    Mango Using 100% CPU
    20 Posts 2 Posters 12.4k Views 2 Watching
    • danD Offline
      dan
      this was the result of the overrides folder...
      root@water:/opt/mango# find /opt/mango/overrides/
      /opt/mango/overrides/properties
      /opt/mango/overrides/properties/env.properties
      /opt/mango/overrides/lib
      /opt/mango/overrides/lib/libjdns_sd.so
        Hmm. From your log it appears you maybe only downloaded the core, and not the bundle (which also has the modules). I would suggest downloading the 2.8.8 bundle from https://store.infiniteautomation.com/core and placing it in your Mango/ directory with the name m2m2-core-2.8.8.zip then trying to start Mango. It should reinstall 2.8.8 and have the 2.8.x versions of the modules in the Mango/web/modules directory (which you could also just copy out of the zip bundle).
        • danD Offline
          dan
          Ah I see, that makes sense ;)
          I'll try that and come back to you.
          • danD Offline
            dan
            Hey Phil, I can't seem to find a bundle pack with all the modules..
            Am I looking in the right place?
              Yeah, that's the right place. My mistake in using the world bundle, I thought it appeared there but it doesn't not. The full core downloads in the top section of the page (two for the latest 3.x enterprise and free, two for 2.8.8) contain modules. Where the cores in the section labelled 'Core Only - No Modules' do not.contain modules.
              • danD Offline
                dan
                Thanks for that, I'll try that one.
                • danD Offline
                  dan
                  ok, so I went back to the original upgrade process, this time extracting the zip which contains the modules also.
                  now the mango process seems to be starting then restarting, looping..
                  one of the errors I see is:
                  ERROR 2018-09-07 11:39:27,544 (com.serotonin.m2m2.Lifecycle.fullyInitializeWebContext:971) -
                  java.lang.NullPointerException
                          at com.serotonin.m2m2.Lifecycle.fullyInitializeWebContext(Lifecycle.java:967)
                          at com.serotonin.m2m2.Lifecycle.initialize(Lifecycle.java:324)
                          at com.serotonin.m2m2.Main.main(Main.java:115)
                  ERROR 2018-09-07 11:39:27,555 (com.serotonin.m2m2.Main.main:119) - Error during initialization
                          at com.serotonin.m2m2.Lifecycle.configureStartupDwr(Lifecycle.java:1023)
                          at com.serotonin.m2m2.Lifecycle.fullyInitializeWebContext(Lifecycle.java:974)
                    Oof. I have seen that error before, but haven't found its exact cause. Something is usually off kilter with either the installation of the core or the Java installation. If you try running up 2.8.8 in a new directory (new installation) do you still see that? What version of Java is installed? I would guess it's an older on! You can download the latest ARM 32bit JVM and unpack it over the existing JVM (which you may need to ls -l /etc/alternatives/java to locate, but it's probably at /usr/lib/jvm/) or you can unpack it someplace else and set JAVA_HOME in your /etc/environment
                    • danD Offline
                      dan
                      I can run up a fresh instance with no data points etc and it seems to run, I'll check what version JVM is on there.
                        Weird!
                        I would try copying your databases folder into the new installation. If that works, I would stop Mango, move the old installation directory, move the new one where the old one was, and start Mango again, which will get the license working.
