    Problems using the new v3 authentication
    7 Posts 3 Posters 4.2k Views 3 Watching
    • H Offline
      hrivers
      I'm trying to implement the new login as described in https://help.infiniteautomation.com/mango-rest-api-authentication/ but I keep getting a response of 401 Unauthorized. admin/admin is a valid login at the address provided in CURLOPT_URL, and $_SESSION['token'] is set. This is in PHP, using Mango v3.0.2, Windows 8, Chrome 57
      $token = $_SESSION['token'];
      $authentication = array();
      $authentication['username'] = 'admin';
      $authentication['password'] = 'admin';
      $curl = curl_init();
      $headers = array(
      	'Accept: application/json',
      	'logout: true',
      	'Cookie:XSRF-TOKEN='.$token,
      	'X-XSRF-TOKEN:'.$token
      curl_setopt_array($curl, array(
      	CURLOPT_RETURNTRANSFER => TRUE,
      	CURLOPT_VERBOSE => TRUE,
      	CURLOPT_HEADER => TRUE,
      	CURLOPT_HTTPHEADER => $headers,
      	CURLOPT_POST => TRUE,
      	CURLOPT_POSTFIELDS => json_encode($authentication),
      	CURLOPT_URL => 'http://<ip_address>:8080/rest/v2/login/'
      $response = curl_exec($curl);
        So $token contains some pre-generated random token?
        I would try and remove the logout header for starters. You may also need the content type header.
        H 2 Replies Last reply Reply Quote 0
          PS here is a demo client for Node.js you might want to look at -
          https://github.com/infiniteautomation/node-mango-client
          Its written for Mango v3.
          • H Offline
            hrivers @Jared Wiltshire
            @Jared-Wiltshire adding 'Content-Type:application/json;charset=UTF-8' and removing 'logout: true' doesn't change the response.
            $token is generated via:
            $_SESSION['token'] = bin2hex(mcrypt_create_iv(32, MCRYPT_DEV_URANDOM)); if mcrypt_create_iv exists, or
            $_SESSION['token'] = bin2hex(openssl_random_pseudo_bytes(32)); if it doesn't,
            so yes, it contains a pre-generated random token.
            H 1 Reply Last reply Reply Quote 0
            • H Offline
              This post is deleted!
              • H Offline
                hrivers @hrivers
                I got it to work with the following code:
                $authentication = '{"username":"admin","password":"admin"}';
                $headers = array(
                	'Content-Type: application/json;charset=UTF-8',
                	'Connection: keep-alive',
                	'Cache-Control: no-cache',
                	'logout: true',
                	CURLOPT_POSTFIELDS => $authentication,
                	CURLOPT_URL => 'http://<ip_address>:8080/rest/v2/login'
                  Thanks for sharing your resolution!
