    A small bug in the atomicwritefilerequest
    8 Posts 2 Posters 5.9k Views 1 Watching
      robert bouwens
      basically it works.
      but the standard says exactly when a bacneterrorexception has to be thrown:
      • negative start
      • start exceeds the filesize
      at the same time a few internal 'things' should be checked. when the device property backupAndRestoreState
      is set to preparingForBackup or preparingForRestore the the atomic read/write requests are dangerous and could deliver
      faulty results. thus throw a device configuration in progress bacnetserviceexception as written in the standard.
      	@Override
      	public AcknowledgementService handle(LocalDevice localDevice, Address from, Network network) throws BACnetException
      		AtomicReadFileAck response;
      		BACnetObject obj;
      		FileObject file;
      		try
      			// Find the file.
      			obj = localDevice.getObjectRequired(fileIdentifier);
      			if (!(obj instanceof FileObject))
      				System.out.println("File access request on an object that is not a file");
      				throw new BACnetServiceException(ErrorClass.object, ErrorCode.rejectInconsistentParameters);
      			// check for status (backup/restore)
      			BackupState bsOld = (BackupState) localDevice.getConfiguration().getProperty(
      					PropertyIdentifier.backupAndRestoreState);
      			if (bsOld.intValue() == BackupState.preparingForBackup.intValue()
      					|| bsOld.intValue() == BackupState.preparingForRestore.intValue())
      				// send error: device configuration in progress as response
      				throw new BACnetServiceException(ErrorClass.device, ErrorCode.configurationInProgress);
      			file = (FileObject) obj;
      			// Validation.
      			FileAccessMethod fileAccessMethod = (FileAccessMethod) file.getProperty(PropertyIdentifier.fileAccessMethod);
      			if (recordAccess && fileAccessMethod.equals(FileAccessMethod.streamAccess) || !recordAccess
      					&& fileAccessMethod.equals(FileAccessMethod.recordAccess))
      				throw new BACnetErrorException(getChoiceId(), ErrorClass.object, ErrorCode.invalidFileAccessMethod);
      		catch (BACnetServiceException e)
      			throw new BACnetErrorException(getChoiceId(), e);
      		if (recordAccess)
      			throw new NotImplementedException();
      		long start = fileStartPosition.longValue();
      		long length = requestedCount.longValue();
      		 * throw an exception when the following conditions are met:
      		 * - start is a negative number
      		 * - start exceeds the length of the file object
      		if (start > file.length() || start < 0)
      			throw new BACnetErrorException(getChoiceId(), ErrorClass.object, ErrorCode.invalidFileStartPosition);
      		try
      			response = new AtomicReadFileAck(new Boolean(file.length() <= start + length), fileStartPosition, file.readData(
      					start, length));
      		catch (IOException e)
      			throw new BACnetErrorException(getChoiceId(), ErrorClass.object, ErrorCode.fileAccessDenied);
      		return response;
      that's it - works nicely.
      robert
        What's "recordAccess"? It isn't defined anywhere.
          robert bouwens
          hi matt,
          sorry for being unclear:
          public class AtomicReadFileRequest extends ConfirmedRequestService
          	private static final long serialVersionUID = -279843621668191530L;
          	public static final byte TYPE_ID = 6;
          	private final ObjectIdentifier fileIdentifier;
          	private final boolean recordAccess;
          	private final SignedInteger fileStartPosition;
          	private final UnsignedInteger requestedCount;
          	public AtomicReadFileRequest(ObjectIdentifier fileIdentifier, boolean recordAccess, SignedInteger fileStartPosition,
          			UnsignedInteger requestedCount)
          		this.fileIdentifier = fileIdentifier;
          		this.recordAccess = recordAccess;
          		this.fileStartPosition = fileStartPosition;
          		this.requestedCount = requestedCount;
          the varaible is the standard member variable defined in the class.
          regards
          robert
            Ah, that explains it. The title of the post threw me off.
              Should the fileStartPosition condition not be:
                      if (start &lt; 0 || start &gt;= file.length())
              Or do you intend that if start == file.length() that a 0 result should be returned?
                robert bouwens
                hello matt,
                a zero length file should be readable without error.
                and the standard says explicitly when the file size exceeds.
                if (start < 0 || start > file.length()
                is correct when reading the spec.
                and another commercial stack shows the same behaviour with the upper mod.
                regards
                robert
                  Ok. I recall (but at the moment can't confirm) that there was some problem with this during testing of the original implementation, but i'll go with your version.
