    [SOLVED] "Failed to create authentication token: Bad Request"
    Mango feedback
    2
    3
    1.7k
    • A
      adamlevy
      Running the latest version of Mango with all modules up to date. When I go to generate a JWT token for any user I get the error message "Failed to create authentication token: Bad Request"
      Here is the corresponding error output from the logs: https://pastebin.com/XF3CbaLM
      The first line is:
      ERROR 2018-01-29T13:26:50,292 (com.serotonin.m2m2.web.mvc.rest.v1.exception.RestExceptionHandler.handleExceptionInternal:74) - Cannot deserialize value of type `java.util.Date` from String "2018-02-05T22:26:48.933Z": not a valid representation (error: Failed to parse Date value '2018-02-05T22:26:48.933Z': Unparseable date: "2018-02-05T22:26:48.933Z")
      We are running this version of java:
      $ java -version
      java version "1.8.0_131"
      Java(TM) SE Runtime Environment (build 1.8.0_131-b11)
      Java HotSpot(TM) 64-Bit Server VM (build 25.131-b11, mixed mode)
      Please let me know what additional information I can provide.
      • Jared WiltshireJ
        @adamlevy Looks like we haven't specified the defaults correctly for the date format, add this to your env.properties file and you should be fine.
        rest.customDateOutputFormat=yyyy-MM-dd'T'HH:mm:ss.SSSXXX
        rest.customDateInputFormat=yyyy-MM-dd'T'HH:mm:ss.SSSXXX
        • A
          adamlevy
          This worked for me. Thank you!
          BTW we had rest.customDateOutputFormat already specified in our env. properties file, it was just the wrong format. So the hard coded defaults are probably fine.
