    M-Bus Protocol?
    13 Posts 4 Posters 17.8k Views 1 Watching
    • A Offline
      apl
      interested in the M-Bus protocol http://www.m-bus.com ?
      I have a M-Bus parser (and plan to develop) the writer for m-bus.
      So my question is do this as a separate module on sf.net or here?
      Arne
        Hi Arne,
        We have a number of priorities that we are working on, but if you have a protocol implementation already, it might be worth looking into.
        • A Offline
          apl
          I've got time.
          And I think I will do it in the next half year...
          I will download the mango sources and start to play with it.
          Arne
            That's what we like to hear! :)
            • Z Offline
              zumiani
              You'll probably be interested in one of our devices: Mbus-to-Modbus gateway.
              It read values from one or more Mbus devices and put that values on modbus registers, all automatically done at regular intervals.
              You can find more info at http://www.marcomweb.it/InfoProdotti/94.aspx
              Hope this help.
                Thanks, but Arne already came through. He contributed an mbus data source a while ago.
                • Z Offline
                  zumiani
                  Ah ok, communicate directly using Mbus protocol surely is the better solution.
                  I've installed Mango software but I haven't find Mbus datasource..
                  Is there an additional tool to install or is it a commercial datasource?
                  Thankyou for your help
                  • A Offline
                    apl
                    There is a switch somewhere (I can't remember),
                    curently I'm implementing communication via TCP/IP and secondary addressing (Project homepage is http://mbus4j.sf.net).
                    I think that I will release this early next year.
                    Arne
                      Click on the SQL menu item, and then enter this:
                      insert into systemSettings (settingName, settingValue) values ('M_BUS.display', 'Y')
                      You should then see the data source in the list.
                      Arne, please let me know when you believe this to be ready to be enabled by default.
                      • U Offline
                        uantero
                        Hello.
                        In the last version of Mango, the MBus driver seems to work fine (is able to search the MBus devices in the network), but when trying to add points... it indicates that "No contextual field found for key address", and won't add the point.
                        Am I missing something there?
                        Thanks in advance.
                        • A Offline
                          apl
                          It is a bug in the code some constraints are not met and the errorhandling in the jsp goes astray....
                          I did some enhancements (TCP|IP and secondary addressing) but the code is not released yet ... It mostly depends on the next version of mango, if there will be a version 1.12 it will be fast, if the next version is 2.0 it will take some time ...
                          Arne
                          • Z Offline
                            zumiani
                            @apl: There is already 1.12 version :) You are late!
