<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Release Notes for Mango 5.6.x]]></title><description><![CDATA[<p dir="auto">Summary of the Mango 5.6.x patch series (5.6.0 – 5.6.10). Full changelogs are on the <a href="https://docs.radixiot.com/docs/release-notes/5.6.x/" rel="nofollow ugc">documentation site</a>.</p>
<ul>
<li><strong>5.6.0</strong> (Dec 1, 2025) — Java 25 build support (Java 17 remains minimum), new Prometheus metrics endpoint, gRPC publisher offline queuing, multi-level email escalation, redesigned event-handler management UI.</li>
<li><strong>5.6.1</strong> (Dec 5, 2025) — Fixed the Users page loading all rows and producing infinite queries; fixed a circular-dependency exception on startup when an active event exists in the database.</li>
<li><strong>5.6.2</strong> (Dec 15, 2025) — Jetty upgraded to 12.1.5, resolving stale file content being served after on-disk changes; several EMS device-details fixes.</li>
<li><strong>5.6.3</strong> (Feb 19, 2026) — Improved NoSQL (ias-tsdb) "reload links" performance; EMS/Platform Manager filtering and UI fixes; Modbus tools UI now supports multi-select.</li>
<li><strong>5.6.4</strong> (Mar 10, 2026) — radix-tsl upgraded to 0.5.2 with multi-series query support; EMS null-check fixes.</li>
<li><strong>5.6.5</strong> (Mar 23, 2026) — Made ClickHouse FINAL query behavior optional for better performance; fixed gRPC publisher dropping inactive events re-raised after a crash.</li>
<li><strong>5.6.6</strong> (May 13, 2026) — ClickHouse JDBC driver moved to the official upstream release with retuned table defaults, improving ingest and query performance on TSL-backed installs. Requires manually migrating existing tables to take effect — see the docs before upgrading.</li>
<li><strong>5.6.7</strong> (Jun 16, 2026) — Fixed a startup issue affecting Modbus serial (ASCII/RTU) data sources.</li>
<li><strong>5.6.8</strong> (Jun 23, 2026) — Fixed a Cloud Connect user-sync bug that could break the client's web interface; <strong>breaking change:</strong> MySQL row-by-row result streaming removed (db.fetchSize=Integer.MIN_VALUE is no longer valid), backported from 5.7.</li>
<li><strong>5.6.9</strong> (Jul 22, 2026) — Fixed several data sources (ASCII File, Data File, TCP/IP) failing to register on startup; fixed BACnet/Modbus/gRPC write-back events not firing; fixed a Watchlist JSON import bug dropping chart configuration.</li>
<li><strong>5.6.10</strong> (Aug 4, 2026, latest) — Fixed chart data stopping updates when 3+ points are selected without combine-values.</li>
</ul>
<p dir="auto">As always, review the full release notes for your upgrade path before updating a production system.</p>
]]></description><link>https://forum.mango-os.com/topic/6186/release-notes-for-mango-5.6.x</link><generator>RSS for Node</generator><lastBuildDate>Thu, 20 Aug 2026 23:15:12 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/6186.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 18 Aug 2026 19:31:42 GMT</pubDate><ttl>60</ttl></channel></rss>
