Login problem
When I try login in mango, the screen is frozen. I can't login because there's no option to login.
Try Firefox or Chrome. I get that in Chrome when my ad blocker is on for some reason.
What browser is that? We do not support Internet Explorer, Edge should work for most things but we do recommend using Chrome or Firefox.
Also check you don't have an adblocker running.
@jared-wiltshire thanks to response me
I tried with different browsers but it doesn't run. As I can check if I have some adblocker running?
@jared-wiltshire I'm checking if adblocker is running, but it is disable.
Can you open the console in Chrome and tell me if anything is in there?
@jared-wiltshire Thanks.
It can see in console
angular.js?v=1501173866:123 Markup '<md-button flex></md-button>' may not work as expected in IE Browsers. Consult 'https://github.com/philipwalton/flexbugs#9-some-html-elements-cant-be-flex-containers' for details.
(anonymous) @ angular.js?v=1501173866:123
c @ angular-material.js?v=1501173866:8
compile @ angular-material.js?v=1501173866:8
W @ angular.js?v=1501173866:74
Ma @ angular.js?v=1501173866:62
ca @ angular.js?v=1501173866:60
(anonymous) @ angular-ui-router.js?v=1501173866:7
(anonymous) @ angular.js?v=1501173866:17
ra @ angular.js?v=1501173866:85
n @ angular.js?v=1501173866:70
g @ angular.js?v=1501173866:61
(anonymous) @ angular.js?v=1501173866:61
(anonymous) @ angular.js?v=1501173866:66
l @ angular-ui-router.js?v=1501173866:7
$broadcast @ angular.js?v=1501173866:151
(anonymous) @ angular.js?v=1501173866:134
$digest @ angular.js?v=1501173866:145
$apply @ angular.js?v=1501173866:149
(anonymous) @ angular.js?v=1501173866:141
e @ angular.js?v=1501173866:48
(anonymous) @ angular.js?v=1501173866:51
setTimeout (async)
k.defer @ angular.js?v=1501173866:51
t @ angular.js?v=1501173866:141
$applyAsync @ angular.js?v=1501173866:149
l @ angular.js?v=1501173866:102
A.onload @ angular.js?v=1501173866:107
XMLHttpRequest.send (async)
(anonymous) @ angular.js?v=1501173866:108
p @ angular.js?v=1501173866:103
(anonymous) @ angular.js?v=1501173866:101
(anonymous) @ angular.js?v=1501173866:148
setTimeout (async)
$evalAsync @ angular.js?v=1501173866:148
(anonymous) @ angular.js?v=1501173866:132
h @ angular.js?v=1501173866:134
then @ angular.js?v=1501173866:137
$delegate.then @ qDecorator.js?v=1501173866:14
f @ ocLazyLoad.js?v=1501173866:8
inject @ ocLazyLoad.js?v=1501173866:8
(anonymous) @ menuItems.js?v=1501173866:94
(anonymous) @ requireQ.js?v=1501173866:65
execCb @ require.js?v=1501173866:5
check @ require.js?v=1501173866:5
(anonymous) @ require.js?v=1501173866:5
each @ require.js?v=1501173866:5
emit @ require.js?v=1501173866:5
enable @ require.js?v=1501173866:5
init @ require.js?v=1501173866:5
completeLoad @ require.js?v=1501173866:5
onScriptLoad @ require.js?v=1501173866:5
(anonymous) @ angular.js?v=1501173866:80
o @ angular-material.js?v=1501173866:7
(anonymous) @ angular.js?v=1501173866:161
setTimeout (async)
f @ angular.js?v=1501173866:161
nextTick @ angular-material.js?v=1501173866:7
init @ angular-material.js?v=1501173866:16
o @ angular-material.js?v=1501173866:16
setTimeout (async)
setTimeout (async)
angular.js?v=1501173866:108 GET http://localhost:8080/rest/v1/data-points/DP_877f14f3-1785-44bf-b373-823681bd2dd9 404 (Not Found)
(anonymous) @ angular.js?v=1501173866:162
setTimeout (async)
request @ loading-bar.js?v=1501173866:7
setTimeout (async)
setTimeout (async)
setTimeout (async)
angular.js?v=1501173866:123 Possibly unhandled rejection: {"data":"","status":404,"config":{"method":"GET","transformRequest":[null],"transformResponse":[null],"jsonpCallbackParam":"callback","timeout":{},"url":"/rest/v1/data-points/DP_877f14f3-1785-44bf-b373-823681bd2dd9","headers":{"Accept":"application/json, text/plain, /","X-Requested-With":"XMLHttpRequest","X-XSRF-TOKEN":"4d713103-576a-418e-90d8-df0a40fb0311"},"cached":false},"statusText":"Not Found"} -
Now, I can login, but only in google chrome, internet explorer don't run.
