    Null Pointer Exception in SequenceOf.write
    7 Posts 2 Posters 5.6k Views 1 Watching
    • F Offline
      Fred
      Matthew,
      I've been doing a bit of testing and I hit a NPE in SequenceOf.java.
      Here's a little background:
      I give my user the ability to add/remove sensors (analog or binary inputs) they want exposed through BACnet. So let's say I create 10 bacnet objects I add to my local device. Everything is fine. I hit my slave server with a BACnet browser and I can see everything as expected. If I delete any number of bacnet objects using removeObject on the local device and then run the scan again from my BACnet browser, I get the exception.
      Here is the full stack trace:
      java.lang.NullPointerException
      	at com.serotonin.bacnet4j.type.constructed.SequenceOf.write(SequenceOf.java:49)
      	at com.serotonin.bacnet4j.type.constructed.BaseType.write(BaseType.java:33)
      	at com.serotonin.bacnet4j.type.Encodable.writeEncodable(Encodable.java:272)
      	at com.serotonin.bacnet4j.type.constructed.ReadAccessResult$Result.write(ReadAccessResult.java:114)
      	at com.serotonin.bacnet4j.type.Encodable.write(Encodable.java:191)
      	at com.serotonin.bacnet4j.type.Encodable.writeOptional(Encodable.java:205)
      	at com.serotonin.bacnet4j.type.constructed.ReadAccessResult.write(ReadAccessResult.java:45)
      	at com.serotonin.bacnet4j.type.Encodable.write(Encodable.java:162)
      	at com.serotonin.bacnet4j.service.acknowledgement.ReadPropertyMultipleAck.write(ReadPropertyMultipleAck.java:46)
      	at com.serotonin.bacnet4j.npdu.ip.IpMessageControl.sendResponse(IpMessageControl.java:239)
      	at com.serotonin.bacnet4j.npdu.ip.IpMessageControl.access$300(IpMessageControl.java:74)
      	at com.serotonin.bacnet4j.npdu.ip.IpMessageControl$IncomingMessageExecutor.runImpl(IpMessageControl.java:536)
      	at com.serotonin.bacnet4j.npdu.ip.IpMessageControl$IncomingMessageExecutor.run(IpMessageControl.java:454)
      	at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
      	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
      	at java.lang.Thread.run(Thread.java:619)
      Regards,
      Fred
        Hi Fred,
        I made an adjustment to the SequeceOf class and checked it in. See if it works better for you now.
        • F Offline
          Fred
          Thanks Matthew, that did the trick.
          Can you share your plans on when you'll be updating the released versions of bacnet4j and modbus4j?
          Regards.
            Well, yes... I have none. Both projects are stable at the moment though. I'd say it's safe to use builds of the current code.
            • F Offline
              Fred
              Thanks Matthew,
              I did the build myself for the update you checked in for SequenceOf.java since I didn't see an updated jar file. The rest of my code is relative to the latest release published on sourceforge.
              If I can avoid it, I never like building 3rd party libraries.
              Regards,
              Fred
                If it's any consolation, the ANT scripts in the repo are what i use to create the builds, so you'll get from that exactly what you'd get from me.
