    Udoo Quad
    6 Posts 2 Posters 6.3k Views 1 Watching
    • C Offline
      chrapchp
      I'm trying to install m2m2 core 2.1.1 on an udoo quad running ubuntu 12.04. I can run things fine on my OS X and VirtualBox running Ubuntu 12.04 just fine. On the Udoo I get the following using error in the log file. Do you have an idea of what could be causing the null pointer exception? language/local issue? I'm using oracle jdk 1.7.0_45 for ARM soft float. On the OSX, I'm using jdk1..7.0_45 and openJDK and both of them work.
      Thoughts?
      DEBUG 2014-01-05 17:06:19,686 (com.serotonin.util.properties.ReloadingProperties.checkForReload:122) - (env) Checking for updated files
      INFO 2014-01-05 17:06:19,759 (com.serotonin.util.properties.ReloadingProperties.checkForReload:142) - (env) Found updated file(s) at [/home/ubuntu/homeautomation/m2m2-core-2/classes/env.properties]. Reloading properties
      DEBUG 2014-01-05 17:06:20,018 (com.serotonin.util.properties.ReloadingProperties.checkForReload:115) - (env) In do not check period. Not rechecking
      DEBUG 2014-01-05 17:06:20,533 (com.serotonin.util.properties.ReloadingProperties.checkForReload:115) - (env) In do not check period. Not rechecking
      DEBUG 2014-01-05 17:06:20,602 (com.serotonin.util.properties.ReloadingProperties.checkForReload:115) - (env) In do not check period. Not rechecking
      DEBUG 2014-01-05 17:06:27,201 (com.serotonin.util.properties.ReloadingProperties.checkForReload:122) - (env) Checking for updated files
      DEBUG 2014-01-05 17:06:27,254 (com.serotonin.util.properties.ReloadingProperties.checkForReload:115) - (env) In do not check period. Not rechecking
      ERROR 2014-01-05 17:06:28,775 (com.serotonin.m2m2.Main.main:94) - Error during initialization
      java.lang.NullPointerException
      at com.serotonin.m2m2.Lifecycle.configureDwr(Lifecycle.java:642)
      at com.serotonin.m2m2.Lifecycle.webServerInitialize(Lifecycle.java:606)
      at com.serotonin.m2m2.Lifecycle.initialize(Lifecycle.java:175)
      at com.serotonin.m2m2.Main.main(Main.java:88)
        Does it throw this error if you try to launch Mango without any modules in your MA_Home/web/modules folder?
        • C Offline
          chrapchp
          Yes. It is a vanilla install with only the core.
            It's difficult to say with any shred of certainty...
            For most of our testing with embedded devices on ARM, we've used JDK 8 (can be found here: https://jdk8.java.net/download.html ) . It looks like it's erring on a ClassLoader, and it looked like it was in the module loading code. I would give JDK 8 a shot.
            • C Offline
              chrapchp
              I got it to work. It is nothing on your end. Long story short, the quad wireless is uber-slow and when I copied the m2m2 content from a NAS I thought everything was copied over. It looked like it was complete. Anyway, not all files where there hence the problem. The core works (started without error and can login ) on JDk 1.70_45 (soft float) and Java 6 open JDK-Armel.
              I was hoping not have to go down the JDK 8 route as there is no soft-float release from what I can see.
              pjc
