    Import javascript library
    sciptingjavascript
    98 Posts 3 Posters 207.9k Views 3 Watching
    • A Offline
      arvand.owji @phildunlap
      @phildunlap said in Import javascript library:
      No. It is using the HTTP API which is over TCP/IP and all TCP/IP connections require an address and a port. Edit: yes localhost is the host if its the same machine (usually, localhost means 127.0.0.1 usually)
      ok, so im on the same machine and tried the local ip of the machine and still the samething.
      Unhandled promise rejection (rejection id: 1): Error: connect ECONNREFUSED 192.168.1.125:8443
      ami i missing something?
        Mango is not running on port 8443?
        A 1 Reply Last reply Reply Quote 0
        • A Offline
          mmm, where can i check it?
            It's the web.port property in your Mango/overrides/properties/env.properties file or Mango/classes/env.properties files as "web.port". Judging from your earlier port of the HTTP Retriever data source, it's 85, but i have no way of knowing. It's 8080 by default.
            • A Offline
              ok, web.port=8080 but i still get the same error as before.
              $node example.js
              (node:7075) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): Error: connect ECONNREFUSED 192.168.1.125:8080
                Mango is probably not running. Connection refused means the port isn't open.
                • A Offline
                  I know it does as i can login into the web admin panel.
                    Is https://192.168.1.125:8080 typed into your address bar?
                    Edit: In the end HTTP localhost 80 prevailed
                    • A Offline
                      ok, i managed to get it working on port 80 and also changing https to http.
                      Now i see only getValue function in datapoints.js. Is there any sort of setValue function available? Thanks.
                        No you would have to add it, something like,
                                static setValue(xid, valueTime) {
                                    return client.restRequest({
                                        method: 'PUT',
                                        path: '/rest/v1/point-values/' + encodeURIComponent(xid),
                                        data: {
                                          "dataType": "NUMERIC",
                                          "value": valueTime.value,
                                          "timestamp": valueTime.time,
                                          "annotation": "annotation" in valueTime ? valueTime.annotation : null
                                    }).then(response => {
                                        return response.data;
                                setValue(valueTime) {
                                    return this.constructor.setValue(this.xid, valueTime);
                        Which should work for numeric points. You would have to do something more clever to make this fully general purpose as currently the DataPoint object doesn't know its data type.
                        The node library is definitely not a finished product and anything you create is certainly encouraged to be shared.
                          Also be sure to check out test/pointValue.spec.js
                          • A Offline
                                            method: 'PUT',
                                            data: {
                            it complains about TypeError: Cannot use 'in' operator to search for 'annotation' in 2118.7704248055056
                            • A Offline
                              arvand.owji
                              this is what i am calling
                              DataPoint.setValue('DP_540483','2118.7704248055056');
                                should be more like...
                                DataPoint.setValue('DP_540483', {'value': 2118.7704248055056, 'time': new Date().getTime()});
                                • A Offline
                                  Thanks itsl working fine now on the script side. Now i have a script (named CoolpropScript.sh) that I want to schedule it to run every 2 minutes. This script runs the node js code.
                                  #! /bin/sh
                                  echo "running RunCoolprop.js"
                                  node /opt/mango/web/node-mango-client-master/RunCoolprop.js
                                  If I run the script manually it works fine and executes the RunCoolprop.js. But if I schedule the script to run using crontab i only see some (echo "running RunCoolprop.js") part of the script being executed and not the rest. Here is how i have it added to the crontab:
                                  */2 * * * * /opt/mango/web/node-mango-client-master/CoolpropScript.sh >> /opt/mango/web/node-mango-client-master/CoolpropScript.log
                                  Is there an auto timeout associated to the crontabs in the mango linux distribution? It seems the scripts timeout after few seconds...
                                    No there shouldn't be anything in the operating system getting in the way. I would advise
                                    1. Redirect stderr to your output file as well,
                                    */2 * * * * root /opt/mango/web/node-mango-client-master/CoolpropScript.sh >> /opt/mango/web/node-mango-client-master/CoolpropScript.log 2>&1
                                    1. Check dmesg output
                                      Edit:
                                    2. Add the user that's running it... how are you editing this cron?
                                    • A Offline
                                        Edit:
                                      Thats better. It seems that Node path gets messed up when the script is executed through crontab and it was complaining about not being able to find node. I added the "/usr/local/bin/node /opt/mango/web/node-mango-client-master/RunCoolprop.js" to the script and now it executes it but further down the road complains about not finding more files, Seems all the paths are screwed up.
                                        Maybe you should try adding echo $PATH; to your CoolpropScript.sh
                                        Did you add a user? If you're editing using crontab -e, you may be running them as the mango user and may have various file permission issues to tackle. If you place them with a user specified in the /etc/cron.d directory you may have more luck.
