    Modbu4J, Help for read register
    7 Posts 2 Posters 6.9k Views 1 Watching
    • F Offline
      fabou3377
      thanks for your library.. Have you an sample to read a marker (word) in a plc?
      • F Offline
        fabou3377
        Here my code:
           public static void main(String[] args) {
                    ModbusFactory m = new ModbusFactory();
                    IpParameters ip = new IpParameters();
                    ip.setHost("127.0.0.1");
                    ip.setPort(502);
                    ModbusMaster mp = m.createTcpMaster(ip, false);
                try {
                    mp.init();
                    ModbusRequest req = new ReadInputRegistersRequest(1, 0, 1);
                    ReadInputRegistersResponse rep = (ReadInputRegistersResponse) mp.send(req);
                    System.out.println(rep.getData());
                } catch (Exception ex) {
                    Logger.getLogger(Main.class.getName()).log(Level.SEVERE, null, ex);
        I've this exception:
        Exception in thread "main" java.lang.NoSuchMethodError: com.serotonin.io.messaging.StreamTransport.<init>(Ljava/io/InputStream;Ljava/io/OutputStream;)V
                at com.serotonin.modbus4j.ip.tcp.TcpMaster.openConnection(TcpMaster.java:113)
                at com.serotonin.modbus4j.ip.tcp.TcpMaster.send(TcpMaster.java:62)
                at javaapplication6.Main.main(Main.java:45)
        Thanks for your furture help
          Is seroUtils.jar in your classpath?
          • F Offline
            fabou3377
            Ok its works..
            my code :
                        ip.setHost("192.168.10.2");
                        ip.setPort(502);
                        ModbusMaster mp = m.createUdpMaster(ip);
                    try {
                        mp.init();
                        ModbusRequest req = new WriteRegisterRequest(1,0,1800);
                        mp.send(req);
                        ModbusRequest req2 = new ReadHoldingRegistersRequest(1,0,1);
                        ReadResponse rep = (ReadResponse) mp.send(req2);
                        System.out.println(rep.getShortData()[0]);
            in my classpath:
            axis.jar
            bacnet.jar
            modbus4j.jar
            RTXXcomm.jar
            serioUtil.jar
            All this library are necessary?
            It's not possible to get direct the value short double string? In the good typage?
            Thanks four your help and for your job, it's great and its works under windows and linux, before I've tried UDP under linux with jamod and there is serious problems..
            It's should be very interessant if the necessary library are of sourceforge.net..
            For the novice, a little tutorial should be nice..
              You shouldn't need bacnet.jar and axis.jar. And if you're using UDP you shouldn't need RXTX either.
              Regarding your code, you should be able to simplify it a bit. ModbusMaster has a number of "getValue" and "setValue" convenience methods. For example, here's something you could do:
               // Define the point locator.
              ModbusLocator loc = new ModbusLocator(1, RegisterRange.HOLDING_REGISTER, 0, DataType.TWO_BYTE_INT_UNSIGNED);
              // Set the point value
              master.setValue(loc, 1800);
              // Get the point value
              System.out.println(master.getValue(loc));
              • F Offline
                fabou3377
                Thanks!
