Webcam into ScadaBR
Dear colleagues,
These last days I’ve been trying to integrate my webcam into the ScadaBR without success. I would like to know what could I do to make it work. I work with the software called WebcamXP5, which I am able to see the broadcasting though a web page (http).The code is shown below:
var height_array = new Array();
var width_array = new Array();
width_array[1] = 640;
height_array[1] = 400;
</script>
<img src="http://189.25.87.53:8080/loading.jpg" class="webcam" id="webcam1" onmousedown="PTZMouseDown1(event)" width="640" height="400" alt="Live Stream" />
currentCamera1= 1;
errorimg1= 0;
document.images.webcam1.onload = DoIt1;
document.images.webcam1.onerror = ErrorImage1;
function LoadImage1()
uniq1 = Math.random();
document.images.webcam1.src = "http://189.25.87.53:8080/cam_" + currentCamera1 + ".jpg?uniq="+uniq1;
function PTZMouseDown1(e)
var IE = document.all?true:false;
var x,y;
var myx,myy;
var myifr = document.getElementById("iframe-ptz");
tp = getElPos1();
myx = tp[0];
myy = tp[1];
if(IE){
var scrollX = document.documentElement.scrollLeft ? document.documentElement.scrollLeft : document.body.scrollLeft;
var scrollY = document.documentElement.scrollTop ? document.documentElement.scrollTop : document.body.scrollTop;
x = event.clientX - myx + scrollX;
y = event.clientY - myy + scrollY;
} else {
x = e.pageX - myx;
y = e.pageY - myy;
if ((width_array[currentCamera1] != null) && (width_array[currentCamera1] > 0)) x = Math.round((x * 400) / width_array[currentCamera1]);
if ((height_array[currentCamera1] != null) && (height_array[currentCamera1] > 0)) y = Math.round((y * 300) / height_array[currentCamera1]);
if (x > 400) x = 400;
if (y > 300) y = 300;
if (myifr != null) myifr.src = "http://189.25.87.53:8080/ptz?src=" + currentCamera1 + "&moveto_x=" + x + "&moveto_y=" + y +"";
return true;
function getElPos1()
el = document.images.webcam1;
x = el.offsetLeft;
y = el.offsetTop;
elp = el.offsetParent;
while(elp!=null)
{ x+=elp.offsetLeft;
y+=elp.offsetTop;
elp=elp.offsetParent;
return new Array(x,y);
function ErrorImage1()
errorimg1++;
if (errorimg1>3){
document.images.webcam1.onload = "";
document.images.webcam1.onerror = "";
document.images.webcam1.src = "offline.jpg";
}else{
document.images.webcam1.src = "http://189.25.87.53:8080/cam" + currentCamera1 + ".jpg?uniq="+uniq1;
function DoIt1()
errorimg1=0;
window.setTimeout("LoadImage1();", 40);
</script>Using the same code within the datasource called “http imagem” in the ScadaBR, and cheking the watchlist I can see the screen but not the image. Below the image for better understanding:
http://www.youtube.com/watch?v=vYVmoqAy1oY&feature=youtu.be
this video show how I made for put webcam into scadabr
Any help will do. Thanks!
Best regards!
ScadaBR is not supported here. I recommend you switch to Mango Automation.
How do i make download of Mango ?
sorry my bad ingles.
