<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[HTTP Retriever Stops Working [update: all data sources hang not just HTTP]]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I am using the HTTP Retriever data source, and it works for a while (not always the same amount of time, but around 30 minutes or so) and then it stops updating. If I go to the datasource and click disable, it disables. But then if I click enable, it give me a error message "Timer already cancelled", and on the Tomcat monitor it gives me &gt; WARN  2011-02-11 09:14:13,953 (org.directwebremoting.util.CommonsLoggingOutput.warn:59) - --Erroring: batchId[5] message[java.lang.IllegalStateException: Timer already cancelled.] Any other changes I try to save to the data source gives the "timer already cancelled" error message.</p>
<p dir="auto">I am thinking that mango must get hung up on something, which prevents further updates from happening, even though I have set my retries to 0 and timeout to 10 seconds.</p>
<p dir="auto">Extra info: I have tested this on more that one website, and both hang at approximately the same point, indicating that it is not a problem with the website.</p>
<p dir="auto">Suggestions? Any help is appreciated!</p>
]]></description><link>https://forum.mango-os.com/topic/743/http-retriever-stops-working-update-all-data-sources-hang-not-just-http</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 23:01:31 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/743.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 09 Feb 2011 19:33:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to HTTP Retriever Stops Working [update: all data sources hang not just HTTP] on Tue, 01 Mar 2011 20:57:34 GMT]]></title><description><![CDATA[<p dir="auto">Yeah, the timer has a limit of 500 threads. It's an artificial limit, but is usually suitable. Your system is adding more than 10 new high priority tasks every 10 seconds, which is definitely bad (but only if it can't clear them out). I'll go ahead an assume that these are database write behind tasks, which would mean that Derby is insufficient for the scale of your system.</p>
]]></description><link>https://forum.mango-os.com/post/5482</link><guid isPermaLink="true">https://forum.mango-os.com/post/5482</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Tue, 01 Mar 2011 20:57:34 GMT</pubDate></item><item><title><![CDATA[Reply to HTTP Retriever Stops Working [update: all data sources hang not just HTTP] on Tue, 01 Mar 2011 20:41:04 GMT]]></title><description><![CDATA[<p dir="auto">Besides the "timer already cancelled" messages, the "High priority active count: " seems very high, going up to ~500. I have attached the log file containing the majority of these error messages.</p>
<p dir="auto">Attachment: <a href="http://archive.infiniteautomation.com/forum/posts/downloadAttach/104.page" rel="nofollow ugc">download link</a></p>
]]></description><link>https://forum.mango-os.com/post/5475</link><guid isPermaLink="true">https://forum.mango-os.com/post/5475</guid><dc:creator><![CDATA[rcopeland]]></dc:creator><pubDate>Tue, 01 Mar 2011 20:41:04 GMT</pubDate></item><item><title><![CDATA[Reply to HTTP Retriever Stops Working [update: all data sources hang not just HTTP] on Tue, 01 Mar 2011 20:14:46 GMT]]></title><description><![CDATA[<p dir="auto">Is there anything interesting in your logs?</p>
]]></description><link>https://forum.mango-os.com/post/5472</link><guid isPermaLink="true">https://forum.mango-os.com/post/5472</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Tue, 01 Mar 2011 20:14:46 GMT</pubDate></item><item><title><![CDATA[Reply to HTTP Retriever Stops Working [update: all data sources hang not just HTTP] on Tue, 01 Mar 2011 20:11:37 GMT]]></title><description><![CDATA[<p dir="auto">Not sure why I was having these errors, but they seem to have stopped. The only thing I can think of is I use a LOT of meta data sources, some of which have very long functions, take in the value of MANY points, maybe the functions were timing out/crashing the program.</p>
]]></description><link>https://forum.mango-os.com/post/5471</link><guid isPermaLink="true">https://forum.mango-os.com/post/5471</guid><dc:creator><![CDATA[rcopeland]]></dc:creator><pubDate>Tue, 01 Mar 2011 20:11:37 GMT</pubDate></item><item><title><![CDATA[Reply to HTTP Retriever Stops Working [update: all data sources hang not just HTTP] on Sun, 20 Feb 2011 17:01:04 GMT]]></title><description><![CDATA[<p dir="auto">Did reverting to a previous version help? The "timer already cancelled" error indicates that the Mango runtime was shut down, which is a curious thing to have happen. It would be interesting to know what the threads are doing just before and just after the points stop updating.</p>
]]></description><link>https://forum.mango-os.com/post/5435</link><guid isPermaLink="true">https://forum.mango-os.com/post/5435</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Sun, 20 Feb 2011 17:01:04 GMT</pubDate></item><item><title><![CDATA[Reply to HTTP Retriever Stops Working [update: all data sources hang not just HTTP] on Fri, 11 Feb 2011 18:33:03 GMT]]></title><description><![CDATA[<p dir="auto">Derby. I haven't changed much of anything in Mango other than some graphical elements.</p>
]]></description><link>https://forum.mango-os.com/post/5403</link><guid isPermaLink="true">https://forum.mango-os.com/post/5403</guid><dc:creator><![CDATA[rcopeland]]></dc:creator><pubDate>Fri, 11 Feb 2011 18:33:03 GMT</pubDate></item><item><title><![CDATA[Reply to HTTP Retriever Stops Working [update: all data sources hang not just HTTP] on Fri, 11 Feb 2011 18:25:43 GMT]]></title><description><![CDATA[<p dir="auto">What database are you using, Derby or MySQL?</p>
]]></description><link>https://forum.mango-os.com/post/5402</link><guid isPermaLink="true">https://forum.mango-os.com/post/5402</guid><dc:creator><![CDATA[fmunhoz]]></dc:creator><pubDate>Fri, 11 Feb 2011 18:25:43 GMT</pubDate></item><item><title><![CDATA[Reply to HTTP Retriever Stops Working [update: all data sources hang not just HTTP] on Fri, 11 Feb 2011 15:54:52 GMT]]></title><description><![CDATA[<p dir="auto">More info: this could possbily be a bug with the current version of mango. All of my data sources stop updating within a minute or so of eachother. Even virtual data sources giving random numbers hang, and product the same "timer already cancelled" error if I try to restart them. I am still not sure what causes this problem to happen, but it seems that 45 mintues or so after mango and tomcat is started, the data sources stop.</p>
<p dir="auto">I will revert back to a previous version of mango and test this if I have a chance.</p>
<p dir="auto">Attachment: <a href="http://archive.infiniteautomation.com/forum/posts/downloadAttach/99.page" rel="nofollow ugc">download link</a></p>
]]></description><link>https://forum.mango-os.com/post/5399</link><guid isPermaLink="true">https://forum.mango-os.com/post/5399</guid><dc:creator><![CDATA[rcopeland]]></dc:creator><pubDate>Fri, 11 Feb 2011 15:54:52 GMT</pubDate></item></channel></rss>
