    mangocli - A utility for querying Mango's REST API
    2 Posts 2 Posters 1.6k Views 2 Watching
    • A Offline
      adamlevy
      Hi all,
      Since Mango 3.3 introduces the use of JWT tokens for authentication, I decided that using the REST API is a bit more appealing. So I decided to write a little utility to make it easier to query.
      mangocli is written in Bash and uses (https://curl.haxx.se/) and jq.
      You can review the code and download it here: https://github.com/iA3io/mangocli
      This is an open source tool and you are free to use and modify it however you see fit. I hope you find it helpful.
      More information is in the README in the Git repo but here is a snippet:
      Example Usage
      Query all data points
      $ mangocli -a ./jwt-token data-points
      The default HTTP action is GET. The default host is http://localhost:8080.
      Create a new data point
      $ mangocli -a ./jwt-token -d @./new-point.json data-points
      The -d option is just the --data option for curl. The @ prefix causes
      the argument to be parsed as a file. Using the -d option changes the default
      HTTP action to POST.
      Enable and restart a data point
      $ mangocli -a ./jwt-token -u enabled=true -u restart=true PUT data-points/enable-disable/DP_XID
      Using the -u option defines a URL query parameter.
      Delete a data point.
      $ mangocli -a ./jwt-token DELETE data-points/DP_XID
      Manual
      Usage: mangocli [OPTION...] [ACTION] PATH
      Options:
        -h HOST      HOST is the domain name or IP address of the Mango server.
                     Can be set using the environment variable MANGOCLI_HOST.
                     Defaults to 'http://localhost:8080' if not specified.
                     A HOST without a specified protocol will default to HTTPS.
        -a AUTH      AUTH is the JWT token or the path to a file containing it.
                     Can be set using the environment variable MANGOCLI_AUTH
        -d DATA      DATA to include in the body of a request. Can be specified multiple times.
                     Use `-d @-' to read from stdin or `-d @filename' to read from a file.
                     Equivalent to `curl --data="DATA"'. Changes default ACTION to POST.
        -u PARAM     PARAM is URL encoded data. Can be specified multiple times.
                     Using this option will pass all data as URL parameters.
                     Use `-u @-' to read from stdin or `-u @file' to read from a file.
                     Equivalent to `curl --get --data-urlencode="PARAM"'.
        -C CURL_OPTS CURL_OPTS is a space separated list of additional options to pass to curl.
        -V VERSION   VERSION is the REST API version number: 1 or 2.
                     Can be set using the environment variable MANGOCLI_VERSION.
                     Defaults to v2.
        -c           Compact JSON output. Removes all whitespace.
        -v           Increase verbosity. Once for info, twice for debug output.
        -q           Quiet mode. Suppresses all error, info and debug messages.
                     Overrides any `-v' options.
      Arguments:
        ACTION       The HTTP action: GET, POST, PUT, DELETE
                     Defaults to GET.
        PATH         The path or route for the request
        Hi adamlevy,
        Thanks for sharing! That's really cool!
