<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Custom dynamic bar and dial gauge]]></title><description><![CDATA[<p dir="auto">Does anyone know how dynamic componets are linked to the points in graphical views?</p>
<p dir="auto">Is it possible to create my own dynamic gauges or at least customize the existing ones?</p>
<p dir="auto">thanks</p>
]]></description><link>https://forum.mango-os.com/topic/650/custom-dynamic-bar-and-dial-gauge</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 16:28:31 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/650.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 19 Nov 2010 16:46:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Custom dynamic bar and dial gauge on Sat, 20 Nov 2010 13:56:04 GMT]]></title><description><![CDATA[<p dir="auto">That's it!</p>
<p dir="auto">I put my own .png gauge image in a separeted folder and its custom pointer using dial example in view.js, it works well.</p>
<p dir="auto">Thank you!</p>
]]></description><link>https://forum.mango-os.com/post/4977</link><guid isPermaLink="true">https://forum.mango-os.com/post/4977</guid><dc:creator><![CDATA[ftomiBR]]></dc:creator><pubDate>Sat, 20 Nov 2010 13:56:04 GMT</pubDate></item><item><title><![CDATA[Reply to Custom dynamic bar and dial gauge on Fri, 19 Nov 2010 20:38:32 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">answers: yes something and I think so.</p>
<p dir="auto">I have not tried but taken a look how it works.</p>
<p dir="auto">Please take a look on the help. It says:</p>
<p dir="auto">"The Dynamic graphic component is similar to the analog image renderer in that it can visualize a numeric point, but instead of choosing one out of a set of images it dynamically draws the indicator of the value. For example, the pointer can be drawn on a single dial image. To add a new dynamic renderer, add a new subdirectory to the graphics directory and put the static image and an appropriate info file there. Then, add a rendering function to the resources/view.js file. The function must be named according to the name given to the subdirectory. See the Dial graphic as an example. "</p>
<p dir="auto">In the view.js there is the code for the dynamic parts. It looks quite straight forward but requires some coding skills. If you can update rest of us after trying...</p>
<p dir="auto">BR<br />
-Jokke</p>
]]></description><link>https://forum.mango-os.com/post/4974</link><guid isPermaLink="true">https://forum.mango-os.com/post/4974</guid><dc:creator><![CDATA[Jokke]]></dc:creator><pubDate>Fri, 19 Nov 2010 20:38:32 GMT</pubDate></item></channel></rss>
