<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Error in system settings]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I get errors when saving in system settings.<br />
M2M2 V1.0.1, Ubuntu 10.04.1 LTS</p>
<p dir="auto">System event alarm levels:<br />
Error marshalling java.util.List: Error marshalling com.serotonin.m2m2.vo.pair.StringIntPair: No converter found for 'class com.serotonin.m2m2.vo.pair.StringIntPair'. See the logs for more details.. See the logs for more details.</p>
<p dir="auto">Audit event alarm levels:<br />
<p dir="auto">Email settings, HTTP settings, Other settings, Colour settings = OK</p>
<p dir="auto">Error when I change and save user:<br />
PreparedStatementCallback; SQL [update users set   username=?, password=?, email=?, phone=?, admin=?, disabled=?, homeUrl=?, receiveAlarmEmails=?,   receiveOwnAuditEvents=? where id=?]; An attempt was made to get a data value of type 'VARCHAR' from a data value of type 'null'.; nested exception is java.sql.SQLDataException: An attempt was made to get a data value of type 'VARCHAR' from a data value of type 'null'.</p>
<p dir="auto">Add a new user = OK</p>
<p dir="auto">Br, Conny Larsson</p>
]]></description><link>https://forum.mango-os.com/topic/794/error-in-system-settings</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 11:32:24 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/794.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 29 Mar 2011 20:59:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Error in system settings on Thu, 31 Mar 2011 00:31:55 GMT]]></title><description><![CDATA[<p dir="auto">No. It's possible it was already discovered and fixed in dev.</p>
]]></description><link>https://forum.mango-os.com/post/5628</link><guid isPermaLink="true">https://forum.mango-os.com/post/5628</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Thu, 31 Mar 2011 00:31:55 GMT</pubDate></item><item><title><![CDATA[Reply to Error in system settings on Wed, 30 Mar 2011 23:55:57 GMT]]></title><description><![CDATA[<p dir="auto">it works</p>
<p dir="auto">any idea about the user save error?</p>
<p dir="auto">Thanks<br />
/Conny</p>
]]></description><link>https://forum.mango-os.com/post/5626</link><guid isPermaLink="true">https://forum.mango-os.com/post/5626</guid><dc:creator><![CDATA[colarsson]]></dc:creator><pubDate>Wed, 30 Mar 2011 23:55:57 GMT</pubDate></item><item><title><![CDATA[Reply to Error in system settings on Tue, 29 Mar 2011 22:59:53 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Conny. I was able to recreate the first two, but not the latter. The first two can be fixed by adding this line to web/WEB-INF/dwr.xml:</p>
<pre><code>    &amp;lt;convert converter="bean" match="com.serotonin.m2m2.vo.pair.*"/&amp;gt;
<p dir="auto">... somewhere in with the other converters. This fix will be in an upcoming upgrade.</p>
]]></description><link>https://forum.mango-os.com/post/5620</link><guid isPermaLink="true">https://forum.mango-os.com/post/5620</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Tue, 29 Mar 2011 22:59:53 GMT</pubDate></item></channel></rss>
