    Angular JS AMcharts Theme
    9 Posts 3 Posters 5.7k Views 3 Watching
    • A Offline
      atkins.chrisw
      How do i set the theme? I am trying to get the borders and the ValueAxes to be the color white. Here is what I have tried.
      options="{ {'theme': 'dark'}, chartScrollbar:{'enabled': true, 'scrollbarHeight': 5}, export: {'position': 'bottom-right'}, valueAxes: [{'id': 'ValueAxis-1','color': '#FFFFFF'}]}"
        Jared may be able to answer better than I, but there is no key to the first item in your object, which could be a problem.
          As Phillip said your syntax is incorrect, it should be
          options="{theme: 'dark', chartScrollbar:{'enabled': true, 'scrollbarHeight': 5}, export: {'position': 'bottom-right'}, valueAxes: [{'id': 'ValueAxis-1','color': '#FFFFFF'}]}"
          • A Offline
            atkins.chrisw
            I tried that too. It does not like it.
            I'm wondering if it has to do with this being in the main div section of the am-charts creation.
              OK so you need to load the amCharts theme file in your app.js, at the top of app.js add
              'amcharts/themes/dark'
              To the end of the define([]) array.
              • A Offline
                atkins.chrisw
                Will this work the same way to make an area chart? Can I load that in the app.js too?
                  I'm not sure what exactly you mean. An area chart is created by setting the fillAlphas property of a "graph" in amCharts. You can't currently do this through our directives without making the graph stacked.
                  What you could do is make a modification to serialChart.js like such:
                  function defaultLineGraph() {
                      return {
                          fillAlphas: 0.01, // set this to 0.01
                          lineAlpha: 0.8,
                          lineThickness: 2.0
                  Then play with the CSS to set the opacity of individual graphs, e.g. -
                      .amcharts-graph-series-1 .amcharts-graph-fill {
                          fill-opacity: 0.5;
                          fill: red;
                  I will make it easier to set these properties on individual graphs in the next release of the dashboards module.
                  • A Offline
                    atkins.chrisw
                    Is there a way I can make a new ma-gauge-chart2 that will look at a new serialchart.js that way I can basically make a chart type for each one?
                      Jared Wiltshire @atkins.chrisw
                      @atkins.chrisw
                      Sure you can definitely do this by defining a new angular directive, however helping you with this is outside of the scope of the forum's free support. I would suggest looking at the way that the menu directives are loaded in the adminTemplate.
