    How to calculate cumulative change in value only if certain condition is true
    Scheduled Pinned Locked Moved Unsolved Scripting general Discussion
    2 Posts 2 Posters 2.8k Views 2 Watching
    • G Offline
      gourav saini
      Hi all,
      I have a process where different solvents are added to a single vessel via actuator valves. The total weight inside the vessel is captured from a load cell.
      I want to create application where total amount of each solvent added to vessel is captured.
      For that I want to log the total amount of weight increment in the vessel when the valve is open.
      But I am not able to create a meta script point where total increment in weight when valve is in open condition is captured.
        Hi gourav,
        It sounds like you want a numeric Meta point something like this...
        //valve is the boolean point controlling the valve, updating ontext, logging on change
        //total is the numeric point measuring the weight in the vessel
        if(valve.value || my.time > valve.lastValue().time) return "no value"; //we'll not be logging here... set data type exception to ignore!
        //Okay, valve just closed
        var values = valve.last(2);
        var difference = total.value - total.pointValueBefore(values[1].time).value;
        return my.vaiue + difference;
