<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can&#x27;t access some devices which can be accessed by BACnet Stack]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I am facing a strange question. I am trying to use the BACnet4J to access a device with a list of objects such as Analog Input and output. I am able to receive the I-AM message from the device so that I can create RemoteDevice for it. However, I can't access its properties and objects and always get the error message in Wireshark: "Reject-Message-To-Network: Reject reason: 1(The router is not directly connected to DNET and ...)". I can do it using BACnet Stack.</p>
<p dir="auto">My IP is A.B.73.178. I compared the messages in Wireshark and found that using BACnet Stack, I will firstly receive an I-AM message from a router (A.B.73.240) which is inside my subnet. In this message, the "BACnet Virtual Link Control" part shows that the IP of the actual device I am asking for is "C.D.100.42". If I use BACnet Stack, it will directly send a "read property" message to this IP address and receive the result from it. However, if I use BACnet4J, the program will send a message to my router "A.B.73.240" and then my router will send back that error message I mentioned in the previous paragraph. Is there anything I did wrong which results in this problem? Thank you very much!</p>
]]></description><link>https://forum.mango-os.com/topic/732/can-t-access-some-devices-which-can-be-accessed-by-bacnet-stack</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 16:19:40 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/732.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 31 Jan 2011 15:43:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can&#x27;t access some devices which can be accessed by BACnet Stack on Tue, 01 Feb 2011 15:35:37 GMT]]></title><description><![CDATA[<p dir="auto">No worries. Thanks for following up.</p>
]]></description><link>https://forum.mango-os.com/post/5322</link><guid isPermaLink="true">https://forum.mango-os.com/post/5322</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Tue, 01 Feb 2011 15:35:37 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t access some devices which can be accessed by BACnet Stack on Tue, 01 Feb 2011 15:29:50 GMT]]></title><description><![CDATA[<p dir="auto">Just found that the latest version of BACnet4J works well for this problem  :)</p>
<p dir="auto">Sorry for spamming!</p>
]]></description><link>https://forum.mango-os.com/post/5321</link><guid isPermaLink="true">https://forum.mango-os.com/post/5321</guid><dc:creator><![CDATA[Pine]]></dc:creator><pubDate>Tue, 01 Feb 2011 15:29:50 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t access some devices which can be accessed by BACnet Stack on Mon, 31 Jan 2011 16:03:23 GMT]]></title><description><![CDATA[<p dir="auto">Just to add some more information: I can use BACnet4J to access some devices and for these devices, when I receive the I-AM message, it is "Original-Unicast-NPDU" message in the "BACnet Virtual Link Control" part. For the devices which I can't access, the message is "Forwarded-NPDU" and there is an IP address there. I think this might be the reason that I get the error message.</p>
]]></description><link>https://forum.mango-os.com/post/5310</link><guid isPermaLink="true">https://forum.mango-os.com/post/5310</guid><dc:creator><![CDATA[Pine]]></dc:creator><pubDate>Mon, 31 Jan 2011 16:03:23 GMT</pubDate></item></channel></rss>
