    Invoke shell commands from a Scripting environment?
    8 Posts 3 Posters 8.0k Views 3 Watching
      I received a question over the phone of if it were possible to invoke shell commands in an easy synchronous manner from a scripting environment. To that, I have this answer:
      Yes, it is very easy to get synchronous shell calling in a Mango JavaScript context. While we haven't added the ability to toggle this only on a per-script basis, you can have a script in Mango/bin/ext-enabled like
      nashorn-scripting.bat
      if "%1" == "init" (
              rem Set the -scripting flag for shell extensions in JavaScript environments
              set JAVAOPTS=%JAVAOPTS% -Dnashorn.args=-scripting
      nashorn-scripting.sh
      case "$1" in
          init)
              # Set the -scripting flag for shell extensions in JavaScript environments
              JAVAOPTS="$JAVAOPTS -Dnashorn.args=-scripting"
      esac
      Important to remember "init" is called on a stop, then start, but not on a restart (which calls the scripts with "restart")
      Which will give us the $EXEC option an the option to use backtick syntax, as well as several other utilities, expanded upon here: https://docs.oracle.com/javase/8/docs/technotes/guides/scripting/nashorn/shell.html or perhaps:
      https://www.google.com/search?q=nashorn+scripting+mode+extensions&oq=nashorn+scripting+mode+extensions&aqs=chrome..69i57.4663j1j7&sourceid=chrome&ie=UTF-8
      What this will enable us to do in a Mango script is:
      //Linux only, Windows may have PATH issues.
      print(`echo "Wow that's awesome!"`);
      print($EXEC('echo "Alternative syntax?!?"'));
      It would also be possible for someone to invoke command line functions without toggling on the -scripting nashorn mode, using
      //Asynchronously kick off the command
      com.serotonin.m2m2.rt.maint.work.ProcessWorkItem.queueProcess("command", timeout);
      //Synchronously kick off the command, get an object with the command and output back
      var response = com.serotonin.m2m2.rt.maint.work.ProcessWorkItem.executeProcessCommand("command", timeout);
      print( response.key );
      print( response.value );
      • MattFoxM MattFox referenced this topic on
      • Jdiaz-coJ Offline
        Jdiaz-co
        Good morning, I have tried to implement this solution in Mango v5.1.4, however, I find that this folder does not exist in your installation. Could you please tell me how to do it for that version?
          MattFox @Jdiaz-co
          @Jdiaz-co add the java opts to start-options.sh in the mango-data directory.
          The rest should be the same
          Jdiaz-coJ 1 Reply Last reply Reply Quote 0
          • Jdiaz-coJ Offline
            Jdiaz-co @MattFox
            @MattFox In the v5 installation, there are no "ext-enabled" or "ext-available" folders, so I don't know where to place the scripts you mentioned as a solution.
              MattFox @Jdiaz-co
              @Jdiaz-co I never mentioned ext enabled. Form mango4 + mango uses start-options.sh
              navigate to your mango 5 installation and there should be a mango-data directory.
              Inside there is a start options.sh file
              add JAVAOPTS="$JAVAOPTS -Dnashorn.args=-scripting" to a new line in the file.
              once you've added it, restart mango then you can use the $EXEC command
              Jdiaz-coJ 2 Replies Last reply Reply Quote 0
              • Jdiaz-coJ Offline
                Jdiaz-co @MattFox
                @MattFox said in Invoke shell commands from a Scripting environment?:
                That's what I did, however, I still can't use the exec command. In Mango v3, it works for me, but in Mango v5, it doesn't.
                • Jdiaz-coJ Offline
                  Jdiaz-co @MattFox
                  @MattFox Alright, in Mango v5, the variable should be set as follows: MA_JAVA_OPTS="$JAVAOPTS -Dnashorn.args=-scripting". Thanks for your help
                    MattFox @Jdiaz-co
                    @Jdiaz-co MA_JAVA_OPTS="$MA_JAVA_OPTS -Dnashorn.args=-scripting" will be the ticket then
                    I see they've changed it a fair bit since then, I'm not near an install right this minute to compare
