<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Max Objects Count]]></title><description><![CDATA[<p dir="auto">Hi;</p>
<p dir="auto">I have created Bacnet device. And I can added max 292 objects(Analog input). When I created 293 obects , error occured("Invalid packed.Unknown reject reason) on bacnet server.</p>
<p dir="auto">And on java error message is below</p>
<pre><code>
java.lang.NullPointerException
	at com.serotonin.bacnet4j.event.DefaultExceptionListener.receivedThrowable(DefaultExceptionListener.java:37)
	at com.serotonin.bacnet4j.npdu.ip.IpMessageControl$IncomingMessageExecutor.runImpl(IpMessageControl.java:530)
	at com.serotonin.bacnet4j.npdu.ip.IpMessageControl$IncomingMessageExecutor.run(IpMessageControl.java:470)
	at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
<p dir="auto">What is the problem. Can I created max 292 objects? But I need more than 292 objects. What can I do.</p>
]]></description><link>https://forum.mango-os.com/topic/747/max-objects-count</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Mar 2026 09:33:21 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/747.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 15 Feb 2011 00:07:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Max Objects Count on Sun, 20 Feb 2011 17:18:38 GMT]]></title><description><![CDATA[<p dir="auto">I committed a change to IpMessageControl that will provide a better exception message than the NPE. Please build from the latest source and give it another try.</p>
]]></description><link>https://forum.mango-os.com/post/5437</link><guid isPermaLink="true">https://forum.mango-os.com/post/5437</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Sun, 20 Feb 2011 17:18:38 GMT</pubDate></item></channel></rss>
