    A script JsonEmport example
    1 Posts 1 Posters 1.2k Views 2 Watching
      Here's a simple script to add a particular event detector to all data points identified by either a static or a query watchlist:
      var xidPrefix = "ED_15m_status_"; //Used to see if a point already has the detector
      var watchListXid = "WL_5275e48f-5819-4971-8462-0d1ed8ea8264"; //Identify the points to add to
      var dataPoints = JSON.parse(JsonEmport.getConfiguration("dataPoints")).dataPoints;
      var watchLists = JSON.parse(JsonEmport.getConfiguration("watchLists")).watchLists;
      function findByXid(list, xid) {
          for( var k = 0; k < list.length; k+=1 )
              if( list[k].xid === xid )
                  return list[k];
          return undefined;
      var wl = findByXid(watchLists, watchListXid);
      if(typeof wl === 'undefined')
          throw "Couldn't find watchlist with XID " + watchListXid + " to add detectors to";
      var importPoints = [];
      function addDetectorToDataPoint(dp) {
          for( var l = 0; l < dp.eventDetectors.length; l+=1 ) {
              if(dp.eventDetectors[l].xid.startsWith(xidPrefix)) //Don't add it twice
                  return;
          var ed = { //Gotten by configuring one and exporting it
                     "type":"BINARY_STATE",
                     "sourceType":"DATA_POINT",
                     "xid":com.serotonin.m2m2.Common.generateXid(xidPrefix),
                     "name":"",
                     "alarmLevel":"URGENT",
                     "durationType":"MINUTES",
                     "duration":15,
                     "state": (dp.textRenderer.type === "BINARY"
                            && dp.textRenderer.oneLabel === "Device Ok")
          //Note that compatibility is not being checked, but it should just fail
          // the individual points during the import if isn't a binary point.
          dp.eventDetectors.push(ed);
          importPoints.push(dp);
      if(wl.type === 'static') {
          //Okay, just look over an XID list
          for(var j = 0; j < wl.dataPoints.length; j+=1) {
              var dp = findByXid(dataPoints, wl.dataPoints[j]);
              addDetectorToDataPoint(dp);
      } else if(wl.type === 'query') {
          //Okay, use the query to get the data points from the DataPointQuery
          var addToPoints = DataPointQuery.query(wl.query);
          for(var j = 0; j < addToPoints.length; j+=1) {
              var dp = findByXid(dataPoints, addToPoints[j].getXid());
      //Mango 3.5 will allow us to
      //JsonEmport.setImportDuringValidation( true );
      JsonEmport.doImport(JSON.stringify({"dataPoints":importPoints}));
      In Mango 3.5 there will be a way to tell the JsonEmport utility to run even during validation, but for now this script would have to actually run to perform the import.
      Edit: I said there would be a way to import during validation, and there is! The commented line about setImportDuringValidation can be uncommented to make the importer work even during script validation.
      8/23/19 edit: I believe the name field an no longer be blank, as in the original posting.
