    Bug report modbus serial
    6 Posts 2 Posters 5.5k Views 1 Watching
    • A Offline
      AlexHK
      I have just created a Modbus serial data source using ttyS129, which is a symbolic link pointing to ttyR00.
      I am using Moxa NPort 5150 Ethernet Serial modules and they create virtual devices ttyR00, ttyR01, etc.
      Since RXTX seems not to enumerate them, a symbolic link is a quick workaround.
      When I create a new source the serial port indeed shows up and all is good (I can communicate).
      When I look at the list of data sources it is also all good (data_sources.shtm) and the source shows up wity ttyS129, also when I export I get it right.
      But when I click on edit, I am left with only ttyS0 and ttyS1.
      When I edit the data source, I only get ttyS00 and ttyS01 in the HTML form (data_source_edit.shtm?dsid=31)
      Exporting, deleting and reimporting with the corrected ttyS129 seems to have fixed my problem.
        Just checking, but did you put the rxtxserial into your mango/overrides folder?
        • A Offline
          AlexHK
          Hi Phil, thanks for your help.
          I did not have this, so I did it now. Not sure if I did that right, but I copied /usr/lib/jni/librxtxSerial.so to my mango/overrides folder and restarted mango.
          I also get the following in the logs:
          Stable Library
          Native lib Version = RXTX-2.2pre2
          Java lib Version = RXTX-2.1-7
          WARNING: RXTX Version mismatch
          Jar version = RXTX-2.1-7
          native lib Version = RXTX-2.2pre2
          Serial communication/modbus seems to work though, although I get the error message posted in another thread:
          'Modbus': Exception from modbus master: No recipient was found waiting for response for key com.serotonin.modbus4j.serial.SerialWaitingRoomKeyFactory$TransportSyncWaitingRoomKey@1
            How did you go about installing rxtx?
            I noticed on the rxtx website they mentioned a version mismatch is thrown by the 2.2 prerelease: http://rxtx.qbang.org/wiki/index.php/Download
            I've not experimented with 2.2 yet, as we tend to use the 2.1.7 (it is supported on a great many platforms) for systems we deploy.
            I'm not familiar with that error, but I'm guessing it can be traced to something in the configuration/setup. What are you trying to do?
            • A Offline
              AlexHK
              I've installed it using sudo apt-get install librxtx-java on Ubuntu 12.04. I am not familiar with Java unfortunately and it's infrastructure, so consider me a dumb user.
              I have a modbus serial source setup and it seems to work fine (ie. I get he frequency from the inverter).
              But it seems each time it will create the following error in the log:
              Oct 23 23:59: 'Modbus': Exception from modbus master: No recipient was found waiting for response for key com.serotonin.modbus4j.serial.SerialWaitingRoomKeyFactory$TransportSyncWaitingRoomKey@1
              UrgentOct 23 23:54: 'Modbus': Exception from modbus master: No recipient was found waiting for response for key com.serotonin.modbus4j.serial.SerialWaitingRoomKeyFactory$TransportSyncWaitingRoomKey@1
              UrgentOct 23 23:49: 'Modbus': Exception from modbus master: No recipient was found waiting for response for key com.serotonin.modbus4j.serial.SerialWaitingRoomKeyFactory$TransportSyncWaitingRoomKey@1
              UrgentOct 23 23:44: 'Modbus': Exception from modbus master: No recipient was found waiting for response for key com.serotonin.modbus4j.serial.SerialWaitingRoomKeyFactory$TransportSyncWaitingRoomKey@1
              UrgentOct 23 23:39: 'Modbus': Exception from modbus master: No recipient was found waiting for response for key com.serotonin.modbus4j.serial.SerialWaitingRoomKeyFactory$TransportSyncWaitingRoomKey@1
              UrgentOct 23 23:34: 'Modbus': Exception from modbus master: No recipient was found waiting for response for key com.serotonin.modbus4j.serial.SerialWaitingRoomKeyFactory$TransportSyncWaitingRoomKey@1
              UrgentOct 23 23:29: 'Modbus': Exception from modbus master: No recipient was found waiting for response for key com.serotonin.modbus4j.serial.SerialWaitingRoomKeyFactory$TransportSyncWaitingRoomKey@1
              UrgentOct 23 23:24: 'Modbus': Exception from modbus master: No recipient was found waiting for response for key com.serotonin.modbus4j.serial.SerialWaitingRoomKeyFactory$TransportSyncWaitingRoomKey@1
