    Custom Events Table
    2 Posts 1 Posters 1.6k Views 1 Watching
    • D Offline
      diesel
      I'm want to modify the existing events table and delete a couple columns and add some formatting. Rather than starting from scratch, I'd like to take the existing eventTable.js and .html and make my own directive.
      I modified the code similar to this thread; https://forum.infiniteautomation.com/topic/3467/gauges-function-amcharts/26.
      It sort of works but Status for all is 'No RTN' and duration is 'ui.translate.instantaneous' (console shows no valid translation'.
      Below is my eventsTableMin.js. The userModule.js file has "mainModule.directive('eventsTableMin', eventsTableMin);" No changes yet to the html file.
      Any idea why this is not working correctly?
       * @copyright 2018 {@link http://infiniteautomation.com|Infinite Automation Systems, Inc.} All rights reserved.
       * @author Jared Wiltshire
      //import eventsTableMinTemplate from './eventsTableMin.html';
      //import './eventsTableMin.css';
      //import moment from 'moment-timezone';
      define(['require', 'angular', 'moment-timezone'], function (require, angular, moment) {
          'use strict';
           * @ngdoc directive
           * @name ngMango.directive:EventsTableMin
           * @restrict E
           * @description
           * `<events-table-min></events-table-min>`
           * - Displays a list of Events in a table format.
           * - Allows for filtering of events by several attributes as explained below.
           * - Can be set to query for events within a specific date range.
           * - The table includes the ability to filter and sort by alarm level and timestamp.
           * - Events can be acknowledged one at a time or a button is shown to acknowledge all events matching the query.
           * - Note in usage examples below raw string literals are wrapped in single quotes where as variable names / numbers / booleans are not.
           * - <a ui-sref="ui.examples.utilities.eventsTableMin">View Demo</a>
           * @param {number=} limit Set the initial limit of the pagination.
           * @param {number=} point-id Filter on the Id property of a point, use with `single-point="true"`.
           * @param {boolean=} single-point Set to `true` and use with point-id attribute to return events related to just a single Data Point.
           * @param {number=} event-id Filter on a specific Event Id, should return a single event.
           * @param {expression=} alarm-level Expression which should evaluate to a string. Filter on Alarm Level. Possible values are:
           *     `'NONE'`, `'INFORMATION'`, `'IMPORTANT'`, `'WARNING'`, `'URGENT'`, `'CRITICAL'`, `'LIFE_SAFETY'` or `'any'`.
           * @param {expression=} event-type Expression which should evaluate to a string. Filter on Event Type.
           *     Possible values are: `'DATA_POINT'`, `'DATA_SOURCE'`, `'SYSTEM'` or `'any'`.
           * @param {expression=} acknowledged Expression which should evaluate to a boolean or the string 'any'.
           *     Filter on whether the event has been acknowledged. Possible values are: `true`, `false` or `'any'` for either.
           * @param {string=} active-status Filter on Active Status. Possible values are: `'active'`, `'noRtn'`, `'normal'` or `'any'`.
           * @param {string=} sort Set the initial sorting column of the table. Possible values are:
           *     `'alarmLevel'`, `'activeTimestamp'`, `'message'` or `'acknowledged'`.
           *     Precede value with a negative (eg. `'-activeTimestamp'`) to reverse sorting.
           * @param {expression=} from Should evaluate to a date, moment or time-stamp. From time used for filtering by date range.
           *     Pass the value from a `<ma-date-picker>`.
           * @param {expression=} to Should evaluate to a date, moment or time-stamp. To time used for filtering by date range.
           * @param {boolean=} [date-filter=false] Turn on date filtering of events. Set value to `true` and use with from/to attribute to use.
           * @param {string=} timezone Display the timestamps in this timezone
           * @usage
           * <!-- Example Using filters on Table Attributes -->
           * <events-table-min event-type="'SYSTEM'" alarm-level="'URGENT'" acknowledged="'any'"
           * active-status="'active' date-filter="true" from="fromTime" to="toTime" limit="50"
           * sort="'-alarmLevel'"></events-table-min>
           * <!-- Example For Restricting Events to those Related to a Data Point -->
           * <events-table-min single-point="true" point-id="myPoint.id" limit="5" from="fromTime" to="toTime"></events-table-min>
          eventsTableMin.$inject = ['maEvents', 'maUserNotes', '$mdMedia', '$injector', '$sanitize', 'MA_DATE_FORMATS', 'MA_EVENT_LINK_INFO', '$timeout',
              'maEventHandler', 'maTranslate', 'maCssInjector'
          function eventsTableMin(Events, UserNotes, $mdMedia, $injector, $sanitize, mangoDateFormats, MA_EVENT_LINK_INFO, $timeout,
            EventHandler, Translate, cssInjector) {
              cssInjector.injectLink('/ui/css/eventsTableMin.css', 'eventsTableMin', '', false);
              const ANY_KEYWORD = 'any';
              class Equals {
                  constructor(value, filter) {
                      this.value = value;
                      this.filter = filter;
                  test() {
                      if (this.filter == null || this.filter === ANY_KEYWORD)
                          return true;
                      return this.testOp();
                  testOp() {
                      return this.value === this.filter;
              class EqualsIgnoreZero extends Equals {
                  test() {
                      if (this.filter === 0) return true;
                      return super.test();
              class GreaterThanEquals extends Equals {
                  testOp() {
                      return this.value >= this.filter;
              class LessThan extends Equals {
                  testOp() {
                      return this.value < this.filter;
              class InArray extends Equals {
                  testOp() {
                      return Array.isArray(this.filter) && this.filter.includes(this.value);
              class EventsTableMinController {
                  static get $$ngIsClass() {
                      return true;
                  static get $inject() {
                      return ['$scope', '$attrs', '$element', 'maEventTypeInfo'];
                  constructor($scope, $attrs, $element, EventTypeInfo) {
                      this.$scope = $scope;
                      this.$attrs = $attrs;
                      this.$element = $element;
                      this.$mdMedia = $mdMedia;
                      this.start = 0;
                      this.page = 1;
                      this.total = 0;
                      this.limit = 50;
                      this.events = [];
                      this.sort = '-activeTimestamp';
                      this.totalUnAcknowledged = 0;
                      this.linkInfo = MA_EVENT_LINK_INFO;
                      this.onPaginateBound = (...args) => this.onPaginate(...args);
                      this.onReorderBound = (...args) => this.onReorder(...args);
                      this.handlersForType = new EventTypeInfo.EventTypeMap();
                  $onInit() {
                      Events.notificationManager.subscribe((event, mangoEvent) => {
                          // temporary fix/work-around for audit events / DO_NOT_LOG events coming through websocket
                          if (mangoEvent.id < 0) {
                              return;
                          if (event.name === 'ACKNOWLEDGED' && (!this.acknowledged || this.acknowledged === ANY_KEYWORD) &&
                              this.totalUnAcknowledged > 0 && this.eventMatchesFilters(mangoEvent, true)) {
                              this.totalUnAcknowledged--;
                          if (this.eventMatchesFilters(mangoEvent)) {
                              // if event is already in current page replace it
                              this.removeEvent(mangoEvent.id, mangoEvent);
                              if (event.name === 'RAISED' && !this.dateFilter) {
                                  if (this.sort === '-activeTimestamp' && this.start === 0) {
                                      // sorted by descending time and on the first page
                                      this.events.unshift(mangoEvent);
                                  } else if (this.sort === 'activeTimestamp' && this.events.length < this.limit) {
                                      // sorted by ascending time and on the last page
                                      this.events.push(mangoEvent);
                                  // ensure that we don't have more items than items per page
                                  if (this.events.length > this.limit) {
                                      this.events.pop();
                                  this.total++;
                                  this.totalUnAcknowledged++;
                          } else {
                              // event may no longer match the filters, remove it if so
                              this.removeEvent(mangoEvent.id);
                      }, this.$scope, ['RAISED', 'ACKNOWLEDGED', 'RETURN_TO_NORMAL', 'DEACTIVATED']);
                      this.$scope.$on('maWatchdog', (event, current, previous) => {
                          if (current.status === 'LOGGED_IN') {
                              $timeout(() => {
                                  this.doQuery();
                              }, 5000);
                      // TODO update with websocket
                      EventHandler.buildQuery()
                          .limit(10000)
                          .query().then(handlers => {
                              this.handlers = handlers;
                              this.rebuildHandlersMap();
                  $onChanges(changes) {
                      const numChanges = Object.keys(changes).length;
                      // don't re-query if only the to and from changed and we are not using the date filter
                      if ((changes.from || changes.to) && !this.dateFilter) {
                          const both = changes.from && changes.to;
                          if (both && numChanges === 2 || numChanges === 1) {
                              return;
                      this.doQuery();
                  rebuildHandlersMap() {
                      this.handlersForType.clear();
                      this.handlers.forEach(handler => {
                          handler.eventTypes.forEach(et => {
                              this.handlersForType.set(et, handler);
                  baseQuery() {
                      const queryBuilder = Events.buildQuery();
                      queryBuilder.addToRql = function (propertyName, op, propertyValue) {
                          if (propertyValue != null && propertyValue !== ANY_KEYWORD) {
                              this[op](propertyName, propertyValue);
                      queryBuilder.addToRql('alarmLevel', 'eq', this.alarmLevel);
                      queryBuilder.addToRql('id', 'eq', this.eventId);
                      if (this.pointId != null && this.pointId !== ANY_KEYWORD) {
                          queryBuilder.addToRql('eventType', 'eq', 'DATA_POINT');
                          queryBuilder.addToRql('referenceId1', 'eq', this.pointId);
                      } else if (Array.isArray(this.pointIds)) {
                          queryBuilder.addToRql('referenceId1', 'in', this.pointIds);
                      } else if (this.sourceId != null && this.sourceId !== ANY_KEYWORD) {
                          queryBuilder.addToRql('eventType', 'eq', 'DATA_SOURCE');
                          queryBuilder.addToRql('referenceId1', 'eq', this.sourceId);
                      } else {
                          const {
                              eventType,
                              subType,
                              referenceId1,
                              referenceId2
                          } = this.eventTypeObject || this;
                          queryBuilder.addToRql('eventType', 'eq', eventType);
                          queryBuilder.addToRql('subtypeName', 'eq', subType);
                          if (!Number.isFinite(referenceId1) || referenceId1 > 0) {
                              queryBuilder.addToRql('referenceId1', 'eq', referenceId1);
                          if (!Number.isFinite(referenceId2) || referenceId2 > 0) {
                              queryBuilder.addToRql('referenceId2', 'eq', referenceId2);
                      if (this.activeStatus === 'active') {
                          queryBuilder.addToRql('active', 'eq', true);
                      } else if (this.activeStatus === 'noRtn') {
                          queryBuilder.addToRql('rtnApplicable', 'eq', false);
                      } else if (this.activeStatus === 'normal') {
                          queryBuilder.addToRql('active', 'eq', false);
                      if (this.dateFilter) {
                          queryBuilder.addToRql('activeTimestamp', 'ge', this.from != null && this.from.valueOf());
                          queryBuilder.addToRql('activeTimestamp', 'lt', this.to != null && this.to.valueOf());
                      return queryBuilder;
                  displayQuery() {
                      const queryBuilder = this.baseQuery();
                      queryBuilder.addToRql('acknowledged', 'eq', this.acknowledged);
                      if (this.sort === 'activeRtn') {
                          queryBuilder.sort('rtnTimestamp', 'rtnApplicable');
                      } else if (this.sort === '-activeRtn') {
                          queryBuilder.sort('-rtnTimestamp', '-rtnApplicable');
                      } else if (this.sort != null) {
                          if (Array.isArray(this.sort)) {
                              queryBuilder.sort(...this.sort);
                          } else {
                              queryBuilder.sort(this.sort);
                      if (this.limit != null) {
                          queryBuilder.limit(this.limit, this.start || 0);
                  doQuery() {
                      // dont query if element has a pointId attribute but its not defined
                      if (this.$attrs.hasOwnProperty('pointId') && this.pointId == null || this.$attrs.hasOwnProperty('sourceId') && this.sourceId == null) {
                          this.events = [];
                          this.total = 0;
                          return;
                      // cancel the previous request if its ongoing
                      if (this.queryResource) {
                          this.queryResource.$cancelRequest();
                      const rqlQuery = this.displayQuery().toString();
                      const separator = rqlQuery.length ? '&' : '';
                      this.csvUrl = `/rest/v2/events?${rqlQuery}${separator}format=csv2`;
                      this.queryResource = Events.query({
                          rqlQuery
                      this.tableQueryPromise = this.queryResource.$promise.then(data => {
                          // Set Events For Table
                          this.events = data;
                          this.total = this.events.$total;
                          if (!this.hideAckButton) {
                              this.countUnacknowledged();
                   *  Also query with limit(0) with RQLforAcknowldege to get a count of unacknowledged events to display on acknowledgeAll button
                  countUnacknowledged() {
                      if (this.countUnacknowledgedResource) {
                          this.countUnacknowledgedResource.$cancelRequest();
                      if (!this.acknowledged || this.acknowledged === ANY_KEYWORD) {
                          const rqlQuery = this.baseQuery()
                              .eq('acknowledged', false)
                              .limit(0)
                              .toString();
                          this.countUnacknowledgedResource = Events.query({
                              rqlQuery
                          }, null);
                          this.countUnacknowledgedResource.$promise.then(data => {
                              this.totalUnAcknowledged = data.$total;
                      } else {
                  addNote($event, event) {
                      return UserNotes.addNote($event, 'Event', event.id).then((note) => {
                          event.comments.push(note);
                  onPaginate(page, limit) {
                      this.start = (page - 1) * limit;
                      this.doQuery();
                  onReorder() {
                      this.doQuery();
                  parseHTML(text) {
                      return $sanitize(text);
                  formatDate(date) {
                      const m = moment(date);
                      if (this.timezone) {
                          m.tz(this.timezone);
                      return m.format(mangoDateFormats.shortDateTimeSeconds);
                  removeEvent(eventId, replacement) {
                      const index = this.events.findIndex(item => item.id === eventId);
                      if (index >= 0) {
                          let removed;
                          if (replacement) {
                              removed = this.events.splice(index, 1, replacement);
                          } else {
                              removed = this.events.splice(index, 1);
                          return removed[0];
                  // Acknowledge single event
                  acknowledgeEvent(event) {
                      const didMatchFilters = this.eventMatchesFilters(event);
                      event.$acknowledge().then(() => {
                          event.acknowledged = true;
                          if (!Events.notificationManager.socketConnected()) {
                              if (didMatchFilters && this.totalUnAcknowledged > 0) {
                              if (!this.eventMatchesFilters(event)) {
                                  this.removeEvent(event);
                  // Acknowledge multiple events
                  acknowledgeEvents(events) {
                      events.forEach((event) => {
                          this.acknowledgeEvent(event);
                  // Acknowledge all matching RQL with button
                  acknowledgeAll() {
                          .toString();
                      Events.acknowledgeViaRql({
                          rqlQuery
                      }, null).$promise.then((data) => {
                          if (data.count) {
                              // re-query
                              this.doQuery();
                  eventMatchesFilters(event, ignoreAckFilter) {
                      const tests = [];
                      if (this.$attrs.hasOwnProperty('pointId')) {
                          if (this.pointId == null) {
                              return false;
                          tests.push(new Equals(event.eventType.eventType, 'DATA_POINT'));
                      if (this.$attrs.hasOwnProperty('sourceId')) {
                          if (this.sourceId == null) {
                              return false;
                          tests.push(new Equals(event.eventType.eventType, 'DATA_SOURCE'));
                      const {
                          eventType,
                          subType,
                          referenceId1,
                          referenceId2
                      let active, rtnApplicable;
                      switch (this.activeStatus) {
                          case 'noRtn':
                              rtnApplicable = false;
                              break;
                          case 'active':
                              rtnApplicable = true;
                              active = true;
                              break;
                          case 'normal':
                              active = false;
                              break;
                      tests.push(
                          new Equals(event.eventType.eventType, eventType),
                          new Equals(event.eventType.subType, subType),
                          new EqualsIgnoreZero(event.eventType.referenceId1, referenceId1),
                          new EqualsIgnoreZero(event.eventType.referenceId2, referenceId2),
                          new Equals(event.alarmLevel, this.alarmLevel),
                          new Equals(event.active, active),
                          new Equals(event.rtnApplicable, rtnApplicable),
                          new Equals(event.eventType.referenceId1, this.pointId),
                          new Equals(event.eventType.referenceId1, this.sourceId),
                          new InArray(event.eventType.referenceId1, this.pointIds),
                          new Equals(event.id, this.eventId));
                      if (!ignoreAckFilter) {
                          tests.push(new Equals(event.acknowledged, this.acknowledged));
                          tests.push(
                              new GreaterThanEquals(event.activeTimestamp, this.from != null && this.from.valueOf()),
                              new LessThan(event.activeTimestamp, this.to != null && this.to.valueOf())
                      return tests.reduce((accum, test) => {
                          return accum && test.test();
                      }, true);
                  formatDuration(duration) {
                      if (duration < 1000) {
                          return Translate.trSync('ui.time.milliseconds', [duration]);
                      } else if (duration < 5000) {
                          return Translate.trSync('ui.time.seconds', [Math.round(duration / 100) / 10]);
                      } else if (duration < 60000) {
                          return Translate.trSync('ui.time.seconds', [Math.round(duration / 1000)]);
                      return moment.duration(duration).humanize();
              return {
                  restrict: 'E',
                  templateUrl: require.toUrl('../views/eventsTableMin.html'),
                  scope: {},
                  controller: EventsTableMinController,
                  controllerAs: '$ctrl',
                  bindToController: {
                      pointId: '<?',
                      pointIds: '<?',
                      eventId: '<?',
                      alarmLevel: '<?',
                      eventTypeObject: '<?',
                      eventType: '<?',
                      subType: '<?',
                      referenceId1: '<?',
                      referenceId2: '<?',
                      acknowledged: '<?',
                      activeStatus: '<?',
                      limit: '<?',
                      sort: '<?',
                      to: '<?',
                      dateFilter: '<?',
                      timezone: '@',
                      hideLink: '@?',
                      hideAckButton: '<?',
                      hideCsvButton: '<?',
                      sourceId: '<?'
                  designerInfo: {
                      translation: 'ui.app.eventsTableMin',
                      icon: 'alarm'
          return eventsTableMin;
      • D Offline
        diesel
        nevermind. I was using the eventsTable html and js from github, however, I should not have used files from master but from ver 3.7.x
