<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[IO Exception in seroUtils.jar]]></title><description><![CDATA[<p dir="auto">Matthew,</p>
<p dir="auto">I'm getting an exception in seroUtils.jar.  Near as I can tell it occurs when there are multiple concurrent requests for values for several different slaves.  The exception stack is:</p>
<p dir="auto">java.io.IOException: Stream closed.<br />
at java.net.PlainSocketImpl.available(PlainSocketImpl.java:434)<br />
at java.net.SocketInputStream.available(SocketInputStream.java:217)<br />
at java.io.BufferedInputStream.available(BufferedInputStream.java:381)<br />
at com.serotonin.io.InputStreamListener.run(InputStreamListener.java:67)</p>
<p dir="auto">The only way it appears I can correct the problem is to restart the application and everything will work fine so long as I don't hammer the requests concurrently.</p>
<p dir="auto">Have you seen this before?</p>
<p dir="auto">The version of Modbus4J is 1.02.</p>
<p dir="auto">Regards,<br />
Fred</p>
]]></description><link>https://forum.mango-os.com/topic/858/io-exception-in-seroutils-jar</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 19:57:55 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/858.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 06 Jul 2011 17:03:24 GMT</pubDate><ttl>60</ttl></channel></rss>
