<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mango integrated into a large-scale Battery Management System]]></title><description><![CDATA[<p dir="auto">I will be test/using Mango as the UI in a large-scale BMS.  The size of an average installation is around 1 MWh.  There are approximately 160 modules (batteries) of 6.2kWh organized into 10 packs of 16 modules.  Each module has approximately 200 data points which are a mix of analog and digital data (eg. voltages and alarms).  The architecture is structured such that the data is gathered by CAN from the 10 "pack controllers" using a .NET-based driver and sorted and inserted into a MySQL database (it is "thin" in that no archiving takes place here).  Mango accesses the MySQL database for its data source.  I have converted Mango to use MySQL rather than Derby as its own database.  I hope that this setup will enable me to update 10% of the data points at once per second.  Some data, such as temperatures, don't change fast enough to warrant better than an update every 5 or 10 seconds.  I have a simple framework with all the components set up and running now.  I have been really impressed with Mango so far., and I will be developing some custom graphics</p>
]]></description><link>https://forum.mango-os.com/topic/835/mango-integrated-into-a-large-scale-battery-management-system</link><generator>RSS for Node</generator><lastBuildDate>Wed, 14 Oct 2026 17:15:12 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/835.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 14 May 2011 22:11:55 GMT</pubDate><ttl>60</ttl></channel></rss>
