    73 Posts 5 Posters 123.1k Views 5 Watching
      Did you see the function I provided Mihai in the script? You could write a loop to call that function and set values out to some alphanumeric point along the way (just not between generations). Something like,
      var pointsList = DataPointQuery.query("dataSourceXid=DS_XID");
      var metaDwr = new com.serotonin.m2m2.meta.MetaEditDwr();
      var now = new Date().getTime();
      //var pvd = com.serotonin.m2m2.Common.databaseProxy.newPointValueDao();
      for(var k = 0; k < pointsList.length; k+=1) {
          //Given the issue discussed here with the delete before checkbox, you may want to call,
          //pvd.deletePointValuesBetween(pointsList[k].getId(), 0, now);
          metaDwr.generateMetaPointHistory(pointsList[k].getId(), 0, now, true);
          //alphanum.set("Finished with point: " + pointsList[k].getId());
      This will regenerate all meta points on data source "DS_XID" from 0 (1970) to now, deleting what exists already, even when you only press validate in the script window.
        Phillip Weeks
        ok sounds great and so can I replace the 0, now) with periodBegin , periodEnd right?
        guess I also could also use the pvd.deletePointValuesBetween in other scripts where I want to delete before I manipulate original logged values in the same way before setting a new value correct? Not only for meta points I mean.
        so Jan 3 - 5 2018
        var periodBegin = new Date(2018, 0, 3);
        periodBegin.setHours(0);
        periodBegin.setMinutes(0);
        periodBegin.setSeconds(0);
        periodBegin.setMilliseconds(0);
        var periodEnd = new Date(2018, 0, 5);
        periodEnd.setHours(12);
        periodEnd.setMinutes(0);
        periodEnd.setSeconds(0);
        periodEnd.setMilliseconds(0);
          Yes all sounds good. I do believe Java will cast a Date to a long by using the getTime() but you may as well call it yourself, i.e. periodStart.getTime() and periodEnd.getTime() in the actual call to generateMetaPointHistory
          To invoke the method on pvd you will need to create it as shown in that script.
            Phillip Weeks
            so where do I run this? .. I tried in a scripting source but is complains of meta data source being cast to the scripting data source ... doI create another metaDS for this to run inside of ? OK that worked in another meta source. Thanks
              That complaint means you have multiple tabs open, and more recently edited the meta data source than the scripting, so it is confused which you are editing. Should work in any script environment, and it'll happen when the validation button is pressed, not only at normal runtime.
                Phillip Weeks
                Phil is there some limitation on the number of points returned into the pointsList by this query because I have 216 meta points in this data source and only 100 are being returned?
                  Yes, there is a default limit on that query of 100. You can add a &limit(1000) to the RQL to increase that.
                    Phillip Weeks
                    thanks ah
                    so if the RQL is eq(dataSourceXid,DS_537506)&limit(500)
                    what goes in here pointsList = DataPointQuery.query("dataSourceXid=DS_537506")
                    I got it now .. had a ) too many but it is working now
                      Nice! I hope that proves helpful!
                      I updated the Mango JavaScript context help to let the default limit of 100 be known, and noted &limit(-1) is the way to not have a limit. But, that note in the help won't appear until a later core version.
                        Phillip Weeks
                        So I set the history loop running in the meta window because I could not get it to validate in the scripting source . It kept complaining about not being able to cast meta to scripting and only one browser window open.
                        I set it running about four hours ago. Mango still refreshes to browser but reports server timeouts when retrieving any data so I guess it's running because it hasn't crashed yet lol. I'll give it overnight to run and check it in the am. If still unresponsive I may have to kill it and see how far it has gotten. 0_1516845440227_2984a869-8c4d-4577-8343-bec6f015498a-image.png
                        So it looks like it crashed again this time it created 318 million records back to 1969
                        Further diagnostics...
                        I ran the script enabling the range deletion over the entire datasource first as a seperate run from the metaDwr.generateMetaPointHistory and this worked perfectly. All datapoints had the correct range deleted.
                        I then ran the script again commenting out the pvd.deletePointValuesBetween and enabling only the metaDwr.generateMetaPointHistory since the purge was already done now. The process did not complete the first point history.. It spent 4 hours creating 318 million points and then ran out of memory several hours later while still on the first point.
                        So the issue with purging of the data beforehand seems unrelated to the generation of the erroneous points. I ran the history recalc for the first several points from the dialog box without deleting existing data as it is still zapped from before and they all recalculated correctly.
                          The fourth argument to that function is whether or not to invoke the delete code. If you have left that true (admittedly you would have had to have read the post carefully where I supplied it to Mihai to see a note on argument 4) then it's the same as having checked the box. I will try to get the updated Meta out today, which won't generate record prior to the start time.
                            Phillip Weeks
                            Shoot I believe I forgot to set that to false. That must be what happened.
                              Version 3.3.1 is released. If you update you can use the checkbox or the true argument without generating history back to time 0
                                Phillip Weeks
                                Thanks Phil will update now.
                                If I reference the metapoint variable from within the script to set a prior timestamp in its history while this script is running or if I do this in a determined loop
                                backcounter=5;
                                myvar.set(xval,myvar.time - backcounter * 1000);
                                backcounter+=5;
                                could this cause memory problems?
                                  I would always generate data oldest to newest, but offhand I wouldn't think so. You may need to throttle your script if there are too many point values waiting to be written. Surely there are cases where you can generate enough data to crash the boat. You could have throttling in there by reading the internal data source's "point values to be written" point, for instance,
                                  if(waitingValues.value > 1000000) RuntimeManager.sleep(5000);
                                    Phillip Weeks
                                    any obvious suggestions off hand I have tried a few variations as you suggested before about tuning the database to the mission. This is working but I haven't stress tested it either. Its tuning one history right now about 130k values
                                      Phillip Weeks
                                      Coincidentally this just crashed about have way thru
                                      When the console says the thread also had an error, does this mean that the script has an error it?
                                      var increment =5;
                                      var backcounter = 5; var LITERS_LAST_5MIN = 0;
                                      while ((CW.past(MINUTE,backcounter).delta === Number.NaN) && (backcounter < 2880)){
                                      backcounter += increment;}
                                      if ((backcounter >= 2880) || (CW.past(MINUTE,backcounter).delta < 0)){
                                      LITERS_LAST_5MIN = 0;}
                                      else{
                                      LITERS_LAST_5MIN = CW.past(MINUTE,backcounter).delta;
                                      return LITERS_LAST_5MIN;
                                        Phillip Weeks
                                        @phildunlap said in History Generation Still Running or Finished??:
                                        cant find this waitingValues in mango system
                                            Phillip Weeks
                                            Did you mean adding this sleep statement to the meta point script - Or to the example you suggested controlling the point history loop because the history fails on the very first point so putting it here would not alleviate this and putting pointstowrite variable in the meta point affects the history date range since both points get considered even though this new pointstowrite variable does not update the metapoint context?
