    Chinese brand PSU_monitoring rs485 and Mango
    63 Posts 3 Posters 124.4k Views 4 Watching
      Nice! That looks like the ASCII (since it doesn't begin with HEX) payload perhaps? Maybe it would be better to just do the regex parsing on the Serial Data source points, then, if you don't have to do any of the conversion to or from hex.
      • H Offline
        hengst
        I had a little throwback....
        after i did get this response i was lost in how everything worked in Mango,
        so i thought it would be good to start over from scratch.
        also i changed the source from "serial data source" to " tcp/ip" data source ( as that is what i need to use in the end )
        ( the PSU happens to have both options to get the information )
        that shouldn't make a big difference in the working flow of mango i think.
        i tested the commands over tcp/ip with SerialComm program to confirm and it works just like Serial.
          "Shouldn't make a big difference..."
          I wouldn't think so either. Do you still have the same setting for sending hex? You can always test the TCP/IP data source against netcat, to see what's coming out of it. Simply nc -l 9876 and point the TCP/IP data source at that machine's 9876 port.
          • H Offline
            hengst
            9876 would than be the port i use i guess ? ( which is 9999 in my case )
            • H Offline
              hengst
              This post is deleted!
              • H Offline
                hengst
                I used tcpdump , and looks like there is interaction,
                0_1477930282597_upload-66409ea6-ec39-4a22-be72-c7c7674ac23e
                • H Offline
                  hengst
                  Yes , data is incoming.
                  0_1477932713242_upload-9ffbf133-70e8-4e32-b554-235cb0fa7be4
                  now whats next ?
                  • H Offline
                    hengst
                    i know i have to get the values out of the returned Hex, with some ( java? ) code
                    ( in the script like in the second post probably ).
                    how does such code typical looks like.
                    get states of modules :
                    returned code :
                    7e30323030303134323030303032373432353641334437424543434343434430303030303030303345393939393941303030303030303034314338303030303431433830303030303134314338303030303030303030303031 3030303145350d
                    following manuals :
                    7e3032303030313432303030303237 ( length of data )
                    3432353641334437 Bus voltage-float: D7A35642=53.66
                    4245434343434344 Battery 1 voltage
                    3030303030303030 Battery 2 voltage
                    3345393939393941 Load current
                    3030303030303030 Total module current
                    3431433830303030 Battery temperature-float: 0000c841=25
                    3431 Number of modules:
                    4338303030303031 Environment humidity
                    3431 System alarms
                    4338303030303030 Batteries and environmental alarms
                    3030 Reservation
                    3031 State of charge: 1 float charging
                    30 30 Relay alarm high byte
                    30 31 Relay alarm low byte
                    45 35 0D
                      You could get the hex for any of these by doing something like...
                      var busVoltage = /[0-9A-Fa-f]{46}([0-9A-Fa-f]{8}).*/.exec(messsage);
                      var extractedValue = busVoltage[1];
                      Using the position in the message to know where to extract them (so, after 46 characters, capture the next 8 is what that regular expression suggests). I'm not sure what the float encoding is (how does D7A35642=53.66?), so I can't really offer too much help there. Some people are talking about a hex to float function here: http://stackoverflow.com/questions/5055723/converting-hexadecimal-to-float-in-javascript
                      It looks like you're working with the ASCII encoded values again, so while you're playing with the script check out the output of
                      function toASCII(message) {
                        var result = "";
                        while(message.length > 1) { //parse two characters at a time
                           var charCode = message.substr(0, 2);
                           result += String.fromCharCode( "0x" + charCode );
                           message = message.substr(2);
                        return result;
                      print( toASCII(message) );
                      In case that's useful.
                      • H Offline
                        hengst
                        yes, that float things is special, i figured out is has something do do with "reversed"
                        http://www.scadacore.com/field-applications/programming-calculators/online-hex-converter/
                        0_1477943857945_upload-c4d36cfd-0296-4615-a6f7-003b8e3aeca9
                        • H Offline
                          hengst
                          pffff, drives me crazy. putting pieces of code in the script only complains about no variable set and stuff and i don t know in what order and place to put the code.
                          so,
                          now i started again from scratch. but same settings do not get any data anymore.
                          ( i see it coming in tcpdump )
                          only in terminal i see :
                          0_1477950904238_upload-a6654fa3-ebf8-4b5f-bc3d-4eccf1b5b37b
                          removing everything. start from beginning. same result. this happened me twice now.
                          rebooting..
                            Perhaps the device holds open the connection and your timeout is set to 0? I would give it a try with a 1000ms timeout or so.
                            • H Offline
                              hengst
                              Nope, reboot did not help, rebooting device and connections did not help.
                              settings :
                              0_1477951949659_upload-8a4e25f9-e204-4559-9642-7b9b6c0784e3
                              0_1477952027989_upload-9a895995-1c71-4f83-831c-8f67c82813f5
                                Your value index is wrong. It should be 0. and your value regex can just be .*
                                • H Offline
                                  hengst
                                  i removed everything and restarted Mango.
                                  The "value index: set to 1 was indeed the bottleneck. ( i checked to see what difference 0 or 1 made.
                                  so i have data again,
                                  The errors
                                  WARN 2016-10-31 23:57:49,316 (com.serotonin.m2m2.rt.dataSource.PollingDataSource$2.execute:228) - PSU-tcp_ip: poll scheduled at 2016/10/31 23:57:49.316 aborted because Task Currently Runnining
                                  in terminal are still there do.
                                  i don t care at the moment, as getting things running is more important to me at the moment.
                                  now i start building COMMAND and RESPONSE from the beginning of the forum..
                                    I mentioned how to fix that, you would turn your timeout down from 50000 ms to less than your polling interval, so less than 5000.
                                    • H Offline
                                      hengst
                                      That fixed it indeed.
                                      i noticed i can check scripting code by clicking on the "little green Script dot".
                                      Its still not clear to me.
                                      • Data source collects makes connection to device. ( interval for set here )
                                        that is the easy part,
                                      • tcp/ip Data point asks for data ( command data point )
                                      • tcp/ip Data point response listen for data
                                      • tcp/ip Data point "link" this to Scripting data point, "message queue" datapoint.
                                      • in the "link" script screen i put in ?? which pieces of code ?
                                      • in the Script Data source i also put in which pieces ?
                                      i tried a lot of combinations, but i don t see it.
                                        Response --> Point Link to parse values --> Scripting Data Source to process message queue into points' values
                                        • H Offline
                                          hengst
                                          Alright i got it. thnx.
                                          i had little play with :
                                          var busVoltage = /[0-9A-Fa-f]{46}([0-9A-Fa-f]{8}).*/.exec(source.value);
                                          print (busVoltage[1]);
                                          Script result:
                                          42453939
                                          so that works, i found code for converting the hex to float, but no knowledge of writing (java) coding structure is a show stopper at the moment. but i do have fun learning , gehehe
                                            Nice!
                                            All the scripts use JavaScript.
