    JsonEmport not working for me
    4 Posts 2 Posters 2.5k Views 2 Watching
      Phillip Weeks
      I used this code before our last update to 3.6... now this returns an eof error.
      print(JsonEmport.dataPointQuery("eq(name,FAN COIL VALVE)&limit(1000)"));```
      Expected } but found eof //JsonEmport.doImport(JSON.stringify({"dataPoints": dataPoints})); ^ at line: 8, column: 90 at line: 8, column: 9
        @Phillip-Weeks
        That bug is fixed in 3.7.x I was not aware it was in the 3.6 release. I am planning another 3.6 release in the next few weeks so I'll get that fix in there. In the meantime you cannot end a script with a comment line. So adding a newline after that I think should work.
          Phillip Weeks
          Thanks no that was not in the script I added that after. This produces the same result. It is 3.6 and I will upgrade to 3.7 shortly if it fixes this. Thanks for your reply,
          var dataPoints = JSON.parse(JsonEmport.dataPointQuery("eq(name,FAN COIL VALVE)&limit(1000)")).dataPoints;
            @Phillip-Weeks I just implemented a Scripting Data source that runs this script and see no errors on Mango 3.6.6?
            var dataPoints = JSON.parse(JsonEmport.dataPointQuery("eq(name,Voltage)&limit(1000)")).dataPoints;
            print(JsonEmport.dataPointQuery("eq(name,Voltage)&limit(1000)"));
            I am searching for a point named Voltage
            Output:
            "dataPoints":[
            "xid":"voltage",
            "name":"Voltage",
            "enabled":true,
            "loggingType":"ON_CHANGE",
            "purgeType":"YEARS",
            "pointLocator":{
            "dataType":"NUMERIC",
            "changeType":{
            "type":"BROWNIAN",
            "max":100.0,
            "maxChange":0.01,
            "min":0.0,
            "startValue":"1"
            "settable":true
            "eventDetectors":null,
            "plotType":"STEP",
            "rollup":"NONE",
            "unit":"V",
            "simplifyType":"NONE",
            "chartColour":"",
            "chartRenderer":null,
            "dataSourceXid":"DS_997094",
            "defaultCacheSize":1,
            "deviceName":"Dashboard Demo",
            "discardExtremeValues":false,
            "discardHighLimit":0.0,
            "discardLowLimit":0.0,
            "intervalLoggingPeriod":15,
            "purgeOverride":false,
            "purgePeriod":1,
            "readPermission":"user",
            "setPermission":"",
            "tags":null,
            "textRenderer":{
            "type":"ANALOG",
            "useUnitAsSuffix":true,
            "format":"#.00"
            "tolerance":0.0
            The cause must be specific to your system. Perhaps that specific point is corrupt? Try another point and if that doesn't work take a look at the logs and see if anything is being output about the error.
            Thanks.
