    Monitoring water flow with alarm point
    3 Posts 3 Posters 2.7k Views 3 Watching
    • O Offline
      ORU_david
      Attached is a water flow point that I would like to add an alarm value too. I know I could set an high/low value, but the flow changes constantly. See the photo of a history snapshot. Should I go with a high/low value or maybe have an accumulated value over time to trigger an alarm? If so, I guess I need to build a point add the sum of an hour or something like that?
      • cwangvC Offline
        cwangv @ORU_david
        @oru_david
        i think you can setup an event based on Delta value.
          I think you should set up an alarm on a datapoint based upon if it exceeds an upper limit for 'n' minutes then use that to fire an event or whatever is necessary.
          However if it's a moving difference/average you require, utilise a meta datapoint with the value that calculates those differences over the last so many minutes and returns it. Attach the event handler to the meta point and you'll be away.
