    What communication protocols do you use?
    28 Posts 15 Posters 54.6k Views 1 Watching
      Hi popeye,
      Thanks for your input. Sadly, we don't have any AB equipment in our lab, which makes the development of a protocol implementation rather sketchy (developing only from documentation is hopeful at best). If there is simulation software available, or if someone were willing to loan us some equipment (free software = no budget to buy), we should be able to get this done.
      • T Offline
        Tohotom
        Modbus (RTU, TCP),
        M-Bus
        BACnet (Ethernet, IP, MS/TP),
        LonTalk,
        IEC-60870-5-104.
          Prodyut Bora
          Clipsal (http://www.clipsal.com), a division of Schneider Electric, is into building automation. They have developed an "open standard" protocol called C-Bus (http://www.cbus-enabled.com/default.html).
          Why don't you consider adding C-Bus to your list of protocols?
          Regards
          Prodyut
            Hi Prodyut,
            Thanks for the suggestion. Sadly it may be some time before we get to this due to (paying) project work that is keeping us very busy. Of course, Mango is open source software, and so we encourage those with a development yen to feel free and implement new stuff. :D
            • K Offline
              Keith
              Hi
              1 wire. & Tcp/ip
                Hi Keith,
                Thanks for the information. We in fact have code about 75% complete to implement 1-wire, but due to other (paying) project work, have not had time to complete the implementation. Watch the site for updates!
                  aslab
                  Do you support xml/SOAP?
                    Do you mean web services? Currently no, not formally. But in which direction would you want support:
                    1. having Mango read data from a web service
                    2. having Mango post data to a web service
                    3. the ability to get data via a Mango web service
                    4. the ability to post data to a Mango web service
                    An existing protocol that is similar to 4) is the "HTTP receiver" data source, which listens for HTTP connections (GET or POST) and can parse the parameters into point values.
                      aslab
                      Primarily read data from a web service but posting would also be nice!!
                      • E Offline
                        esquizo
                        Hi. You're right about OPC but in Industry there are many closed or commercial solutions. With OPC we can use many protocols with the same OPC server ( Modbus, Profibus, Device Net, MPI, PPI, Unitelway, Control Net, .....).
                        There is a project in this page:
                        http://openscada.org
                        The project is called Utgard, and it's a pure Java OPC client, and the better thing, it's Open Source.
                        Best regards.
                        • K Offline
                          knigjes
                          +1 Allen Bradley
                            CouchPotatoe
                            Regards
                            Prodyut
                            Unfortunately the C-Bus protocol is not an open standard. It is however available to C-Bus Enabled partners. There is a subset of the protocol available as a 'public' document but it is restricted in its features.
                            There is a C-Bus to xAP protocol convertor and xAP is very much an open standard - and appears in the survey above. One of the benefits of xAP is that it is very simple yet powerful and its also easy to convert other protocols into xAP and hence integrate them into different applications. Most of the leading HA applications now have xAP plugins.
                            • D Offline
                              dusky
                              Hi
                              I use :
                              Modbus RS232
                              Modbus TCP/IP
                              Bacnet IP
                              Bacnet LON
                              SQL Sybase SQL Anywhere
                              BR
                                Dusan, you're in luck. Mango supports them all. (Ok, not BACnet LON).
                                • I Offline
                                  iyus
                                  How about KNX ?
                                    juanfetel
                                    Good Day,
                                    In our company we use:
                                    LonWorks
                                    BACnet (IP and MSTP)
                                    ModBus
                                    SNMP
                                    KNX (Hope it will be included in the future)
                                      jfhaugh
                                      Modbus/RTU
                                      Modbus/TCP
                                      My company (greenHouse Gas and Electric) supports j2mod which also has support for Modbus/UDP (Modbus/TCP packets over UDP), but I don't personally use Modbus/UDP. I mention j2mod because j2mod is being used as the "base" for posting open source Arduino sketches that support Modbus/RTU and eventually Modbus/TCP and/or Modbus/UDP.
                                      I'd like to do more with 1-wire, just haven't had the time.
                                      I'm toying with creating new protocols, but there are intellectual property issues to resolve.
