18n.TranslatableMessage@2b076d7, js.help.related=com.serotonin.m2m2.i18n.TranslatableMessage@3dce6ae3, js.help.lastUpdated=com.serotonin.m2m2.i18n.TranslatableMessage@729293fd, js.email.addAddress=com.serotonin.m2m2.i18n.TranslatableMessage@cbb9a38a, js.help.error=com.serotonin.m2m2.i18n.TranslatableMessage@f876c0, js.email.addUser=com.serotonin.m2m2.i18n.TranslatableMessage@49cc77b5, js.email.addMailingList=com.serotonin.m2m2.i18n.TranslatableMessage@6fa4a69f, js.email.noRecipForEmail=com.serotonin.m2m2.i18n.TranslatableMessage@4b694592, common.access.set=com.serotonin.m2m2.i18n.TranslatableMessage@a3e5309b, common.access.read=com.serotonin.m2m2.i18n.TranslatableMessage@d8bff83d, common.loading=com.serotonin.m2m2.i18n.TranslatableMessage@cf5f0419, common.sendTestEmail=com.serotonin.m2m2.i18n.TranslatableMessage@8fd89c9f, common.disabledToggle=com.serotonin.m2m2.i18n.TranslatableMessage@d7f89333, common.alarmLevel.none=com.serotonin.m2m2.i18n.TranslatableMessage@223c1a70, common.administrator=com.serotonin.m2m2.i18n.TranslatableMessage@a467f3ea, common.enabledToggle=com.serotonin.m2m2.i18n.TranslatableMessage@ea5c2f12, common.alarmLevel.urgent=com.serotonin.m2m2.i18n.TranslatableMessage@8fa9c879, common.minimize=com.serotonin.m2m2.i18n.TranslatableMessage@5d740b21, js.email.noRecipients=com.serotonin.m2m2.i18n.TranslatableMessage@d78563d2, common.user=com.serotonin.m2m2.i18n.TranslatableMessage@8a9479ce, events.silence=com.serotonin.m2m2.i18n.TranslatableMessage@8376c0ac, js.email.testSent=com.serotonin.m2m2.i18n.TranslatableMessage@f59d9881, common.alarmLevel.ignore=com.serotonin.m2m2.i18n.TranslatableMessage@7a97f30a, common.maximize=com.serotonin.m2m2.i18n.TranslatableMessage@c752a74f, common.alarmLevel.doNotLog=com.serotonin.m2m2.i18n.TranslatableMessage@9d8a4f14, events.unsilence=com.serotonin.m2m2.i18n.TranslatableMessage@29ad6533, common.alarmLevel.info=com.serotonin.m2m2.i18n.TranslatableMessage@2239cfe6}
             constants.SystemEventType.TYPE_SET_POINT_HANDLER_FAILURE=SET_POINT_HANDLER_FAILURE
             MangoApiSystemSettingsDwr=com.infiniteautomation.mangoApi.web.MangoApiSystemSettingsDwr@799089d6
             constants.DataTypes.ALPHANUMERIC=4
             constants.Permissions.DataPointAccessTypes.ADMIN=4
             constants.Permissions.DataPointAccessTypes.SET=2
             constants.AuditEventType.TYPE_DATA_SOURCE=DATA_SOURCE
             constants.SystemEventType.TYPE_EMAIL_SEND_FAILURE=EMAIL_SEND_FAILURE
             constants.SystemEventType.TYPE_UPGRADE_CHECK=UPGRADE_CHECK
             constants.Permissions.DataPointAccessTypes.NONE=0
             org.directwebremoting.impl.ServerContext=org.directwebremoting.impl.DefaultServerContext@3f6b67cb
             constants.EventType.EventTypeNames.PUBLISHER=PUBLISHER
             org.eclipse.jetty.containerInitializers=[ContainerInitializer{org.eclipse.jetty.apache.jsp.JettyJasperInitializer,interested=[],applicable=[],annotated=[]}]
             org.eclipse.jetty.server.Executor=qtp1324514662{STARTED,10<=10<=200,i=6,q=0}
             constants.EventType.EventTypeNames.DATA_SOURCE=DATA_SOURCE
             constants.SystemEventType.TYPE_LICENSE_CHECK=LICENSE_CHECK
             org.springframework.web.context.WebApplicationContext.ROOT=Root WebApplicationContext: startup date [Mon Feb 18 15:00:31 EST 2019]; root of context hierarchy
             org.springframework.web.context.support.ServletContextScope=org.springframework.web.context.support.ServletContextScope@1de8756e
             constants.SystemEventType.TYPE_SYSTEM_SHUTDOWN=SYSTEM_SHUTDOWN
             SystemSettingsDwr=com.serotonin.m2m2.web.dwr.SystemSettingsDwr@d16830c
             mangoMessageKeys=[Ljava.lang.String;@38290674
             org.directwebremoting.WebContextFactory$WebContextBuilder=org.directwebremoting.impl.DefaultWebContextBuilder@140411b3
             org.apache.jasper.runtime.JspApplicationContextImpl=org.apache.jasper.runtime.JspApplicationContextImpl@4a994558
             javax.servlet.context.tempdir=C:\EnsureSmart\work
             constants.DataTypes.MULTISTATE=2
             org.apache.tomcat.InstanceManager=org.apache.tomcat.SimpleInstanceManager@732ea1e4
             org.apache.catalina.jsp_classpath=C:\EnsureSmart\web\modules\sqlConsole\classes;C:\EnsureSmart\web\modules\sqlConsole\lib\m2m2-sqlConsole-1.6.0.jar;C:\EnsureSmart\web\modules\sstGraphics\classes;C:\EnsureSmart\web\modules\sstGraphics\lib\m2m2-sstGraphics-1.2.0.jar;C:\EnsureSmart\web\modules\TCPIP\classes;C:\EnsureSmart\web\modules\TCPIP\lib\m2m2-TCPIP-1.2.0.jar;C:\EnsureSmart\web\modules\dataPointDetailsView\classes;C:\EnsureSmart\web\modules\dataPointDetailsView\lib\m2m2-dataPointDetailsView-1.1.0.jar;C:\EnsureSmart\web\modules\jsonFileImport\classes;C:\EnsureSmart\web\modules\jsonFileImport\lib\m2m2-jsonFileImport-1.2.2.jar;C:\EnsureSmart\web\modules\mbus\classes;C:\EnsureSmart\web\modules\mbus\lib\commons-beanutils-1.8.3.jar;C:\EnsureSmart\web\modules\mbus\lib\commons-collections-3.2.2.jar;C:\EnsureSmart\web\modules\mbus\lib\commons-lang-2.5.jar;C:\EnsureSmart\web\modules\mbus\lib\commons-logging-1.1.1.jar;C:\EnsureSmart\web\modules\mbus\lib\ezmorph-1.0.6.jar;C:\EnsureSmart\web\modules\mbus\lib\json-lib-2.4-jdk15.jar;C:\EnsureSmart\web\modules\mbus\lib\m2m2-mbus-1.2.0.jar;C:\EnsureSmart\web\modules\mbus\lib\mbus4j-core-1.0.0.jar;C:\EnsureSmart\web\modules\mbus\lib\mbus4j-master-1.0.0.jar;C:\EnsureSmart\web\modules\mbus\lib\spsw-java-0.0.7.jar;C:\EnsureSmart\web\modules\twilio\classes;C:\EnsureSmart\web\modules\twilio\lib\m2m2-twilio-1.2.0.jar;C:\EnsureSmart\web\modules\twilio\lib\twilio-java-sdk-3.4.1-jar-with-dependencies.jar;C:\EnsureSmart\web\modules\pop3\classes;C:\EnsureSmart\web\modules\pop3\lib\m2m2-pop3-1.6.0.jar;C:\EnsureSmart\web\modules\vmstat\classes;C:\EnsureSmart\web\modules\vmstat\lib\m2m2-vmstat-1.6.0.jar;C:\EnsureSmart\web\modules\egauge\classes;C:\EnsureSmart\web\modules\egauge\lib\m2m2-egauge-1.2.0.jar;C:\EnsureSmart\web\modules\scripting\classes;C:\EnsureSmart\web\modules\scripting\lib\m2m2-scripting-1.2.0.jar;C:\EnsureSmart\web\modules\opcda\classes;C:\EnsureSmart\web\modules\opcda\lib\j-interop-2.0.10.jar;C:\EnsureSmart\web\modules\opcda\lib\j-interopdeps-2.01.jar;C:\EnsureSmart\web\modules\opcda\lib\jcifs-1.2.19.jar;C:\EnsureSmart\web\modules\opcda\lib\m2m2-opcda-1.7.0.jar;C:\EnsureSmart\web\modules\opcda\lib\org.openscada.opc.dcom_0.7.0.201203290910.jar;C:\EnsureSmart\web\modules\opcda\lib\org.openscada.opc.lib_0.9.0.201203290910.jar;C:\EnsureSmart\web\modules\opcda\lib\org.openscada.utils_0.17.0.201203290908.jar;C:\EnsureSmart\web\modules\loggingConsole\classes;C:\EnsureSmart\web\modules\loggingConsole\lib\m2m2-loggingConsole-1.2.0.jar;C:\EnsureSmart\web\modules\asciiFile\classes;C:\EnsureSmart\web\modules\asciiFile\lib\m2m2-asciiFile-1.3.0.jar;C:\EnsureSmart\web\modules\dashboards\classes;C:\EnsureSmart\web\modules\dashboards\lib\m2m2-dashboards-3.3.1.jar;C:\EnsureSmart\web\modules\dataImport\classes;C:\EnsureSmart\web\modules\dataImport\lib\m2m2-dataImport-1.5.0.jar;C:\EnsureSmart\web\modules\serial\classes;C:\EnsureSmart\web\modules\serial\lib\m2m2-serial-1.3.0.jar;C:\EnsureSmart\web\modules\onewire\classes;C:\EnsureSmart\web\modules\onewire\lib\m2m2-onewire-1.6.0.jar;C:\EnsureSmart\web\modules\onewire\lib\OneWireAPI.jar;C:\EnsureSmart\web\modules\onewire\lib\RXTXcomm.jar;C:\EnsureSmart\web\modules\ssh\classes;C:\EnsureSmart\web\modules\ssh\lib\jsch-0.1.51.jar;C:\EnsureSmart\web\modules\ssh\lib\m2m2-ssh-1.2.0.jar;C:\EnsureSmart\web\modules\sstGlobalScripts\classes;C:\EnsureSmart\web\modules\sstGlobalScripts\lib\m2m2-sstGlobalScripts-1.6.0.jar;C:\EnsureSmart\web\modules\BACnet\classes;C:\EnsureSmart\web\modules\BACnet\lib\bacnet4j-3.2.4.jar;C:\EnsureSmart\web\modules\BACnet\lib\m2m2-BACnet-2.3.0.jar;C:\EnsureSmart\web\modules\mangoApi\classes;C:\EnsureSmart\web\modules\mangoApi\lib\apache-log4j-extras-1.2.17.jar;C:\EnsureSmart\web\modules\mangoApi\lib\m2m2-mangoApi-1.2.1.jar;C:\EnsureSmart\web\modules\modbus\classes;C:\EnsureSmart\web\modules\modbus\lib\m2m2-modbus-1.8.0.jar;C:\EnsureSmart\web\modules\modbus\lib\modbus4j-3.0.3.jar;C:\EnsureSmart\web\modules\excelReports\classes;C:\EnsureSmart\web\modules\excelReports\lib\m2m2-excelReports-1.1.2.jar;C:\EnsureSmart\web\modules\dglux\classes;C:\EnsureSmart\web\modules\dglux\lib\gentlyWEB-utils-1.1.jar;C:\EnsureSmart\web\modules\dglux\lib\JoSQL-2.2.jar;C:\EnsureSmart\web\modules\dglux\lib\m2m2-dglux-1.4.0.jar;C:\EnsureSmart\web\modules\virtualDS\classes;C:\EnsureSmart\web\modules\virtualDS\lib\m2m2-virtualDS-1.6.1.jar;C:\EnsureSmart\web\modules\scheduledEvents\classes;C:\EnsureSmart\web\modules\scheduledEvents\lib\m2m2-scheduledEvents-1.6.0.jar;C:\EnsureSmart\web\modules\jspViews\classes;C:\EnsureSmart\web\modules\jspViews\lib\m2m2-jspViews-2.2.0.jar;C:\EnsureSmart\web\modules\log4jDS\classes;C:\EnsureSmart\web\modules\log4jDS\lib\m2m2-log4jDS-1.2.0.jar;C:\EnsureSmart\web\modules\snmp\classes;C:\EnsureSmart\web\modules\snmp\lib\m2m2-snmp-1.6.0.jar;C:\EnsureSmart\web\modules\snmp\lib\SNMP4J.jar;C:\EnsureSmart\web\modules\pointLinks\classes;C:\EnsureSmart\web\modules\pointLinks\lib\m2m2-pointLinks-1.6.0.jar;C:\EnsureSmart\web\modules\sqlds\classes;C:\EnsureSmart\web\modules\sqlds\lib\m2m2-sqlds-1.7.0.jar;C:\EnsureSmart\web\modules\controlcore\classes;C:\EnsureSmart\web\modules\controlcore\lib\m2m2-controlcore-1.2.0.jar;C:\EnsureSmart\web\modules\meta\classes;C:\EnsureSmart\web\modules\meta\lib\m2m2-meta-2.3.0.jar;C:\EnsureSmart\web\modules\dnp3\classes;C:\EnsureSmart\web\modules\dnp3\lib\dnp34j.jar;C:\EnsureSmart\web\modules\dnp3\lib\m2m2-dnp3-1.7.0.jar;C:\EnsureSmart\web\modules\maintenanceEvents\classes;C:\EnsureSmart\web\modules\maintenanceEvents\lib\m2m2-maintenanceEvents-1.6.0.jar;C:\EnsureSmart\web\modules\graphicalViews\classes;C:\EnsureSmart\web\modules\graphicalViews\lib\m2m2-graphicalViews-1.7.0.jar;C:\EnsureSmart\web\modules\persistent\classes;C:\EnsureSmart\web\modules\persistent\lib\m2m2-persistent-1.7.2.jar;C:\EnsureSmart\web\modules\templateConfig\classes;C:\EnsureSmart\web\modules\templateConfig\lib\m2m2-templateConfig-1.1.0.jar;C:\EnsureSmart\web\modules\internal\classes;C:\EnsureSmart\web\modules\internal\lib\m2m2-internal-1.6.2.jar;C:\EnsureSmart\web\modules\http\classes;C:\EnsureSmart\web\modules\http\lib\m2m2-http-1.6.2.jar;C:\EnsureSmart\web\modules\log4JReset\classes;C:\EnsureSmart\web\modules\log4JReset\lib\m2m2-log4JReset-1.2.0.jar;C:\EnsureSmart\web\modules\reports\classes;C:\EnsureSmart\web\modules\reports\lib\m2m2-reports-2.3.2.jar;C:\EnsureSmart\web\modules\dataFile\classes;C:\EnsureSmart\web\modules\dataFile\lib\jaxb-api.jar;C:\EnsureSmart\web\modules\dataFile\lib\jaxb-core.jar;C:\EnsureSmart\web\modules\dataFile\lib\jaxb-impl.jar;C:\EnsureSmart\web\modules\dataFile\lib\jaxb-jxc.jar;C:\EnsureSmart\web\modules\dataFile\lib\jaxb-xjc.jar;C:\EnsureSmart\web\modules\dataFile\lib\m2m2-dataFile-1.2.0.jar;C:\EnsureSmart\web\modules\watchlists\classes;C:\EnsureSmart\web\modules\watchlists\lib\m2m2-watchlists-1.8.0.jar
             constants.UserComment.TYPE_POINT=2
             org.directwebremoting.Container=org.directwebremoting.impl.DefaultContainer@11ab28ec
             constants.DataTypes.IMAGE=5
             org.apache.jasper.compiler.TldCache=org.apache.jasper.compiler.TldCache@286acdad
             org.springframework.web.servlet.FrameworkServlet.CONTEXT.springDispatcher=WebApplicationContext for namespace 'springDispatcher-servlet': startup date [Mon Feb 18 15:00:34 EST 2019]; parent: Root WebApplicationContext
             constants.Permissions.DataPointAccessTypes.DATA_SOURCE=3
             constants.EventType.EventTypeNames.SYSTEM=SYSTEM
             constants.SystemEventType.TYPE_PROCESS_FAILURE=PROCESS_FAILURE
             constants.AuditEventType.TYPE_DATA_POINT=DATA_POINT
             constants.SystemEventType.TYPE_MAX_ALARM_LEVEL_CHANGED=MAX_ALARM_LEVEL_CHANGED
             constants.DataTypes.NUMERIC=3
             constants.Common.NEW_ID=-1
             MiscDwr=com.serotonin.m2m2.web.dwr.MiscDwr@1c57d89a
             constants.AuditEventType.TYPE_EVENT_HANDLER=EVENT_HANDLER
            Are you restoring a backup from a previous version of Mango into a newer version? That's what it looks like. To do that, you would have to follow the instructions for doing the restore on the command line, so that Mango can follow its normal upgrade procedure during startup. The "eventDetectors" table which is missing was created in Upgrade12, which was released long ago.
            You'll want to move your existing mah2.h2.db file before doing the command line restore, for safe keeping.
