    Multiple TCP Modbus Slaves
    25 Posts 3 Posters 31.2k Views 1 Watching
    • F Offline
      Fred
      Matthew,
      That should work. I think you're right in that you might have some class name confusion as people may view the slave at the device id level instead of the networking ip/port level as the new semantics are.
      Not that I think it would be a big performance hit, but with the process images backed by a hashmap keyed by slave id, you don't have to do a linear search to find the requested process image.
      I may keep my current implementation simply because my process image registry is a collection of process images keyed first by slave id and secondly by my concept of a slave configuration (allowing for more than one process image if a "spill over" process image is needed). This class is thread safe and handles the addition/removal of process images by my slave objects. That said, I think this logic could easily be moved into the ModbusSlave class where if necessary I can create my own implementation.
      So the answer to your question is yes with the reservation on the class naming as you pointed out.
      Regards,
      Fred
        Good points. The class is now called ModbusSlaveSet and has this relevant code:
            protected LinkedHashMap<Integer, ProcessImage> processImages = new LinkedHashMap<Integer, ProcessImage>();
            public void addProcessImage(ProcessImage processImage) {
                processImages.put(processImage.getSlaveId(), processImage);
            public ProcessImage getProcessImage(int slaveId) {
                return processImages.get(slaveId);
            public Collection<ProcessImage> getProcessImages() {
                return processImages.values();
        I used a LinkedHashMap in order to preserve the order in which the process images were added in case the querying order is important to the user.
        • S Offline
          skiv71
          hi, just picked up on this thread.... is this some sort of data source that gives mango the ability to listen on port xxx and accept modbus requests? thus making it a TCP slave? think i needs this :)
          Neil
            This forum is for discussions around the Modbus4J product, which is used in Mango, but otherwise no associated. It is possible to get Mango to act as a modbus slave, but not trivial. If you need this, please use the contact page to request a quote.
