    node-mango-client to update datasource properties on Mango 2.8
    Mango Automation general Discussion
    3
    8
    2.2k
    • E
      etantonio
      I want try to use node-mango-client to update some Mango 2.8 datasource properties from outside Mango user interface. Mango instance is running on a RPI3B+.
      To achieve this I've done the following:
      sudo apt install -y nodejs
      node -v
      v8.11.1
      sudo apt install npm
      npm -v
      1.4.21
      (node:4528) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
      cd /home/solergy/MANGO/NODE-JS/
      npm install mango-client --save
      (node:2363) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
      mango-client@0.4.0 node_modules/mango-client
      ├── uuid@3.1.0
      ├── moment-timezone@0.5.27
      └── moment@2.24.0
      after this I've tried this little sample:
      const MangoClient = require('mango-client');
      const client = new MangoClient({
          protocol: 'http',
          host: 'localhost',
          port: 8810,
          rejectUnauthorized: false
      const DataPoint = client.DataPoint;
      const User = client.User;
      User.login('myUsername', 'myPassword').then(data => {
          console.log(`Logged in as '${data.username}'.`);
          return DataPoint.getValue('internal_mango_num_data_points');
      }).then(data => {
          console.log(`There are ${data.value} data points.`);
          // you can perform any arbitrary rest request like this
          return client.restRequest({
              path: '/rest/v1/data-points/internal_mango_num_data_points',
              method: 'GET',
              //data: {object}
      }).then(response => {
          console.log(`The data point's name is '${response.data.name}'`);
      it is the same descripted here:
      https://github.com/infiniteautomation/node-mango-client
      but I've the following error:
      solergy@Tracker_0-1:~/MANGO/NODE-JS/node_modules/mango-client $ node example.js
      (node:4926) UnhandledPromiseRejectionWarning: SyntaxError: Unexpected token < in JSON at position 3
          at JSON.parse (<anonymous>)
          at IncomingMessage.response.on (/home/solergy/MANGO/NODE-JS/node_modules/mango-client/src/mangoClient.js:183:62)
          at emitNone (events.js:111:20)
          at IncomingMessage.emit (events.js:208:7)
          at endReadableNT (_stream_readable.js:1064:12)
          at _combinedTickCallback (internal/process/next_tick.js:138:11)
          at process._tickCallback (internal/process/next_tick.js:180:9)
      (node:4926) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
      (node:4926) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
      any idea about where's the problem?
      • Jared WiltshireJ
        I took at look at it is because the node client uses the REST V2 APIs to log in and they are not available on Mango 2.8. The actual error is because Mango 2.8 incorrectly returns the HTML error page instead of a JSON error response.
        I had a play with manually using client.restRequest() to login but that will not work either due to the CSRF protection changing.
        Otherwise this would work I would think...
        const MangoClient = require('@infinite-automation/mango-client');
            protocol: 'http',
            host: 'localhost',
            port: 8080,
        const username = 'admin';
        const password = 'admin';
            path: `/rest/v1/login/${username}`,
            method: 'POST',
            params: {password}
            const data = response.data;
        }).then(data => {
                method: 'GET',
                //data: {object}
        • E
          etantonio
          It seems there's still some problem:
          (node:3790) UnhandledPromiseRejectionWarning: Error: Mango HTTP error - 403 Forbidden
              at IncomingMessage.response.on (/home/solergy/MANGO/NODE-JS/node_modules/mango-client/src/mangoClient.js:194:35)
          (node:3790) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
          (node:3790) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
          • Jared WiltshireJ
            Jared Wiltshire @Jared Wiltshire
            @jared-wiltshire said in node-mango-client to update datasource properties on Mango 2.8:
            ^ as I said CSRF has changed since 2.8.
            • E
              etantonio
              OK, thanks anyway, I will search for a different approach to change datasource properties from outside Mango 2.8. I've tried to read the blob with the following python script:
              #!/usr/bin/python3
              import pymysql
              import json
              def write_file(data, filename):
                  with open(filename, 'wb') as f:
                      f.write(data)
              def read_blob(filename):
                  # select photo column of a specific author
                  query = "SELECT data FROM mangoTerlizzi.dataSources where xid='FML01-main'"
                  try:
                      # Open database connection
                      db = pymysql.connect("localhost","user","pwd","mangoTerlizzi" )
                      # prepare a cursor object using cursor() method
                      cursor = db.cursor()
                      # execute SQL query using execute() method.
                      cursor.execute(query)
                      # Fetch a single row using fetchone() method.
                      data = cursor.fetchone()[0]
                      # write blob data into a file
                      with open(filename) as json_file:
                        data = json.load(json_file)
                  except Error as e:
                      print(e)
                  finally:
                      cursor.close()
                      db.close()
              read_blob("datasourceDescription.json")
              but maybe it is not all the stuff, in fact I've the following error:
              solergy@Tracker_0-1:~ $ python3 dbConnection.py
              Traceback (most recent call last):
                File "dbConnection.py", line 34, in read_blob
                File "/usr/lib/python3.5/json/__init__.py", line 265, in load
                  return loads(fp.read(),
                File "/usr/lib/python3.5/codecs.py", line 321, in decode
                  (result, consumed) = self._buffer_decode(data, self.errors, final)
              UnicodeDecodeError: 'utf-8' codec can't decode byte 0xac in position 0: invalid start byte
              • E
                etantonio
                At the end I choose to use a scripting datasource to update datasource properties:
                var dsvoMain = com.serotonin.m2m2.db.dao.DataSourceDao.instance.getByXid("FML01-main");
                    dsvoMain.host = "172.16.0.12";
                    com.serotonin.m2m2.db.dao.DataSourceDao.instance.saveDataSource(dsvoMain);
                and the same for the publisher:
                var voPublisher = com.serotonin.m2m2.db.dao.PublisherDao.instance.getByXid("Pub_TRK-0.1")
                    voPublisher.port              = "8811";
                    com.serotonin.m2m2.db.dao.PublisherDao.instance.savePublisher(voPublisher);
                but I can't update instead systemSettings,
                I've tried with the following:
                com.serotonin.m2m2.db.dao.SystemSettingsDao.setValue("emailFromName", "Etantonio");
                but the result is:
                but the method seems to be there in
                https://github.com/infiniteautomation/ma-core-public/blob/2.8.x/Core/src/com/serotonin/m2m2/db/dao/SystemSettingsDao.java
                do you have an idea about where's the problem?
                And also, there's a similar way to update excelReport properties on table excelReportTemplates?
                Thanks, Antonio
                • terrypackerT
                  @etantonio it looks like you have a syntax error. The other dao classes have a static instance member to access the methods but this dao is different in Mango 2.8,
                  The method you are using is not static so you need to first get a reference to the created dao. I believe there is a DaoRegistry class you may be able to use. Just be careful and make sure you understand why some methods are static and others are not.
                  • E
                    etantonio
                    yes, you're right, the following code it's ok. thanks,
                    var ssdao = new com.serotonin.m2m2.db.dao.SystemSettingsDao();
                       ssdao.setValue("emailFromName", "Etantonio");
                    instead for excelReport:
                    var voExcelReport = com.infiniteautomation.mango.excelreports.dao.ExcelReportTemplateDao.instance.getByXid("My_DailyReport")
                    voExcelReport.setName("Etantonio")
                    com.infiniteautomation.mango.excelreports.dao.ExcelReportTemplateDao.instance.save(voExcelReport);
                    Antonio
