<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Solved] Timer already canceled error]]></title><description><![CDATA[<p dir="auto">Hello everyone,</p>
<p dir="auto">I'm having difficulties with meta points using a CRON patern.<br />
As soon as I disable them, if I enable them again the message "Timer already canceled" pops up and all meta points with CRON stop being updated.</p>
<p dir="auto">I'm running Mango under Ubuntu 10.04LT with Tomcat6 downloaded from Mango website.</p>
<p dir="auto">Have some of you run into that issue?</p>
<p dir="auto">Thanks for your help</p>
]]></description><link>https://forum.mango-os.com/topic/638/solved-timer-already-canceled-error</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 22:24:26 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/638.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 13 Nov 2010 17:06:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Solved] Timer already canceled error on Thu, 25 Nov 2010 12:55:13 GMT]]></title><description><![CDATA[<p dir="auto">Hello mlohbihler and apl,</p>
<p dir="auto">I have installed Sun Java, removed OpenJava and Mango has been running without issue since then.<br />
I believe the issue is definitively solved.</p>
<p dir="auto">Thanks a lot!!  :D</p>
<p dir="auto">Alex</p>
]]></description><link>https://forum.mango-os.com/post/5007</link><guid isPermaLink="true">https://forum.mango-os.com/post/5007</guid><dc:creator><![CDATA[amoulart]]></dc:creator><pubDate>Thu, 25 Nov 2010 12:55:13 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved] Timer already canceled error on Sun, 21 Nov 2010 02:48:55 GMT]]></title><description><![CDATA[<p dir="auto">Is this still an issue?</p>
]]></description><link>https://forum.mango-os.com/post/4982</link><guid isPermaLink="true">https://forum.mango-os.com/post/4982</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Sun, 21 Nov 2010 02:48:55 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved] Timer already canceled error on Mon, 15 Nov 2010 11:17:59 GMT]]></title><description><![CDATA[<p dir="auto">If nothing helps:</p>
<p dir="auto">First Install sun-java6-jdk<br />
Second deinstall any openjdk and gcj stuff - you have now a clean java system. I had some difficulties with openjdk6 after installing suns jdk and removing openjdk its working.</p>
<p dir="auto">Arne</p>
]]></description><link>https://forum.mango-os.com/post/4939</link><guid isPermaLink="true">https://forum.mango-os.com/post/4939</guid><dc:creator><![CDATA[apl]]></dc:creator><pubDate>Mon, 15 Nov 2010 11:17:59 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved] Timer already canceled error on Sun, 14 Nov 2010 20:32:53 GMT]]></title><description><![CDATA[<p dir="auto">Thank you very much for your answer mlohbihler,</p>
<p dir="auto">I have put a log extract just when the error occurs (2010-11-14 21:18:37,306) in the attached file.<br />
In the beginning of the Catalina log file I can see the Tomcat version:<br />
INFO: Starting Servlet Engine: Apache Tomcat/6.0.20</p>
<p dir="auto">I can see also an info at beginning of log file, could it be linked to the problem?<br />
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: /usr/lib/jvm/java-6-openjdk/jre/lib/i386/client:/usr/lib/jvm/java-6-openjdk/jre/lib/i386:/usr/lib/jvm/java-6-openjdk/jre/../lib/i386:/usr/java/packages/lib/i386:/usr/lib/jni:/lib:/usr/lib</p>
<p dir="auto">I have read there was a bug in Tomcat 6.0.24 causing the same error message but I'm not sure it is linked:<br />
<a href="https://issues.apache.org/bugzilla/show_bug.cgi?id=48971" rel="nofollow ugc">https://issues.apache.org/bugzilla/show_bug.cgi?id=48971</a></p>
<p dir="auto">Thank you for your help,</p>
<p dir="auto">Attachment: <a href="http://archive.infiniteautomation.com/forum/posts/downloadAttach/72.page" rel="nofollow ugc">download link</a></p>
]]></description><link>https://forum.mango-os.com/post/4937</link><guid isPermaLink="true">https://forum.mango-os.com/post/4937</guid><dc:creator><![CDATA[amoulart]]></dc:creator><pubDate>Sun, 14 Nov 2010 20:32:53 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved] Timer already canceled error on Sat, 13 Nov 2010 22:02:10 GMT]]></title><description><![CDATA[<p dir="auto">I can't recreate. Is there an error message with stack trace in the Tomcat console? Also, what version of Mango are you using?</p>
]]></description><link>https://forum.mango-os.com/post/4936</link><guid isPermaLink="true">https://forum.mango-os.com/post/4936</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Sat, 13 Nov 2010 22:02:10 GMT</pubDate></item></channel></rss>
