Navigation
    • Search
    How to send command to standard serial port
    How-To
    2
    3
    3017
    • W
      wf321 last edited by
      Dear Sir:
      1. I had a hardware(switch), direct connect to computer com1 using R485 line.
      2. I can turn the switch on/off using standard serial test code.
      3. I can also using following rxtx( same version as scadabr using) java code to turn it on/off.
      now with mango, I created modbus serial data source, and it can scan found 1 node. But when create data point,
      there is no "output" option for "Register range", so I do not know how to continue.
      would you please help me how to create data source ( modbus serial or .. ?) ,
      data point and script to turn the switch on/off ?
      Thanks a lot.
      william
      wf321@163.com
      *********************************** RXTX CODE ****************************
      import gnu.io.CommPort;
      import gnu.io.CommPortIdentifier;
      import gnu.io.SerialPort;
      import java.io.FileDescriptor;
      import java.io.IOException;
      import java.io.InputStream;
      import java.io.OutputStream;
      public static void main ( String[] args )
      connect("COM1");
      void connect ( String portName ) throws Exception
          CommPortIdentifier portIdentifier = CommPortIdentifier.getPortIdentifier(portName);
          CommPort commPort = portIdentifier.open(this.getClass().getName(),2000);
                  SerialPort serialPort = (SerialPort) commPort;
      serialPort.setSerialPortParams(4800,SerialPort.DATABITS_8,SerialPort.STOPBITS_2,SerialPort.PARITY_NONE);
                  System.out.println(serialPort.getName());
                  InputStream in = serialPort.getInputStream();
                  OutputStream out = serialPort.getOutputStream();
                  // send 8 int to control the switch
                  int len = 8;
                  int[] buffer = new int[len];
                  buffer[0] = 0x01;  // com1
                  buffer[1] = 0x05;
                  buffer[2] = 0x00;  // port 0
                  buffer[3] = 0x01;  // channel
                  buffer[4] = 0xff;  // turn the switch on , 0X00 means tuen off
                  buffer[5] = 0x00;
                  buffer[6] = 0xdd;  // check use crc16
                  buffer[7] = 0xfa;  // check use crc16
                  for (int i = 0; i < len; i++)
                      System.out.println(buffer*);
                   out.write(buffer*);
                  out.flush();
                  commPort.close();
      • M
        mlohbihler last edited by
        "output" is not a valid register range. "Input status" and "Input register" are the read-only register ranges.
