<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[1-wire USB]]></title><description><![CDATA[<p dir="auto">Hi how do I make the  DS1990A 1-wire USB interface unit work with mango ?<br />
When I try to add 1-wire to the system only com1 shows, not any USB ports</p>
<p dir="auto">regards, jesper</p>
]]></description><link>https://forum.mango-os.com/topic/96/1-wire-usb</link><generator>RSS for Node</generator><lastBuildDate>Wed, 14 Oct 2026 16:25:58 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/96.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 21 Jul 2008 13:18:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 1-wire USB on Sun, 18 Jan 2009 17:26:34 GMT]]></title><description><![CDATA[<p dir="auto">Which one wire device are you planning on using?</p>
]]></description><link>https://forum.mango-os.com/post/2425</link><guid isPermaLink="true">https://forum.mango-os.com/post/2425</guid><dc:creator><![CDATA[mjbcomputers]]></dc:creator><pubDate>Sun, 18 Jan 2009 17:26:34 GMT</pubDate></item><item><title><![CDATA[Reply to 1-wire USB on Mon, 21 Jul 2008 15:22:57 GMT]]></title><description><![CDATA[<p dir="auto">Java's support for USB is sketchy at best. I don't recall off hand if there is a Windows solution to this problem, but for *nix you can buy special serial/USB cables (about $25 in Canada). Then you issue a command such as the following:</p>
<pre><code>mknod /dev/ttyUSB0 c 188 0
<p dir="auto">The two '0' (zeroes) can be replaced with whatever node you want to use. Note that the nature of USB though makes it sometimes unpredictable which node number will be used. This is usually just a problem on system restarts though.</p>
<p dir="auto">Once this is done, you should see something like "/dev/ttyUSB0" show up in your port lists in Mango.</p>
]]></description><link>https://forum.mango-os.com/post/2262</link><guid isPermaLink="true">https://forum.mango-os.com/post/2262</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Mon, 21 Jul 2008 15:22:57 GMT</pubDate></item></channel></rss>
