    "maximum time" and "minimum time" syntax for Analog Statistics object in Metadata scripts
    7 Posts 2 Posters 5.3k Views 1 Watching
    • C Offline
      crutherf
      Does anyone know the proper syntax for the Analytics Object "time" functions in the metadata source in Mango 1.12.0? Does it work? When I use the following syntax, I get no error messages, but ALWAYS 0.0 as a result.
      return pxxxx.past(DAY, 30).maximum.time
      The idea is to find the time at which the maximum value occurred in the past 30 days. Any help would be appreciated
      Craig
        Try maximumTime.
        return pxxxx.past(DAY, 30).maximumTime
        • C Offline
          crutherf
          Thanks for the quick response Matt. Tried that with the same result ("Success. result=0.0"). .maximumTime, .maximumtime, .maximum_time, and .maximum.time all give that same response, but if I give a known bad (.maximum time or .time.maximum for example) I still get a script error (type errors or other).
          Confused.
          Craig
            Note that you can return the stats object from your script and click the test icon if you want to see all of the attributes that it has. No need to guess about the attribute names.
            The maximumTime attribute may be 0 if there were no values during the interval. What is the value of the "count" attribute?
            • C Offline
              crutherf
              Thanks Matt,
              That was the info I needed to figure it out. I didn't realize I could apply the "help" to drill down. I put in the following script:
              return p1164.past(HOUR, 24).help
              And got the response:
              Could not convert result "{minimum: 83.013917, minTime=1361337619432, maximum: 307.904591, maxTime=1361383219432, average: 161.63032972540182, sum: 93298.89984499985, count: 576, noData: false, realStart: 1361299318262, end: 1361385718262}" to Numeric
              So it looks like "minTime" and "maxTime" is the proper syntax (I tried this earlier, but I think I put "mintime" and "maxtime" which returns the same 0.0)
              Thanks for the help.
              Craig
                Ah, ok. There are differences in the var names between M2M and MA, and also between MA 1.x and MA 2.x.
