Modbus4J. ListenerTest (TCP). java.net.BindException
Hello.
I am testing the ListenerTest.java in Linux computer and Eclipse 4.3.2
The code is the next:package com.ramonahl.test; import java.util.Random; import com.serotonin.modbus4j.BasicProcessImage; import com.serotonin.modbus4j.ModbusFactory; import com.serotonin.modbus4j.ModbusSlaveSet; import com.serotonin.modbus4j.ProcessImage; import com.serotonin.modbus4j.ProcessImageListener; import com.serotonin.modbus4j.code.DataType; import com.serotonin.modbus4j.code.RegisterRange; import com.serotonin.modbus4j.exception.IllegalDataAddressException; import com.serotonin.modbus4j.exception.ModbusInitException; import com.serotonin.modbus4j.ip.IpParameters; public class ListenerTest { static Random random = new Random(); static float ir1Value = -100; public static void main(String[] args) throws Exception { // SerialParameters params = new SerialParameters(); // params.setCommPortId("COM1"); // params.setPortOwnerName("dufus"); // params.setBaudRate(9600); IpParameters params = new IpParameters(); String host = "127.0.0.1"; params.setHost(host ); ModbusFactory modbusFactory = new ModbusFactory(); // ModbusListener listener = modbusFactory.createRtuListener(processImage, 31, params, false); // ModbusListener listener = modbusFactory.createAsciiListener(processImage, 31, params); final ModbusSlaveSet listener = modbusFactory.createTcpSlave(false); // ModbusSlave listener = modbusFactory.createUdpSlave(processImage, 31); // Add a few slave process images to the listener. listener.addProcessImage(getModscanProcessImage(2)); listener.addProcessImage(getModscanProcessImage(3)); listener.addProcessImage(getModscanProcessImage(5)); listener.addProcessImage(getModscanProcessImage(9)); // When the "listener" is started it will use the current thread to run. So, if an exception is not thrown // (and we hope it won't be), the method call will not return. Therefore, we start the listener in a separate // thread so that we can use this thread to modify the values. new Thread(new Runnable() { public void run() { try { listener.start(); } catch (ModbusInitException e) { e.printStackTrace(); } } }).start(); while (true) { synchronized (listener) { listener.wait(200); } for (ProcessImage processImage : listener.getProcessImages()) updateProcessImage((BasicProcessImage) processImage); } } static void updateProcessImage(BasicProcessImage processImage) throws IllegalDataAddressException { processImage.setInput(10, !processImage.getInput(10)); processImage.setInput(13, !processImage.getInput(13)); processImage.setInputRegister(20, DataType.FOUR_BYTE_FLOAT, ir1Value += 0.01); short hr1Value = ((Number) processImage.getHoldingRegister(80, DataType.TWO_BYTE_BCD)).shortValue(); processImage.setHoldingRegister(80, DataType.TWO_BYTE_BCD, hr1Value + 1); } static class BasicProcessImageListener implements ProcessImageListener { public void coilWrite(int offset, boolean oldValue, boolean newValue) { System.out.println("Coil at " + offset + " was set from " + oldValue + " to " + newValue); } public void holdingRegisterWrite(int offset, short oldValue, short newValue) { System.out.println("HR at " + offset + " was set from " + oldValue + " to " + newValue); } } static BasicProcessImage getModscanProcessImage(int slaveId) { BasicProcessImage processImage = new BasicProcessImage(slaveId); processImage.setAllowInvalidAddress(false); processImage.setInvalidAddressValue(Short.MIN_VALUE); processImage.setCoil(10, true); processImage.setCoil(11, false); processImage.setCoil(12, true); processImage.setCoil(13, true); processImage.setCoil(14, false); processImage.setInput(10, false); processImage.setInput(11, false); processImage.setInput(12, true); processImage.setInput(13, false); processImage.setInput(14, true); processImage.setBinary(16, true); processImage.setBinary(10016, true); processImage.setHoldingRegister(10, (short) 1); processImage.setHoldingRegister(11, (short) 10); processImage.setHoldingRegister(12, (short) 100); processImage.setHoldingRegister(13, (short) 1000); processImage.setHoldingRegister(14, (short) 10000); processImage.setInputRegister(10, (short) 10000); processImage.setInputRegister(11, (short) 1000); processImage.setInputRegister(12, (short) 100); processImage.setInputRegister(13, (short) 10); processImage.setInputRegister(14, (short) 1); processImage.setBit(RegisterRange.HOLDING_REGISTER, 15, 0, true); processImage.setBit(RegisterRange.HOLDING_REGISTER, 15, 3, true); processImage.setBit(RegisterRange.HOLDING_REGISTER, 15, 7, true); processImage.setBit(RegisterRange.HOLDING_REGISTER, 15, 8, true); processImage.setBit(RegisterRange.HOLDING_REGISTER, 15, 14, true); processImage.setBit(RegisterRange.INPUT_REGISTER, 15, 0, true); processImage.setBit(RegisterRange.INPUT_REGISTER, 15, 7, true); processImage.setBit(RegisterRange.INPUT_REGISTER, 15, 8, true); processImage.setBit(RegisterRange.INPUT_REGISTER, 15, 15, true); processImage.setRegister(RegisterRange.HOLDING_REGISTER, 16, DataType.TWO_BYTE_INT_SIGNED, new Integer(-1968)); processImage.setRegister(RegisterRange.HOLDING_REGISTER, 17, DataType.FOUR_BYTE_INT_SIGNED, new Long(-123456789)); processImage.setRegister(RegisterRange.HOLDING_REGISTER, 19, DataType.FOUR_BYTE_INT_SIGNED_SWAPPED, new Long( -123456789)); processImage.setRegister(RegisterRange.HOLDING_REGISTER, 21, DataType.FOUR_BYTE_FLOAT, new Float(1968.1968)); processImage.setRegister(RegisterRange.HOLDING_REGISTER, 23, DataType.EIGHT_BYTE_INT_SIGNED, new Long( -123456789)); processImage.setRegister(RegisterRange.HOLDING_REGISTER, 27, DataType.EIGHT_BYTE_INT_SIGNED_SWAPPED, new Long( -123456789)); processImage.setRegister(RegisterRange.HOLDING_REGISTER, 31, DataType.EIGHT_BYTE_FLOAT, new Double(1968.1968)); processImage.setRegister(RegisterRange.HOLDING_REGISTER, 80, DataType.TWO_BYTE_BCD, new Short((short) 1234)); processImage.setRegister(RegisterRange.HOLDING_REGISTER, 81, DataType.FOUR_BYTE_BCD, new Integer(12345678)); processImage.setRegister(RegisterRange.HOLDING_REGISTER, 12288, DataType.FOUR_BYTE_FLOAT_SWAPPED, new Float( 1968.1968)); processImage.setRegister(RegisterRange.HOLDING_REGISTER, 12290, DataType.FOUR_BYTE_FLOAT_SWAPPED, new Float( -1968.1968)); processImage.setRegister(RegisterRange.INPUT_REGISTER, 16, DataType.TWO_BYTE_INT_UNSIGNED, new Integer(0xfff0)); processImage.setRegister(RegisterRange.INPUT_REGISTER, 17, DataType.FOUR_BYTE_INT_UNSIGNED, new Long(-123456789)); processImage.setRegister(RegisterRange.INPUT_REGISTER, 19, DataType.FOUR_BYTE_INT_UNSIGNED_SWAPPED, new Long( -123456789)); processImage.setRegister(RegisterRange.INPUT_REGISTER, 21, DataType.FOUR_BYTE_FLOAT_SWAPPED, new Float( 1968.1968)); processImage.setRegister(RegisterRange.INPUT_REGISTER, 23, DataType.EIGHT_BYTE_INT_UNSIGNED, new Long( -123456789)); processImage.setRegister(RegisterRange.INPUT_REGISTER, 27, DataType.EIGHT_BYTE_INT_UNSIGNED_SWAPPED, new Long( -123456789)); processImage.setRegister(RegisterRange.INPUT_REGISTER, 31, DataType.EIGHT_BYTE_FLOAT_SWAPPED, new Double( 1968.1968)); processImage.setRegister(RegisterRange.HOLDING_REGISTER, 50, DataType.EIGHT_BYTE_INT_UNSIGNED, 0); processImage.setExceptionStatus((byte) 151); // Add an image listener. processImage.addListener(new BasicProcessImageListener()); return processImage; } }But when I run the code I can see the next error:
com.serotonin.modbus4j.exception.ModbusInitException: java.net.BindException: Permiso denegado
at com.serotonin.modbus4j.ip.tcp.TcpSlave.start(TcpSlave.java:57)
at com.ramonahl.test.ListenerTest$1.run(ListenerTest.java:48)
at java.lang.Thread.run(Thread.java:744)
Caused by: java.net.BindException: Permiso denegado
at java.net.PlainSocketImpl.socketBind(Native Method)
at java.net.AbstractPlainSocketImpl.bind(AbstractPlainSocketImpl.java:376)
at java.net.ServerSocket.bind(ServerSocket.java:376)
at java.net.ServerSocket.<init>(ServerSocket.java:237)
at java.net.ServerSocket.<init>(ServerSocket.java:128)
at com.serotonin.modbus4j.ip.tcp.TcpSlave.start(TcpSlave.java:47)
... 2 moreDo you know How Can I solve this error?
Thanks in advance.
On linux operating systems you must have the proper privileges to access ports below 1024. Modbus defaults to port 502.
Thanks for the information.
If I execute Eclipse using the sudo command (administrator) I can run the ListenerTest.See you
