<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Edit Raw Data]]></title><description><![CDATA[<p dir="auto">I'm looking for a way to edit the temp/RH data that mango stores. Whenever we lose power in the warehouse the temp/RH module reads -1,000 and that causes a lot of problems on the Mango graphs.<br />
Any ideas?</p>
<p dir="auto">Thanks,<br />
Josh</p>
]]></description><link>https://forum.mango-os.com/topic/864/edit-raw-data</link><generator>RSS for Node</generator><lastBuildDate>Sat, 17 Oct 2026 03:05:12 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/864.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 18 Jul 2011 18:15:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Edit Raw Data on Tue, 30 Oct 2012 21:42:46 GMT]]></title><description><![CDATA[<p dir="auto">Can someone please post a sample SQL command that will purge extreme values from a datapoint, or purge values within a certain time range?</p>
<p dir="auto">I realize that I can set a discard low/high limit, but that does not help once the data is already logged. I have often found that when adjusting metadata formulas I sometimes wind up with a recent datapoint value that screws up my dataset, and consequently the graph scaling. My other option is the purge function, but that would cause me to lose all history before that point.</p>
<p dir="auto">It would also be useful to know how to replace point values that meet a certain date or value threshold. This would enable me to, for instance, change the scaling of prerecorded datapoints. e.g. to replace a Fahrenheit temperature dataset history with a Celsius dataset, or replace amperes with milliamperes.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.mango-os.com/post/7098</link><guid isPermaLink="true">https://forum.mango-os.com/post/7098</guid><dc:creator><![CDATA[PCM]]></dc:creator><pubDate>Tue, 30 Oct 2012 21:42:46 GMT</pubDate></item><item><title><![CDATA[Reply to Edit Raw Data on Tue, 19 Jul 2011 04:19:53 GMT]]></title><description><![CDATA[<p dir="auto">In addition, you can prevent this from happening in the first place by using "discard extreme values" checkbox for the data point. I was having the same problem with my 1-wire temperature sensors and this fixed it entirely.</p>
<p dir="auto">Attachment: <a href="http://archive.infiniteautomation.com/forum/posts/downloadAttach/114.page" rel="nofollow ugc">download link</a></p>
]]></description><link>https://forum.mango-os.com/post/5830</link><guid isPermaLink="true">https://forum.mango-os.com/post/5830</guid><dc:creator><![CDATA[mhradom]]></dc:creator><pubDate>Tue, 19 Jul 2011 04:19:53 GMT</pubDate></item><item><title><![CDATA[Reply to Edit Raw Data on Mon, 18 Jul 2011 20:26:07 GMT]]></title><description><![CDATA[<p dir="auto">I think, it is only one way to change or delete old values.<br />
I did it one or two times without problems.</p>
<p dir="auto">You can this:</p>
<li>Backup DERBY files or go to Export function in Mango</li>
<li>Create new Mango on other PC</li>
<li>Import data from backup</li>
<li>Try SQL operations</li>
<p dir="auto">I think, that you will be succesfully.</p>
<p dir="auto">sorry for my English.</p>
]]></description><link>https://forum.mango-os.com/post/5826</link><guid isPermaLink="true">https://forum.mango-os.com/post/5826</guid><dc:creator><![CDATA[oja]]></dc:creator><pubDate>Mon, 18 Jul 2011 20:26:07 GMT</pubDate></item><item><title><![CDATA[Reply to Edit Raw Data on Mon, 18 Jul 2011 20:04:47 GMT]]></title><description><![CDATA[<p dir="auto">oja, you lost me. Especially when the SQL page states: "Warning: use this facility at your own risk. Incorrect usage may result in corrupted data and/or system failures."</p>
<p dir="auto">So unless you, or someone, has a known working SQL statement that I can fill in my particulars and use, I'm not going to risk it.</p>
]]></description><link>https://forum.mango-os.com/post/5825</link><guid isPermaLink="true">https://forum.mango-os.com/post/5825</guid><dc:creator><![CDATA[xeroseven]]></dc:creator><pubDate>Mon, 18 Jul 2011 20:04:47 GMT</pubDate></item><item><title><![CDATA[Reply to Edit Raw Data on Mon, 18 Jul 2011 19:53:20 GMT]]></title><description><![CDATA[<p dir="auto">I think that you can do it by SQL queries. Third icon from end on icon bar.<br />
You have to see table DataPoints - check ID column and XID column. Right value ID can be used for query on table PointValues.</p>
]]></description><link>https://forum.mango-os.com/post/5824</link><guid isPermaLink="true">https://forum.mango-os.com/post/5824</guid><dc:creator><![CDATA[oja]]></dc:creator><pubDate>Mon, 18 Jul 2011 19:53:20 GMT</pubDate></item></channel></rss>
