    mdp-time-picker refreshing issue
    5 Posts 2 Posters 2.2k Views 2 Watching
    • C Offline
      chrapchp
      core 3.4.5 + mangoApi 3.4.6
      Hello I'm experimenting with the mdp-time-picker where I store the light on/off times in arduino based controller as a Unix EPOCH. Works fine so far via the watch list. I have CV (current value) and SP (setpoint). I slapped together some very temporary code and everything works except when I click "test restore" all values restore accept for the HH::MM value in in the time-picker. When one drills down on it, the underlying info is updated and if I hit Ok then it gets refreshed. see attached screen shot
      not so nice HTML stuff
      <div layout="row" flex="" layout-wrap="" layout-align="space-between">
          <ma-get-point-value point-xid="DP_c373b0f5-9962-42da-8f4e-732e4928549d" point="DY_103_OFT_CV"></ma-get-point-value>
          <ma-get-point-value point-xid="DP_c5b8682a-5404-4cff-8440-71b178164cc9" point="DY_103_ONT_CV"></ma-get-point-value>
          <ma-get-point-value point-xid="DP_4de82242-f4df-4144-8d81-4657084a714a" point="DY_103_OFT_SP"></ma-get-point-value>
          <ma-get-point-value point-xid="DP_01f2db2e-2aa4-466d-a9c5-f06e4420a3cb" point="DY_103_ONT_SP"></ma-get-point-value>
          <md-card-content>
              Growing Chamber
              <div layout="column" ng-controller="lightController" ng-init="init(1535557320,1535557920)">
                  <p>{{DY_103_OFT_CV.value}} PO:{{pendingOffTime}}
                  </p>
                  <p>{{persistOffTime()}}</p>
                  <md-button ng-click="init2(DY_103_OFT_CV.value)" class="md-raised"> Test Restore</md-button>
                  <mdp-time-picker mdp-placeholder="Off Time" mdp-format="hh:mm" mdp-open-on-click mdp-auto-switch="true" ng-model="pendingOffTime"></mdp-time-picker>
                  <md-button ng-click="DY_103_OFT_SP.setValue(persistOffTime())" class="md-raised">Set to {{persistOffTime()}}</md-button>
                  <p>END GC</p>
              </div>
      userModule.js - not so nice code.
      'use strict';
      userModule.component('myComponent', {
          bindings: {
          template: '<span>Hello {{$ctrl.name}}</span>'
      // d
      userModule.controller('lightController', ['$scope', function($scope) {
        $scope.init = function(aOffTime, aOnTime)
       	$scope.currentOffTime = new Date ( aOffTime * 1000);
         $scope.pendingOffTime = new Date ( aOffTime * 1000);
      //$scope.currentOffTime = new Date(0);
      //$scope.pendingOffTime = new Date(0);
        $scope.persistOffTime = function() {  return ( $scope.pendingOffTime.valueOf() / 1000 ) }
      $scope.init2 = function( aOffTime)
      	$scope.pendingOffTime.setTime(aOffTime * 1000 );
      	//return( $scope.pendingOffTime.toLocaleTimeString() );
      //return( "co:" + aOffTime * 1000 );
      return userModule;
      }); // define
        My only thought is for you is as ngModel is used for inputs, set the value by doing
        $scope.pendingOffTime=(aOffTime * 1000);
        instead.
        Although you may need to make (aOffTime * 1000); into a moment object first...
        • C Offline
          chrapchp
          Thanks for the reply.
          I removed the need for a controller albeit at the expense of not exactly what I wanted. I was access to the mdp-time-picker as setup under under mango so I can get events. I also did no see how to include moment in my module. Tried different ways but did not work.
          I ended up with this for now.
              <md-card-content>
                  Growing Chamber
                  <div layout="column">
                      <div layout="row">
                          <mdp-time-picker mdp-placeholder="Off Time" mdp-format="hh:mm A" mdp-auto-switch="true" ng-model="offTime">
                              <p>Current Off Time: {{DY_103_OFT_CV.value * 1000 | maMoment:'format':'hh:mm A'}}</p>
                              <md-button ng-show="offTime != null" ng-click="DY_103_OFT_SP.setValue(offTime.valueOf() / 1000)" class="md-raised">Update</md-button>
                          </mdp-time-picker>
                          <mdp-time-picker mdp-placeholder="On Time" mdp-format="hh:mm A" mdp-auto-switch="true" ng-model="onTime">
                              <p>Current Off Time: {{DY_103_ONT_CV.value * 1000 | maMoment:'format':'hh:mm A'}}</p>
                              <md-button ng-show="onTime != null" ng-click="DY_103_ONT_SP.setValue(onTime.valueOf() / 1000)" class="md-raised">Update</md-button>
                          </mdp-time-picker>
                      </div>
                  </div>
            To get moment in your controller:
            Change
            To
            define(['angular', 'require','moment-timezone'], function(angular, require, moment) {
            in userModule.js
            • C Offline
              chrapchp
              Thanks. I
