    Modbus4J 2.0.2. Problems with the listener and the threads.
    2 Posts 1 Posters 3.0k Views 1 Watching
    • ramonhlR Offline
      ramonhl
      Hello.
      I am testing the ListeterTest2.java and works fine.
      public class ListenerTest2Mon1 {
          static Random random = new Random();
          static float ir1Value = -100;
              ModbusFactory modbusFactory = new ModbusFactory();
              final ModbusSlaveSet listener = modbusFactory.createTcpSlave(false);
              listener.addProcessImage(getModscanProcessImage(127));
              // When the "listener" is started it will use the current thread to run. So, if an exception is not thrown
              // (and we hope it won't be), the method call will not return. Therefore, we start the listener in a separate
              // thread so that we can use this thread to modify the values.
              new Thread(new Runnable() {
                  public void run() {
                      try {
                          listener.start();
                      catch (ModbusInitException e) {
                          e.printStackTrace();
              }).start();
              while (true) {
                  updateProcessImage1((BasicProcessImage) listener.getProcessImage(127));
                  synchronized (listener) {
                      listener.wait(100);
          static void updateProcessImage1(BasicProcessImage processImage) {
              processImage.setNumeric(RegisterRange.HOLDING_REGISTER, 0, DataType.TWO_BYTE_INT_UNSIGNED,
                      random.nextInt(10000));
              processImage.setNumeric(RegisterRange.HOLDING_REGISTER, 2, DataType.FOUR_BYTE_INT_UNSIGNED_SWAPPED,
              processImage.setNumeric(RegisterRange.HOLDING_REGISTER, 10, DataType.TWO_BYTE_INT_UNSIGNED,
              processImage.setNumeric(RegisterRange.HOLDING_REGISTER, 12, DataType.FOUR_BYTE_INT_UNSIGNED_SWAPPED,
              processImage.setNumeric(RegisterRange.HOLDING_REGISTER, 20, DataType.TWO_BYTE_INT_UNSIGNED,
              processImage.setNumeric(RegisterRange.HOLDING_REGISTER, 22, DataType.FOUR_BYTE_INT_UNSIGNED_SWAPPED,
              static BasicProcessImage getModscanProcessImage(int slaveId) {
              BasicProcessImage processImage = new BasicProcessImage(slaveId);
              processImage.setAllowInvalidAddress(true);
              processImage.setInvalidAddressValue(Short.MIN_VALUE);
              processImage.setExceptionStatus((byte) 151);
              return processImage;
      But when I try to insert this code in my java program I have problems with the threads.
      I do:
      • Change the code of the listener test and create a new class.
      • In java I have a jframe with two buttons, start server, stop server.
      • In the jframe I create a new instance of my listener class.
      • In the start button I start using my class the listener.start().
      • The start button freezes, if I debug in the listener.start() the code stops.
      Do you have some example with listener in jframe or similar?
      Thanks in advance.
      Best regards.
