    Bacnet Event registration
    6 Posts 3 Posters 3.1k Views 3 Watching
    • R Offline
      revanreddy
      I am using Bacnet4j, I ma trying to register for event notifications ,
      please help me on this , how to implement the event enrolment for the bacnet device client
        Hi revanreddy,
        I suspect you're looking for the DevieEventListener interface: https://github.com/infiniteautomation/BACnet4J/search?q=DeviceEventListener&unscoped_q=DeviceEventListener. You need to add a listener to the DeviceEventHandler for a particular LocalDevice.
        • R Offline
          revanreddy
          I added deviceListener to LocalDevice is that enough to get events from bacnet device when some event are generated
          • A Offline
            Andreas Vogt
            Hello Guys
            I guess I have the same problem as revanreddy. The DeviceEventListener works fine for COV in datapoints like present value. But how do I get the Events/Alarms in the eventNotificationReceived
            method?
            I think, I have to set the localDevice as a receifer in the notifications class on the the remote device. Could you guys help me out with an example or test class?
            Thanks in advance!
              Hi Andreas, welcome to the forum!
              Yes, this is correct. You need to add your device as a destination in the recipientsList property on a notificationClass object. Then, on the object you wish to use that notification class to handle cases of intrinsic reporting, you set the notificationClass property on the object doing the intrinsic reporting to the object instance number of the notificationClass object you wish to use.
              You may need to try a CreateObjectRequest if the remote device doesn't have any existing notification classes.
              • A Offline
                Andreas Vogt
                Hi phil
                Meanwhile I found the "Destination" type in the type package. I could registered the LocalDevcie on my RemoteDevices at the notifications class objects.
                Now I am goning to try the intrinsic reporting as you said.
                Many thanks for your hepl!
