    Timer for Binary Switch Button
    6 Posts 2 Posters 2.7k Views 3 Watching
      Shehryar Tariq
      I am trying to add a binary switch button to my dashboard that I can turn on manually through the dashboard and after X amount of seconds it turns off automatically. I do not see any parameters where I can change these settings. Are there any functions/settings/parameters that can enable me to do this timing functionality with a toggle switch? Can I get some help on this?
      Mango Core Verison: 3.6.0
      Mango API Module Version: 3.6.0
      Mango UI Module Version: 3.6.1
      Platform: Windows 10 Pro
      Browser: Google Chrome
        Jared Wiltshire @Shehryar Tariq
        @shehryar-tariq said in Timer for Binary Switch Button:
        This is something that you should ideally do within your PLC program. If you are not using a PLC you can do it from the Mango backend using an event detector.
        The reason for this is that if you close the tab/window, or if there is some sort of communication issue the command to turn the binary point back off will not get sent.
        It is possible to do this from a dashboard, but I would not recommend it as per above.
          Shehryar Tariq
          Thank you for your response but I am not using a PLC. Can you please explain what do you mean by using backend Mango? I thought event recorder is only for getting events, I don't think it can trigger anything, can it?
          What I intend to do is that I have a toggle switch shown above, and I want it to automatically close once I manually turn it on after a certain time delay
            To be more explicit about how to do this with an event detector -
            • Add a binary state detector to your binary data point
            • Under the state tab, choose the true state and set the duration to X seconds
            • Save event detector
            • Go to event handlers page
            • Add a "Set point" event handler
            • Under the "Set point" tab choose your binary point
            • Under the "Event types" tab select your binary state event
            • Under the "Active action" tab, choose "Set to static value" and set the value to false
            • Save event handler
              The event detectors are used to monitor for certain conditions and trigger an event/alarm yes. But you can hook up event handlers to these events to perform actions.
                Something that might be useful - you can create a single event handler that you can attach to multiple event detectors.
                • Change the event handler to "Set to scripted value"
                • Add this script -
                var points = DataPointQuery.query('eq(id,' + event.referenceId1 + ')');
                points[0].runtime.set(0);
                return UNCHANGED;
                This will make the handler lookup the point which triggered the event and set that point back to zero.
