    NullPointerException when trying to create RTU or ASCII Slave
    3 Posts 1 Posters 3.8k Views 1 Watching
    • R Offline
      rstoeck
      We are trying to see if Modbus4J will work in our upcoming product. We are making a slave (server) application.
      I can get the TCP slave to work just fine, but when I try to create an RTU or ASCII slave, I get a NullPointerException immediately after calling ModbusSlaveSet start() method.
      Here's the code:
      public static void main(final String[] args)
          throws Exception
          ModbusSlaveSet listener;
          boolean tcp = false;  // TCP works, but RTU and ASCII do not
          final ModbusFactory modbusFactory = new ModbusFactory();
          if (tcp)
              listener = modbusFactory.createTcpSlave(false);
          else
              final SerialParameters serialParams = new SerialParameters();
              serialParams.setCommPortId("/dev/ttyUSB0");
              serialParams.setBaudRate(9600);
              serialParams.setDataBits(8);
              serialParams.setStopBits(1);
              serialParams.setParity(2);
              listener = modbusFactory.createRtuSlave(serialParams);
          final BasicProcessImage processImage = new BasicProcessImage(1);
          processImage.setAllowInvalidAddress(true);
          processImage.setInvalidAddressValue((short)0);
          listener.addProcessImage(processImage);
          new Thread(new Runnable()
              public void run()
                  try
                      listener.start();
                  catch (ModbusInitException e)
                      e.printStackTrace();
          }).start();
      Here's the output:
      Stable Library
      Native lib Version = RXTX-2.1-7
      Java lib Version   = RXTX-2.1-7
      RXTX Warning:  Removing stale lock file. /var/lock/LCK..ttyUSB0
      com.serotonin.modbus4j.exception.ModbusInitException: java.lang.NullPointerException
      	at com.serotonin.modbus4j.serial.SerialSlave.start(SerialSlave.java:31)
      	at com.serotonin.modbus4j.serial.rtu.RtuSlave.start(RtuSlave.java:23)
      	at com.prozesstech.spectron.sandbox.Modbus4JTest$1.run(Modbus4JTest.java:103)
      	at java.lang.Thread.run(Thread.java:744)
      Caused by: java.lang.NullPointerException
      	at com.serotonin.messaging.StreamTransport.start(StreamTransport.java:32)
      	at com.serotonin.modbus4j.serial.SerialSlave.start(SerialSlave.java:28)
      	... 3 more
      Any idea what might be going on?
      -Rob
      • R Offline
        rstoeck
        Adding to this discussion: the listener.start() calls into RtuSlave.start(), which immediately calls SerialSlave.start():
        in SerialSlave:
            @Override
            public void start() throws ModbusInitException {
                try {
                    serialPort = SerialUtils.openSerialPort(serialParameters);
                    transport = new StreamTransport(serialPort.getInputStream(), serialPort.getOutputStream());
                    transport.start("Modbus4J SerialSlave");  // <--- This line throws the exception
                catch (Exception e) {
                    throw new ModbusInitException(e);
        The line that throws the NullPointerException is the third line, the transport.start("Modbus4J SerialSlave").
        This calls into the StreamTransport class of seroUtils.jar, which we do not have the source code for.
        Would it be possible for me to get this source code so that I can debug this problem?
