<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Module.properties not found]]></title><description><![CDATA[<p dir="auto">Trying to load up some of the modules and getting an error that the (could not cut and past from dev system so not exact message)</p>
<p dir="auto">/m2m/web/modules/classes module.properties not found in module directory - module not loaded</p>
<p dir="auto">any idea how to fix</p>
]]></description><link>https://forum.mango-os.com/topic/729/module-properties-not-found</link><generator>RSS for Node</generator><lastBuildDate>Wed, 11 Nov 2026 07:27:54 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/729.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 28 Jan 2011 15:44:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Module.properties not found on Sat, 29 Jan 2011 12:31:23 GMT]]></title><description><![CDATA[<p dir="auto">great - works now - prehaps the instructions could be a little clearer</p>
]]></description><link>https://forum.mango-os.com/post/5301</link><guid isPermaLink="true">https://forum.mango-os.com/post/5301</guid><dc:creator><![CDATA[fclauson]]></dc:creator><pubDate>Sat, 29 Jan 2011 12:31:23 GMT</pubDate></item><item><title><![CDATA[Reply to Module.properties not found on Fri, 28 Jan 2011 17:30:44 GMT]]></title><description><![CDATA[<p dir="auto">The "classes" directory should be a subdirectory of the module. The path should be "/m2m/web/modules/&lt;module-name&gt;/classes".</p>
<p dir="auto">To install a module you need only put the zip file into the "modules" directory.</p>
]]></description><link>https://forum.mango-os.com/post/5298</link><guid isPermaLink="true">https://forum.mango-os.com/post/5298</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Fri, 28 Jan 2011 17:30:44 GMT</pubDate></item></channel></rss>
