    Avoid data collisions?
    6 Posts 2 Posters 3.9k Views 1 Watching
    • J Offline
      JNIEMI
      Hi all,
      Have a new and exciting problem with M2M2 with regards to continuity of data.
      Ive got a 5 devices in a daisy chain. Controller->Power Peter->3x I/O Modules to Rs485/LAN gateway that M2M2 polls from. This should work just fine. The unit beside it doesnt have a problem.
      Now, the problem seems to be data collisions. my sampling intervals are 5 seconds and at the end of every other interval a non-zero value (lets say discharge temperatures) just cuts down to zero and then picks up to the "proper" value after the next 5 seconds.
      The baudrates of the devices are all 19200, everything is setup properly as far as I can tell.
      I dont understand why this is different than the time I did this before...any ideas?
      Jonathan
        Not sure what you mean by data collisions. Do you think this is a problem with Modbus? You're using Modbus, right? If so, you could enable I/O logging and see if that help troubleshoot the problem.
        • J Offline
          JNIEMI
          This is a pic of what Im experiencing. And its only 2 points (OD outlet and discharge temp). The other 13pts work fine.
          I dunno if this helps or not.
          Jonathan
          Attachment: download link
          • J Offline
            JNIEMI
            How do I enable I/O logging?
            Also, does the "point value may not be reliable" have anything to do with it?
            Jonathan
              You need at least 1.13.0 to do I/O logging with Modbus. Your other possibility is to set a discard low limit on the point that is > 0, but then you'll only be getting 10 second updates.
